Question about Epson Stylus NX100 InkJet Printer
Wwhwere is the ink cartridge replacement button
How to replace catridges for Epson Stylus Office T40W??
Good day. I hope this steps can help you in replacing your cartridges. This how i remember doing it. Just follow these steps.
>Make sure the power light is on, but not flashing.
>Open the printer cover and the output tray.
>Press the ink button. The ink cartridge holder moves to the ink cartridge check position and the
power light begins to flash.
>Press the ink button again. If more than one ink cartridge is expended or low, the ink cartridge holder moves to the mark.This
occurs each time you press the ink button until all expended or low ink cartridges have been
indicated. Once all of the expended or low ink cartridges have been indicated, the ink cartridge
holder
moves to the ink cartridge replacement position when you press the ink button. >Open the cartridge cover and place the ink cartridge into the cartridge holder with the bottom down.
Then push down the ink cartridge until it clicks into place. Then close the cartridge cover
>Press the ink button and then the printer moves the ink cartridge holder and begins charging the
ink delivery system
Hope this will help you a bit with your ink cartridge replacement problem. Have a great day.
May 22, 2011 | Epson Computers & Internet
MY EPSOM CX 5500 WILL NOT PRINT. i HAVE A RED LIGHT PERM ON BY THE INK ICON. i HAVE TAKEN OUT THE CARTRIDGES SEVERAL TIMES AND RESTARTED BUT NOTHING HAPPENS. tHE CARTRIDGES HAVE INK AS FAR AS i...
Hello, This happens with epson as it has a chip on the cartridge, which sometimes shows the cartridge empty even if there is some ink left on it. You can try this steps:- 1. With the printer turned on press the ink replace button, which will bring the print head to ink replacement position, pull out the cartridges one by one and cover the tip of the cartridge with some tape and shake the cartridges and reinsert it on the printer and press the ink replacement button once again, the printer will check the inks cartridges, if the inks is empty it will show the red light again, pressing the button once will bring the printer to ink replacement position with the cartridge to be replaced on the replacement position. you can also check on the printer software on the pc that which ink cartridge is emptied.
Hope this helps.
May 14, 2011 | Epson CX4400/CX5600
How do i install my ink cartridges into my epson stylus nx125
Starts on page 23. http://files.support.epson.com/pdf/nx125_/nx125_qr.pdf
Replacing Ink Cartridges Make sure you have a new ink cartridge before you begin. You must install new cartridges immediately after removing the old ones. Caution: Do not open ink cartridge packages until you are ready to install the ink. Cartridges are vacuum packed to maintain reliability. Note: Leave the expended cartridge installed until you have obtained a replacement, or the ink remaining in the print head nozzles may dry out. 1. Turn on your printer. 2. If an ink cartridge is expended, the error and ink lights on the control panel stay on. 3. Open the document cover, then open the ink cover. Caution: Do not remove the ink cartridge guard or you may damage the printer.24 Maintaining Your Printer 4. Press the y Stop button. If a cartridge is low or expended, the print head moves that cartridge to the replacement position to indicate that it should be replaced. The P Power light starts flashing. If two or more ink cartridges are expended, the expended cartridge at the far left moves to the replacement position. The P Power light starts flashing. If no cartridges are low or expended, the print head does not move. Note: Do not hold the y Stop button for more than three seconds, or the printer may start cleaning the print head. 5. Squeeze the tab on the cartridge and lift it up. Dispose of it carefully. Do not take the used cartridge apart or try to refill it. Warning: If ink gets on your hands, wash them thoroughly with soap and water. If ink gets into your eyes, flush them immediately with water. Keep ink cartridges out of the reach of children.Replacing Ink Cartridges 25 6. Before you open the new cartridge package, shake it gently four or five times. Then remove the cartridge from the package. Caution: Do not touch the green chip on the front of the cartridge. This can damage the ink cartridge. 7. Remove the yellow tape from the bottom of the ink cartridge. Caution: Do not remove any other labels or seals, or ink may leak. 8. Insert the new ink cartridge into the holder and push it down until it clicks into place. 9. Press the y Stop button. If another cartridge is low or expended, it moves to the replacement position. Repeat steps 5 through 8 to replace any other cartridges that need to be replaced. When you press the y Stop button and no other cartridges need to be replaced, the print head moves to its home position and the printer starts priming the ink. This takes about 1 1/2 minutes.26 Maintaining Your Printer When the P Power light stops flashing and the error and ink lights go out, ink charging is finished. 10. Close the ink cover, then close the document cover. Caution: Never turn off the your Epson printer while ink is charging or you'll waste ink. If the error and ink lights remain on after the print head moves into its home position, an ink cartridge may not be installed properly. Press the y Stop button again, and then press the ink cartridge down securely. Note: If you replaced a cartridge while copying a document or photo, cancel printing and make sure your original is still placed correctly on the document table. Then copy your original again. If you remove a low or expended ink cartridge, you cannot reinstall and use the cartridge.
