Re: Nautilus N655. Looking for replacement plastic grill (approx. 19x16) and light lens (approx. 6"sq.). Any ideas? -Rick
3 Suggested Answers
bulldogchief
  • 388 Answers
SOURCE: need sq inches of grill model no ggr50b
This grill is supposed to have 200 square inches of cooking surface. I hope this answers your question. If you need or want to know anything else I can help you.
Posted on Nov 24, 2009
  • 118 Answers
SOURCE: fan motor quit working, we
lowes has it
Posted on Dec 05, 2010
Where can I by a new box/transformer my lighted out door tree.
Tree is approx 6 feet tall payed approx 200.00 dollars for this tree .not happy with this failure .it is the black box approx 3in sq. with a plug in for the lights ...If you wish to get some details; check the site linked here. AmanStino Mouse Pad with Gel Wrist Pad grey9 0 7 8 AmanStino
Nov 21, 2016 | Office Equipment & Supplies
Where can i buy a nautilus model n655 replacement ?
Sorry but this site doesn't sell parts or have anyway to look them up for you.
Oct 25, 2016 | Dishwashers
How do i convert 60 tons of ashpalt to square yards
AC is approx. 145 lbs per cubic ft.
there are 27 cubic ft in 1 cubic yard
60 tons x 2000 = 120000 divided by 145 = 827.58 cubic ft divided by 27 = 30.65 cubic yards
square yards would depend on thickness of AC.
you can take thickness x sq ft to get cubic ft
in concrete 1 cubic yard =
4 inch thickness = 81 sq ft or 9 sq yrds
6 inch thickness = 54 sq ft or 6 sq yards
Feb 16, 2015 | Heating & Cooling
I have a Kenmore grill and when I went to pull the gas tank off to get it refill a tiny plastic circular piece fell out of the connection. When I reconnected it it did not supply gas to the burners. I...
Yes, it may be the plastic ring, if you didn't reinstall it. However, it could be something else. The gas regulator may be locked up. To solve this problem, do the following :
1. Turn the gas tank valve OFF and disconnect the hose from the tank.
2. Wait 5 minutes and reconnect the hose to the tank.
3. Open the tank valve VERY, VERY SLOWLY (Slow motion, slow).
4. Once the tank valve is fully open, light the burner farthest from the tank first and set the burner
control knob on HIGH. Does the flame height look correct for being set on HIGH? If so, light
the remaining burners the same way. Do all the burner flames look correct? If so, you solved
the problem. Remember, to always open the tank valve Very, Very Slowly.
If that didn't solve the problem, you will need to replace the grill's Hose/Regulator Assembly. It runs about $30.00 at any home center or hardware store that sells grills & accessories. If you replace it, turn the tank valve ON Very, Very Slowly.
Hope this helped you to troubleshoot and solve the problem. Happy Grilling!! Thanks for choosing FixYa.
Aug 09, 2011 | Kenmore 882 sq. in. Cooking Area Gas Grill...
The brass valve "stem" that the plastic
Although this grills is no longer available, Coleman may still support it. Try contacting their Customer Support Dept 800-835-3278, if you haven't already. From what the Owner's Manual shows, what you're needing is the entire burner valve assembly. As the brass stem is not a separate part.
I hope this helped and thanks for choosing FixYa.
Aug 04, 2011 | Coleman 9995B750 Grill
My camera wont take a pic. it is showing a ! then says " press shutter release button again."
Hi there!
Make sure that the lens is mounted properly. if the lens are properly mounted and you are still getting this error message, you will need to replace the SQ base plate unit to resolve the problem.
Hope this helps.
Apr 25, 2011 | Cameras
Weak Flames on Propane Grill
It is possible that your burners are clogged. Clean the burner ports with a paperclip (not a toothpick).
Jun 01, 2009 | Kenmore Elite 644 sq. in. Cooking Area Gas...
Replacing my headlamps on my 96 Chevy Tahoe
On a 99 Tahoe Don't remove the grill.. There are two 6 inch long, hex head, vertical screws protruding from the frame above the headlight. To unscrew use a small hex socket.. maybe 1/4 inch. Turn the screws counterclockwise to remove till loose then pull up. The screws serve as a linch pin to secure the headlight to the mounting bracket. Here's a pic of the driver side light. Also, I had very good results with my park light lenses in 5 minutes with a hand drill, a soft buffing pad, and some fine polish. They were yellow and dull and looked clear and white when done. I washed the inside of the lense with soapy water and a soft toothbrush.. it made a big difference.fcb90cc.jpg
Mar 04, 2009 | 1996 Chevrolet Tahoe
Chevrolet Equinox how to change the head light
Hiya
IF it's the headlight's light bulb you want to access to pull out old bulb and install new bulb, here it is:
You know where the 3 bolts that secure the headlight body on the frame, also pull out the 4 black plastic clips that holds the grille-it's located on the top grille brackets (it's close to the top radiator area)
When you pull out the clips, gently pull the grille away from the top frame, then pull the headlight body away carefully to allow your hand to gain access behind the grille/headlamp body, find the wire that connects to the headlight bulb, use your fingers to feel the plastic 'collar ring' around the socket and twist it counterclockwise (just like unscrewing a lid off the jar) and pull the socket out with the bulb.
This space is tight for your fingers so it takes patient to get the job done.
IF it's the ENTIRE headlight body you want to remove it off the equinox (since you mentioned you've removed the 3 screws) there's one more that still holds it down is the black plastic tab that's only accessible inside the fender! So to gain access under the fender, remove the plastic wheelwell liner part located underneath the front-left fender (driver's side) there's a small screw and few plastic clips you'll need to remove it to move the wheelliner liner aside to locate that headlight body's plastic tab on the fender frame, use a plier to 'unlock' the tab out of the hole.
Feb 06, 2009 | 2005 Chevrolet Equinox
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
