Deep boomy base noise all the time - Audio Players & Recorders
    Novelist:
  • 87 Answers
By your description - I am assuming what you have is a hum and not a musical tone. 60 Hz hum is usually the result of bad ground connection on cables (either broken or not connected). Since you don't specify what source is selected or if it is across all sources, I'd start with the cabling. If there are record in/out connections, you might start there.
Posted on Nov 06, 2010
What r the best settings for a Power Acoustic PEQ-73 7Band passive eq, electronic crossover, sub woofer level control
Depends on your room, speakers being used, size of sub woofer, amp set up ect.
There is no "best setting" for every application. If that was the case a variable control would not be needed.
Some rooms are boomy, which would lead you to turn down low freq's. Some rooms are very splashy, in which case high will need to come come down. Some rooms are very dead in either lows or highs, in which case those freq's would need to be increased.
To get a baseline on what your rooom is like send some pink noise through your system and analyze it with a RTA. (real Time Analizer) There are free apps you can use on your phone or pro audio products that do a very good job. With pink noise being pushed through the system you will see what freqencies are naturally louder or softer in your room. Then you can adjust that real time on your eq and see the changes.
This will set your room to a flat response, however lots of people don't like that sound and want more punch,growl, or clarity. In that case simply adjust the low, mids or highs to your own listening preference
Feb 22, 2016 | Audio Players & Recorders
No problem. just bought it and a pair of thump 15s what cables are best. and we want to play our accoustic gigs through this and dont know how to set eq i know its different each room but a starting point.
Use balanced lines for the audio interconnects. Use XLR low noise mic cables or TRS type cables. IMPORTANT: Power the speakers and the mixer from the SAME receptacle, even if it means running extension cords. Ground bounce in building wiring can destroy the circuits in the equipment.
Jul 11, 2011 | Mackie ProFX12 Professional Compact Mixer
I have a husqvarna k750 sawing stone stawls under load whats wrong?
If the motor revs up ok it might be the type of disc you are using. I used a huge 2000 Sten one time from about 1961 going through rebar cemented inside cinder block wall to make some windows. It used the huge 18 inch discs and the older guy that was my boss said there is two types of discs - one is tar bonded abbrasives and the other is resin based which is three times better cutting and doesn't smoke up your lungs while you are breathing hard. They are usually dull red with no black in the grit if you look right up close. If the motor stalls or has a cutting out noise at high rev without load it may just be a dust covered gas filter which is deep inside the saw's gas tank on the end of a rubber tube.
Apr 10, 2011 | Husqvarna 965142201 K750 5HP 12" Gas Cut...
No external mic connection? isn't there a way to avoid the boomy room sound when narrating into the camera from a slight distance?
An external mic connection doesn't make much sense in a waterproof camera. Perhaps switching off the Sound Wind Noise Reduction might enhance the "boomy room sound"?
Dec 04, 2009 | Sanyo Xacti VPC-CG9 Digital Camera
Bissell 9200 ProHeat -the water tank won't fit on the base
sume time the rubber gromit comes of the base of the water tank and gets stuck in the base there the water tank fitts to the base if this is why take out of the and refit it to water tank and of you go
Jul 23, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Kenmore dryer stopped running
Hi, I can determine a motor bad by the noise. Does it hum while holding the start button or is it a grinding deep sound? It can sound like the motor starts slow but once it gets going, it is ok. Sometimes the house lights will dim when the motor statrs going bad.
Let me know if I can help you further.
Vic
Jul 02, 2009 | Dryers
Microphone gives a really boomy distorted sounds on certain chords with an acoustic guitar
Hi Nic
Thats exactly how you do it:) Some times it doesnt matter what you do, you will get strange resonances. Careful EQ is the best way to tone it down. Some guitars will present boominess on certain notes, thats just the way they are. Acoustics rely on this boominess to some degree. Good luck and happy recording. :) Happy to talk more to you about it.
regards
robotek
Oct 31, 2008 | Audio Technica Audio-Technica AT2020...
Subs stop in middle of songs with deep base
may be the inpedance is too low , poor current...i try to change a wire alimentation for one of number 4 ...and screwed gnd! gd look!!
Mar 16, 2007 | Pioneer TS-W256C Car Subwoofer
32 people viewed this question
 Grubhead
Grubhead