Mar 09, 2011 | Epson Stylus Multifunction Inkjet Printer/...
How to change ink cartridges on an Epson CX 3800
Be sure you have a new ink cartridge before you begin. Once you start replacing a cartridge you must complete all steps in one session.
1. Make sure the Epson CX printer is on.
2 Make sure the document cover is closed, then open the scanner
Caution: Do Not open the scanner when the document cover cover is open.
3. Press and release the " ink " button. The ink cartridge moves to the check position and the
" On " and " ink " lights flash. If one of the cartridges is low or empty, the printer moves the
cartridge to the _ink out mark.
Note: Don't hold down the " ink " button for 3 or more seconds or the printer starts cleaning the print head.
Caution: Do Not move the print head by hand; this may damage the printer, always press the ink
button to move it.
4. Press the " ink " button again
a. If more than one cartridge is low or empty, the next cartridge moves to the_ink out position.
b. If all of the empty or low cartridges have been identified, the print head moves to the ink
cartridge replacement position.
5. Open the cartridge cover.
6. Squeeze the tab at the back of the empty/low cartridge and lift it straight out.
7. Before you open the new ink cartridge package shake it four or five times, then remove it
from the package.
Caution: Do Not remove or tear the label on the cartridge; otherwise ink will leak.
Do Not touch the green chip on the front of the cartridge, this can damage the
ink cartridge.
8. Place the new ink cartridge into the cartridge holder and push it down until it snaps into
place.
a. Replace any other cartridges that need to be replaced.
9. Close the ink cartridge cover and press it until it clicks into place.
10.Close the scanner.
11. Press the " ink " button The print starts charging ink and the " On " light starts flashing. This
takes about one minute. When it's finished the " On " light stops flashing and remains on.
and the " ink " light goes out.
Caution: Never turn off the printer while the " On " light is flashing or you'll waste ink.
Note: If the " ink " light stays on ( not flashing ), the ink cartridge may not be installed correctly.
Press the " ink " button again and reinstall the ink cartridge until it clicks into place.
Feb 09, 2011 | Epson Office Equipment & Supplies
How to Change ink cartridge on Epson Stylus SX215
#1 Wait until you are out of ink. The warning light and ink-low notifications come on well before the ink cartridge is empty, and even if it runs out of ink in the middle of a print, you can replace it then and finish the print with no problem.
#2 Lift the lid of your Epson inkjet printer to expose the ink cartridge replacement button. Make sure you have plenty of light so you can see what you are doing.
#3 Press the ink cartridge replacement button. This will loosen the empty ink cartridges so they can be pulled up and out.
#4 Fill the empty cartridge at an ink-refilling location, or buy a new ink cartridge to replace the empty one.
#5 Insert the new or refilled ink cartridge into the holder with the same orientation as the previous one.
#6 Press the cartridge replacement button to charge the system and close the printer cover. Charging takes about one minute
Thanks
Sep 30, 2010 | Epson Stylus Multifunction Inkjet Printer/...
