How do I copy and enlarge a 4" x 6" photo to 8.5" x 11" sheet of paper?
  • 44 Answers
You need a scanner and an imaging software (i.e. photoshop).
- Scan the original photo
- increase the resolution on the software to at least 300dpi
- increase/modify the size of the image to 8.5 x 11
- save new image under a different name
Different software have different detailed instructions, but the general objective is as described above.
Hope it helps
Posted on Nov 06, 2010
I have just got a new HP 1050 Deskjet J410 Series printer. I am not able to increase or reduce a document when copying. What do i need to do?
Press Copy until Reduce/Enlarge appears in the top line of the dis
The following options are available in the Reduce/Enlarge menu.
you will have three choices.
Reduce/Enlarge
Actual Size
Custom 100%
Full Page 91%
Legal > Ltr 72%
Also:
Use Photo Fit to Page when you want to automatically enlarge your original
photo to fill the printable area of the paper size loaded in the paper tray.
Photo Fit to Page only enlarges original photos that are standard photo sizes. The
standard photo sizes are as follows:
• 3.5 by 5 inches (9 by 13 cm)
• 4 by 6 inches (10 by 15 cm)
• 5 by 7 inches (13 by 18 cm)
• 6 by 8 inches (15 by 20 cm)
• 8 by 10 inches (25 by 25 cm)
For originals containing text or photos that are not a standard size, use Reduce/
Enlarge.
Manual is HERE Copy functions start on page 27.
Mar 27, 2011 | Office Equipment & Supplies
How can I enlarge pages and print them across multiple sheets of paper on the hp photosmart c6280 all-in-one printer?
Use photoshop (or similar) to enlarge the photo to the size you want. Then cut it up in photoshop to fit the printers paper size.
Then print each individual part of the photo.
Is that what you wanted to achieve?
Mar 19, 2011 | Computers & Internet
Hi...I have a problem with my HP Photosmart C7280...can you help ? the error message "Photo tray problem" keeps coming up, telling me to "lift the output tray, push the photo tray all the...
Photo tray problem
' Lift the output tray up and verify that the photo tray
' is pushed in until it stops, then lower output all the
' way down. Press OK button on the printer to
'continue printing
HP Photosmart C7280 All-in-One Printer
1. Turn off printer.
2. Pull out paper tray and photo tray
3. Remove output duplexer (on back of printer)
4. Open input sheet feeder (on top of printer)
5. Open cartridge access door. (Basically lift up control panel and scanner section of the printer)
6. Turn on printer (Power button on now raised control panel)
7. Printer may display message "Performing printer alignment - Do not interrupt"
8. Wait for a few minutes until printer stops making all setup noises.
9. Close cartridge access door, close input sheet feeder, replace output duplexer, insert paper trays
10. Do a test print. All should be fine.
Mar 11, 2011 | Office Equipment & Supplies
I860 will not print a 4 x 6 photo on a windows 7 pc. It gives a message that I have installed the wrong paper. It only wants to print full sheet size photos. I installed the canon add on module drivers and...
Set Envelopes Correctly Before setting envelopes, press down on all four corners and edges of the envelopes to remove curls and bends, as well as any air contained.
Note: The flap of the envelope should be straightened if bent. If the envelope is curled, hold the opposite corners and gently bend them in the opposite direction. If the leading edge of the envelope is puffed or curled up, use a pen, etc. to press the envelope flat and sharpen the crease. (Press the envelope completely flat, working from the middle to the edge.)
i80_envelopes_2.gif How to set envelopes:
  1. Set envelopes to the right side of the sheet feeder. Set envelopes with their longer side vertically and the flap either at the bottom or on the left.
  2. Pinch and slide the paper guide until it firmly resets against the left side of the stacked envelopes.
    Note: The maximum number of envelopes that can be loaded is five.
    <1> Sheet Feeder's right side
    <2> Paper Guide
  3. Set the paper thickness lever to the left.
    <3> Paper Thickness Lever
    Note: Remove the printed papers from the paper output slot cover before five sheets have been ejected.
Also How do I enlarge or reduce my printing size?
Nov 07, 2010 | Canon i860 InkJet Photo Printer
On i850 canon printer (with slider to the right for thicker paper) won't 'grab' it and feed this thicker paper through makes clunking noises and attempts to no avail: have tried single sheet or several in...
make sure you use the correct paper size for the printers specification :
Media Type Matte photo paper , Banners , Glossy photo paper , High-gloss photo film , Iron-on transfers , Plain paper , Glossy photo cards , Transparencies , Envelopes
  • Max Media Size (Custom) 8.5 x 14.0
  • Media Sizes Letter A Size (8.5 in x 11 in) , U.S. #10 envelopes , European DL , Legal (8.5 in x 14 in) , A6 (4.13 in x 5.83 in)
  • Envelope Sizes US No 10 (4.1 in x 9.5 in)
  • Card / Label Sizes US 4 x 6 Card (4 in x 6 in)
  • Total Media Capacity 150.0 sheets
  • Media Feeder(s) 1.0 x Autoload - 150.0 sheets - Legal (8.5 in x 14 in)
  • if you are then you might want to try cleaning the printer pickup rollers with a lynt free cloth and a bit of alcohol if that does not solve the issue then you machine is fualty and if your still under warrenty I suggest you replace it
    Nov 08, 2009 | Canon i850 InkJet Photo Printer
    Paper will not feed
    when you printer mechanism going to be old it can not turn your photo paper. change the rubber of roller it will be solved
    Oct 25, 2009 | HP Office Equipment & Supplies
    Canon R265 keeps grabbing 6 sheets for printing one sheet
    Paper has different thicknesses called Mils. Make sure you are using the correct paper for your printer. Paper that is thinner than is intended for your printer may sometimes cause it to take multiplesheets.
    Jun 15, 2009 | Epson Stylus R265 InkJet Photo Printer
    Paper Feed Problem
    I had same problem... eventually just started using 8.5 X 11 paper to print photos with smaller sizes.
    Mar 30, 2008 | Epson Stylus Photo R320 InkJet Printer
    Trouble enlarging a 4 x 6 photo to a 5 x 7.
    What software are u using to print and resize and what is the pritner that u have.
    Mar 01, 2008 | HP Photosmart 2610 All-In-One InkJet...
    Red line on last quarter of photos
    I assume that the red line is not on the photos themselves (make sure this is the case - if they're scanned photos, it might be a scanner problem). If this is a 4" by 6" paper, set it in the printer after bending it in the opposite direction. 1) Set a sheet of paper on the printing side of the paper to be printed on. (If the print surface is touched by hand, the print surface may be soiled by skin oils, and the print quality may deteriorate.) 2) To bend the paper, hold the paper in a rounded shape for about 10 seconds. 3) Remove the paper not to be used in printing, and confirm that, when laid flat with the print side up, the center of the paper to be printed on is raised between 2 to 5 mm (0.2 in.) . 4) The curled paper to be printed on should be set in the printer, and printed, sheet by sheet. Canon recommends using Photo Paper Pro PC-101S 4" x 6" sized paper. When using PC-101S, printing is performed at the center of paper and streaks or uneven printing is avoided. If this is an A4 sized paper, try using Photo Paper Pro PR-101 paper, and make sure that the printing quality is set to "high" or "fine". If nothing helps, I would suggest trying a new ink cartridge. If you still have this problem and nothing solves it, call a repairman.
    Apr 09, 2006 | Canon BubbleJet i560 InkJet Printer
    Computers & Internet Logo
    41 people viewed this question
    David Payne
    David Payne
