Where does wiring go on a two wire system red and white
    Problem Solver:
  • 16 Answers
Red goes to the t-stat RH and white goes to W for heat furnace. If it as A/C unit Red goes to one of the wires at the condensor(pick one) and the other side to Y at the t-stat, White goes to the other at the condensor, and the other side goes to Common at the air handler or where ever your common is.
Posted on Nov 06, 2010
Does anyone have an audio system wiring schematics for a '02 montero sport with an infinity amp? color code?
http://www.the12volt.com/installbay/stereodetail/1582.html
This is the best I could find. Hope it helps.
May 04, 2011 | Car Audio & Video
I am installing a stereo in my car and the previous owner cut the wires and the labels are gone. The stereo I am installing has 4 wires other than the speaker wires. They are: +Battery(Yellow), ACC (Red),...
Here you go.
Radio Side -- Car side
12v (Yellow) -- Orange/Black
ACC (Red) -- White/Black
Ground (Black) -- Black or chassis ground(bare Metal)
Pwr Ant (Blue/white) -- Pink
If your not adding and amplifier than your system remote should be used for power antenna which is the pink.
Hopefully this helps
Please Vote & Rate thx
Mar 08, 2010 | Pioneer 50W x 4 MOSFET Apple iPod...
Have a wiring harness for a CQ-C8100U panasonic CD Player/Head Unit, need a wiring diagram to hook it up to a 2002 Ford Explorer Sport 2 Door
Hello! Since I do not know if your vehicle is equipped with the Standard or Premium System I'll give both sets of wiring...You can identify which system you have by looking at the color of the ground wire...
Red=Standard and Black/Green =Premium
Standard...Constant +12=Green/Yellow...
Switched=Yellow/Black...Ground=Red...
Illumination=Blue/Red...
Standard Speaker
FR + White
FR - Green/Orange
FL + Orange/Green
FL - Light Blue/White
RR + Orange/Red
RR - Black/White
RL + Pink/Green
RL - Pink/Blue
Premium...Only power difference is Ground=Black/Green
Premium Speaker
FR+ White/Red
FR- Brown
FL+ Green
FL- White/Orange
RR+ Purple/White
RR- Blue
RL+ Blue/Black
RL- Yellow
Guru.....saailer
I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
Feb 18, 2010 | Panasonic CQ-C8100U CD Player
Micromark wiring diagram
hi have the same issue found it to be red power black negative yellow video white audio and bare wire is the shared ground for the yellow and white hope this helps
Feb 09, 2010 | Swann Communications DVR4-Pro-Net...
I had an old two wire system, red and white. gas
Check for a bad thermostat and wire by jumping the red and white wire together at the thermostat. If the unit fires, you have a bad thermostat. If it does not, jump the R and W terminals at the furnace (or where ever the thermostat wires are connected to). If the unit fires you have a bad wire. If it still does not fire, you have an issue with the heating system not the thermostat or its wires.
Dec 06, 2009 | Honeywell Focus 6300B 5-2 Days...
What color is the power wire in 1994 toyota pick up
this might help
1994 Toyota Pickup Car Security Wiring Diagram
Battery Constant 12v+ Positive Wire (+): White And White/Red
Battery Constant 12v+ Positive Wire Location: Ignition Switch Harness
Starter Positive Wire (+): Black
Starter Positive Wire Location: Ignition Switch Harness
Ignition Positive Wire (+): Black/Yellow
Ignition Positive Wire Location: Ignition Switch Harness
Second Ignition Positive Wire (+): Black/Yellow Or Black/Red
Second Ignition Positive Wire Location: Ignition Switch Harness
Accessory Positive Wire (+): Blue/Red
Accessory Positive Wire Location: Ignition Switch Harness
Parking Light Negative Wire (-): Red/Black
Parking Light Negative Wire Location: At Steering Column Harness
Parking Light Positive Wire (+): Green
Parking Light Positive Wire Location: In Drivers Kick Panel
Power Door Lock Negative Wire (-): Blue/White
Power Door Lock Negative Wire Location: At Door Control Relay. The door control relay, is located behind the driver dash speaker.