I have all full cartridges, I have tried cleaning the heads multiple times, still i can not get any printing..not even the head alignment will print
try to reseat the ink cartridge, that means take it out, re insert the same cartridge if it is with ion 6 months, if more than 6 months, replace it w/ brand new, the ink might dried up already.
follow this:
Press the Setup button and select Ink Cartridge by pressing the fontu1.gif/fontd1.gif button, then press the OK button. Confirm the messages on the LCD panel and press the OK button to start the ink cartridge replacement.The ink cartridges move to the replacement position.
Make sure that the document cover is closed, and then open the scanner unit.
Open the cartridge cover. Pinch the sides of the ink cartridge . Lift the cartridge out
put it back in the printer.
Close the scanner unit, then press the OK button.
then print a nozzle check
Feb 10, 2010 | Epson RX620 All-In-One InkJet Photo...
I want to replace the ink cartridge, let me be informed about the procedure to instal the new ink cartridge
Press ink button once, the carriage should move to ink replacement position. When in position replace the ink cartridge, after replacing the cartridge push the ink button once again.
Jan 17, 2010 | Epson Stylus C20SX InkJet Printer
Error inkcartridge
Error message: No color or black ink cartridge-->Press the Color Copy button to install a new ink cartridge.
Solution: The indicated ink cartridge is not installed. Please install the necessary cartridge(s).
Error message: Color or black ink out -- >Press the Color Copy button to begin replacing the ink cartridge.
Solution: The indicated ink cartridge is out of ink. You will need to replace the necessary ink cartridge(s).
Error Message: Ink cartridge error -- > Press the Color Copy button to begin replacing the ink cartridge.
Solution: There is something wrong with the ink cartridge. Make sure the cartridge is genuine Epson ink. Also, try reseating the cartridge (remove it, and then reinstall it).
Error Message: Paper jam or misfeed -- > Press the Color Copy button and clear the paper jam by hand if necessary.
Solution: Paper is jammed. Check for any obstructions under the unit's cover, and in the paper tray.
Error Message: Paper out -- > Load paper in the sheet feeder and press the Color Copy button.
Solution: Load paper in the sheet feeder, and then press the Color Copy button to continue printing.
Error Message: Scanner unit open -- > close the scanner unit
Solution: Carefully close the scanner and press it down until it clicks securely into place.
Error Message: Scanner error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Unlock the transportation lock, if necessary. If it is already unlocked, toggle the lock back and forth, 5-10 times. Turn on your Stylus CX3200 again.
Error Message: Printer error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Disconnect it from power, and then reconnect it to power. Press the ON button to turn on the Stylus CX3200
Nov 28, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Epson stylus 1280 printer
Based on the lights you are already out of one or more ink cartridge or an ink cartridge is not being recognized/expended.
-You cannot print if any ink cartridge is expended.
-Leave the empty cartridge installed in the printer until you have obtained a replacement.
Once you start the ink cartridge replacement procedure, you must complete all the steps in one session.
1. Open the printer cover and press the INK REPLACEMENT button, located under the printer's cover. The print head moves to the center and the lights flash.
2. Lift up the ink cartridge clamp. The cartridge rises up from its holder.
3. Remove the cartridge and dispose of it carefully. If ink gets on your hands, wash them with soap and water. If ink gets in your eyes, flush them immediately with water.
4. Unpack the new ink cartridge and remove the yellow tape. You must remove the yellow tape from the top of the cartridge. Do not remove the clear seal underneath the cartridge. Do not touch the green circuit board on the back of the cartridge, or you may inhibit normal operation and printing.
5. Tilt the new cartridge toward you slightly as you insert it. Lower the cartridge so that the tabs rest on the hooks. Do not place the cartridge tabs under the hooks.
6. Press down firmly on the ink cartridge clamp until it snaps in place.
7. If you need to replace the other ink cartridge, repeat steps 2 through 6 before continuing with step 8.
8. Press the INK REPLACEMENT button and close the printer cover. The printer begins charging the ink delivery system.
9. Wait until ink charging is finished (the power light stops flashing and the red error light goes out).
Jun 17, 2008 | Epson Stylus Photo 1280 InkJet Printer
Epson Stylus NX100 InkJet Printer Logo
655 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
