Question about Homelite ZR10580 FactoryReconditioned 42cc 18" Gas Chain Saw
Will only run with the full choke on - Homelite ZR10580 FactoryReconditioned 42cc 18" Gas Chain Saw
  • George Hels
    George Hels Nov 06, 2010
    have you tried shooting carb cleaner into the carb?
    Brigadier General:
  • 4,088 Answers
Check the fuel filter, air cleaner, and muffler for plugging. Inspect the fuel lines for decay or other damage. If no help, then the carburetor may need service. If you just obtained this saw, take it back for warranty repair or replacement. Good luck!
Posted on Nov 07, 2010
My murray weedeater want run off choke why?
Carburetor needs to be rebuilt. I won't even think twice about. the diaphram is on it's way out.
Aug 29, 2017 | Weedeater Garden
Gas Trimmer will not stay started
Many times with a gas mix, after sitting for a while, the mix separates and gums up the carb. Taking the carb off and soaking it overnight in a parts or carb cleaner and running carb cleaner through the tank and gas lines will cure this.
Jul 02, 2008 | Ryobi 15" Electric Factory Reconditioned...
Mine starts, runs 5 minutes, tries to die, runs 5 more minutes (poorly) with full choke, then dies. Carb? Cool?
need vehicle make and year. "Full" choke will always flood the engine causing it to dye. once running reduce choke. Is this automatic or manual choke?
Apr 07, 2017 | Garden
Small gas engine dies when choke full open
I have attached a diagnostic sheet to help you determine what is wrong.
Jan 21, 2014 | Weedeater 2 Speed Gas Blower FL1500LE ()
What is the starting procedure?
Start with the choke on full press the fuel siphon button till the lines are full of fuel. pull handle until it tries to start but stops. move the choke to half then start again. let it run for 60 seconds on full. don't move the choke to full or it will stop. Either slow the revs and then put the choke on full or keep the revs high and slowly move the choke to full (to allow the governor to slowly advance with the new revs)
Nov 03, 2012 | kawasaki Krb750b Backpack Leaf Blower
I have a coleman powermate premium plus 6250 generator,put in new plug ,new filter ,changed oil,cleaned the carb,put in new gas. runs ok at half choke but when go full choke it starts backfiring and runs...
if you are running the engine at full CHOKE, then it is flooding the engine, but if you meant off full choke, then the carb is still stopped up. Try soaking in carb cleaner overnight after removing jet & all rubber goods. HOPE THIS HELPS.
Dec 17, 2010 | Coleman Powermate Premium Plus 6250W...
My homelite string trimmmer will not run when choke is run position. it will run, but not at full throtle, when choke is set between full choke and half-choke.
you've got a fuel system issue , most likely carb problem, if this a newer trimmer it will likely need the carburetor replaced or adjusted, also check for cracking fuel lines or signs of old fuel varnish in the tank
May 31, 2010 | Homelite Mighty Lite Lawn Trimmer
Blower will only run on full choke ryobi ry08578
They aren't designed to run with full choke on, the choke is for starting cold engines only, many times you can choke them pull the cord a few times and then turn the choke off or turn it down to start it. Then slowly reduce the choke until it runs fine on its own.
May 06, 2010 | Ryobi Backpack Blower 25.4cc
PR4 125 Enduro runs on full choke... What do I do?
2000 rpm and I cleaned bottom of carbs. Someone told running them on full choke would foul out plugs.The bike runs but only when I pull choke all the way out.If it only runs with the choke on it might have a vacuum leak or an air restriction which the choke is counteracting. (very lean fuel mix). To locate a leak you could try spraying CRC around the rubber carb connections and see if the idle speed is affected.,
Nov 10, 2008 | 2006 AJP PR4 125 Enduro
Homelite ZR10580 FactoryReconditioned 42cc 18" Gas Chain Saw Logo
115 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
