HOOKING UP A HUB WITH MODEM
My son got me a 5 port hub and I want to hook it to my paradyne router 6381 A3 router. No instruction came with the hub. We have worked with it for a while and no go. HELP
  • 106 Answers
Plug the cable to one of the ports on the hub which I'm sure you tried... if not, there should be a port marked with an "X" which means it's a cross over port which might do the trick. Just make sure the port next to that port is free (not plugged to anything).
Do you get any lights when you plug an ethernet cable between the router and the hub?
Posted on Jun 15, 2008
My company provided me wired internet using Paradyne 6381 wired modem. it works fine. I have D Link 2640 T wirelss modem + router available with me. Please advise me how do I connect available D link 2640...
Since your D-Link 2640 is a modem + router it may not work the way you intend.
You need just a wireless router without modem.
Run a small Ethernet patch cable from your Paradyne modem into the WAN port on your router, you can plug your existing Ethernet cable into one of the other LAN ports on the router, then access the router setup using the computer connected to the Ethernet cable using a browser and putting the router's IP address into the address line of your browser. It will most likely be 192.168.0.1 or 192.168.1.1.
Once you have configured the Wi-Fi router you will have your wireless network. Full instructions should come with the router.
Routers are available for as little as $29.95 but expect to pay closer to $79.95 for satisfactory speed and capability.
Oct 23, 2017 | Paradyne ADSL/R 6381 Router (6381-a2-200)
What is the ip address of paradyne 6381 a3 300 router
To configure your router, open your web browser. Type the default IP address (http://192.168.1.1) into the Location field of your browser and press the Enter key. A Login screen will appear. Use the below to log into your router.
The default IP address is 192.168.1.1
The default user name is Admin
The default password is Admin
Both are case-sensitive.
Jan 08, 2010 | Paradyne ADSL/R 6381 Router (6381-a2-200)
How to hook up the Ethernet 5port Workgroup Hub Model No. ew5HUB
To start with please make sure it says router on it as the title says "Networking Hub". These are two different devices. If not return the Hub and purchase a Linksys Router then follow instructions below.
Assuming you have a router:
Before you begin unplug the power from the Cable or DSL Modem before you start as they will have to be powered on in a particular order I will discuss later.
Your cable or DSL modem will have a cable coming out of it that looks similar to a phone line except a little larger. The cable will say CAT5 or CAT6 or Ethernet on it.
On your Linksys Router there will be a ports/jack that you can plug the Cable into from your Cable/DSL Modem. You want to look for one labled "WAN" or "Internet". Plug it in then plug in the power to your Cable or DSL Modem. When the "Ready" light is on the modem, plug in the power cable to your router.
The next step is hooking it up to your computer. There will be anywhere from 1 to 8 more ports available on your Router that is number 1,2,3,4, etc. Plug another Ethernet Cable into any one of those ports. With the other end plug it into your PC or Laptop, there is only one port/jack on your computer that this plug will fit in. Power up your PC and voila, you should be on the Internet.
Please let me know if this solves your problem.
Thanks,
Adam
Nov 28, 2008 | Linksys Instant Networking Hub
Using both USB and Ethernet to connect to the internet
Does your router suports usb ports, normally routers do not support usb ports, please check if your router first suports usb ports
Jul 22, 2008 | Paradyne 6381 ADSL2+/ReachDSL Router...
Using both USB and Ethernet port to connect to the Internet
Hi; I have used it with both ethernet and usb connections at the same time. I have never used the bridge, but I use it at home.
Try this ( I have XP SP3): Right-click on the monitors where the clock is (lower right corner), select "Open Network Connections". Go to the LAN connection and r-click "Properties". On the "general" tab select "Internet Protocol (TCP/IP)". There you select "Obtain IP address automatically" and "Obtain DNS server automatically" then click "Ok" until exit. Either Shut Down or Restart the PC. Check if this work.
Jul 19, 2008 | Paradyne 6381 ADSL2+/ReachDSL Router...
Trying to set up pptp on a Paradyne 6381
I have modems 6381-A2-200, sw ver.03.00.10. This model does not support pptp-connection.
Dec 06, 2007 | Paradyne 6381 ADSL2+/ReachDSL Router...
6381-A3-302,6211-I1-300 Paradyne ADSL 2+/Bridge Router
i have paradyne paradyne 6381 a3 302 lost the driver cd. My new windows xp don't pick it automaticly. plz give me a slution.
Nov 22, 2007 | Paradyne 6381 ADSL2+/ReachDSL Router...
Computers & Internet Logo
688 people viewed this question
David Payne
David Payne
