I went into my Linksys wireless router set-up on the internet and added 02 to the end of my IP Address (I was trying to add a computer but couldn't get the Edit Macfilter list to come up) now I cannot access it at all. Please help!!
You can't add the 02 on the end of an IP address so go back into the Linksys wireless router set up and take the 02 off. Are you trying to get a laptop to work? What are you trying to do I need a little more information.
Posted on Nov 06, 2010
Hi there,\r\nWe have a Linksys WPS54G print server and I'm trying to re-connect it to the new Veridon Fios router. The print server has a default ip address of IP Address:169.254.53.156 but the new router...
The problem is that your printer can't obtain an IP address from your router so it is kicking back the IP address 169.x.x.x which indicates it can't reach the router. You need to go into the IP address configuration on your printer and set a static IP address on the same subnet as the router. For example your router's IP is 192.168.1.1 so set your printer's IP address to 192.168.1.5 and set the default gateway on the printer to the router's IP address (192.168.1.1) next you need to enter in the DNS Server address which is also the router's IP address (192.168.1.1). Once you do that you will be on the same network as your router. From there you can add the printer on your computer through devices and printers if its a Windows pc. Cheers! J the Guru
Oct 16, 2017 | Linksys Computers & Internet
No connection
Ok here is what you do
1.) disconnect your internet cable
2.) connect your router to your computer
3.) in internet explorer type 192.168.1.1
4.) enter your username and password
5.) click on Lan
6.) In the ip address box change your router ip to a new ip
e.g. 192.168.1.2
7.) Click on DHCP AND ENABLE THE DHCP SERVER
8.) Click on wan
9.) In Wan settings choose static ip address
10.) set the static ipaddress to the ipaddress you entered for your router
11.) set your subnet mask
12.) In the isp gateway enter your modem ip e.g 192.168.0.1
13.) as your primary dns enter your modem ip e,g 192.168.0.1
14 save changes and exit
YOU CAN HAVE THE ROUTER AUTOMATICALLY ASSIGN AN IP ADDRESS TO EACH SYSTEM OR YOU CAN SET IT AUTOMATICALLY
FOR AUTOMATIC ASSIGN JUST CONNECT THE CABKLE
FOR STATIC IP(recommended)
double click on the network icon to the buttom of your screen e.g LOCAL AREA CONNECTION
Click on Properties
Double Click on Internet Protocol(TCP/IP)
Enter the ip address you want the computer to have using the same 3 bloacks as your router e.g 192.168.1.10
Enter your sub net mask
Enter the ip for your moden in defaul gateway e.g 192.168.1.1
Enter the Prefered Dns as also your Modem ip 192.268.1.1
cheers
Jan 05, 2008 | Linksys Wireless-G WRT54G Router
Cannot connect linksys wireless broadband router with at & t dsl modem to connect to internet ?
Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Click on WAN settings and set those settings as your internet service provider settings.
Enable DHCP if you want to get ip from router.
Click on wireless settings enable wireless then enable WEP Security then add WEP code .It is your password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
Then check
Let me know if you need further assistance.
Thanks for using FixYa.
Jun 05, 2010 | Linksys Wireless-G WRT54G Router
I'm trying to configure add my dell dimension 3000 to a netgear wireless router via a linksys devise. This would be adding a 2nd computer to the wireless router. I know the password. I'm getting a error...
Do You have an association button on Your router? If so, the firstly press the button and then try to connect. If not, You must enter IP address of Your computer, like 192.168.0.5 Subnet mask, like 255.255.255.0 IP address of router, like 192.168.0.1 Then, most important - default gateway. If You have another computer connected at the same router, run cmd, then ipconfig in the black MS DOS window that appears after cdm command. Here You can see all parameters of Your TCP/IP configuration. Take a note of the default gateway and put it to TCP/IP settings of Your Linksys device. If it not help, drop me a message.
Sep 10, 2009 | Dell Dimension 3000 PC Desktop
Laptops stopped connecting wireless
how about to reset your router and setup it the proper address by your internet provider..
laptops only connect to the router automatically if you enable it reconnect and detect its network without manually connect internet, this procedure can see in your wireless properties by enabling it.
And also ask your internet provider if theres a problem also with their internet connection.
Jul 18, 2009 | Linksys WRT160N Wireless Router
Having problems with linksys connection
Please check if the router needed IP address?
- if yes? ( goto Network Settings and add the IP address.
- if not? ( obtained you Network Settings do not input IP address.
Double check also if your Router is properly configured?
Sep 21, 2008 | Linksys Wireless-G WRT54G Router
I cant connect my wireless laptop tp my comp.
Let me know the settings of your Router if needed IP address?
Yes - add your IP address into Network Connection.
No - obtained the setting in your Network Connection.
How to Add or Obtained the setting s of your IP address:
- goto Control Panel
- Double Click Network Connection
- Rigth Click then Properties the Local Area Connection
- Select Internet Protocol (TCP/IP) and select Properties
- Under General Tab they have choices to add or obtained settings.
Sep 20, 2008 | Linksys Wireless-G WRT54G Router
Linksys wireless g router will not connect to the internet
hello jillyg70
my name is tazman
have you tryed calling linksys they can help you . but you might want to try going to 192.168.1.1 first this will get you in to your router so you can set the settings on it. it might ask you for a password its admin try this before you contact linksys if you have trouble setting it up we have a premium chat i can help you
hope this works
Jul 06, 2008 | Linksys Wireless-G Broadband Router
Wireless network broken, access to WRT54G & Motorola 2210-02 via http.. denied
I have att yahoo dsl which I installed about a year ago. The process required bridging the ADSL Modem (in my case a speedstream 4100) and accepting dynamic IP addresses and configuring PPPoE on the WAN side of my Linksys router. The ATT support person walked me through the entire process over the phone even though I was comfortable with making the Linksys configuration changes as I had to do the same in China without technical support. The modem configuration was no more difficult than the router configuration as it was performed from a web browser too. The biggest warning was that to reverse the modem change (if desired) required use of a reset button because the web interface was disabled as a result of the configuration change. My advice to you especially if you are willing to attach the Linksys router to the telco modem is to contact the ATT highspeed DSL support line and see if they will walk you through it like they walked me through it. Reviewing your Linksys User's Guide and understanding the configuration of that device would probably be appreciated by the ATT Support person as well as assuring you can access the Linksys router to configure it during the call.
Dec 08, 2007 | Linksys Wireless-G WRT54G Router
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