Power Door Unlock Negative Wire (-): Blue/Yellow
Power Door Unlock Negative Wire Location: At Door Control Relay. The door control relay, is located behind the driver dash speaker.
Door Trigger Negative Wire (-): Black/White Or Black
Door Trigger Negative Wire Location: At 2-Pin Plug, Top Of Fusebox
Domelight Supervision Wire: Use Door Trigger, Requires Relay
Domelight Supervision Wire Location: N/A
Horn Negative Wire (-): Green/Red
Horn Negative Wire Location: At Steering Column Harness
Tachometer Wire Negative Wire (-): Black
Tachometer Wire Negative Wire Location: At Diagnostic Connector. The diagnostic connector, is located on the passenger inner fender near the fuse/relay box.
Brake Light Positive Wire (+): Green/White
Brake Light Positive Wire Location: At Switch Above Brake Pedal
Factory Alarm Disarm Wire (-): N/A
Factory Alarm Disarm Wire Location: N/A
Factory Anti-Theft System: N/A
Factory Anti-Theft System Location: N/A
Nov 29, 2009 | 1994 Toyota Pickup
Need a wiring diagram for the audio system in a 2002 Holden tf Rodeo???
Car Radio Battery Constant 12v+ Wire: Red/White
Car Radio Accessory Switched 12v+ Wire: Red/Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Red/Green
Car Stereo Dimmer Wire: Red/Yellow
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 5 1/4′
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Blue
Left Front Speaker Negative Wire (-): Yellow
Right Front Speaker Positive Wire (+): Green
Right Front Speaker Negative Wire (-): Gray
Car Audio Rear Speakers Size: 4′
Car Audio Rear Speakers Location: Roof Mount
Left Rear Speaker Positive Wire (+): Orange
Left Rear Speaker Negative Wire (-): White
Right Rear Speaker Positive Wire (+): Orange/Blue
Right Rear Speaker Negative Wire (-): Orange/White
should be the one
Oct 21, 2009 | 2002 Isuzu Rodeo
Ok, here is a list of the factory wires coming from the car that I have for hooking up a radio and there colors. Red wire with blue stripe, red wire with yellow stripe, brown wire with white stripe, brown...
Hello jlharris28, Here's the color code for the '92 Sentra: Radio Constant 12V+ Wire: Red/Black Radio Switched 12V+ Wire: Blue Radio Ground Wire: Chassis Radio Illumination Wire: Red/Blue Radio Dimmer Wire: Red/Yellow Radio Antenna Trigger Wire: N/A Radio Amp Trigger Wire: N/A Front Speakers Size: 5 1/4′ Front Speakers Location: Doors Left Front Speaker Wire (+): Blue/White Left Front Speaker Wire (-): Blue/Yellow Right Front Speaker Wire (+): Brown Right Front Speaker Wire (-): Brown/White Rear Speakers Size: 6 1/2′ Rear Speakers Location: Rear Deck Left Rear Speaker Wire (+): Red Left Rear Speaker Wire (-): Green Right Rear Speaker Wire (+): Blue Right Rear Speaker Wire (-): Pink It's better to use an aftermarket wiring harness that plug into the vehicle wiring. The Metra part number 70-1763 seems to be the correct one for your vehicle. Hope this helps.
Aug 12, 2009 | Car Audio & Video
Wiring diagram for audio system replacement? First time replacing a car audio system. I'm OK with wires connections but color codes does'nt match at all.... No diagram found in manual nether on actual...
2003 Mitsubishi Galant Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Red/Black
Car Radio Switched 12v+ Wire: Blue
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: Green/White
Car Stereo Dimmer Wire: Black/Yellow
Car Stereo Antenna Trigger: N/A
Front Speakers Size: N/A
Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): White/Blue
Left Front Speaker Negative Wire (-): Black/Blue
Right Front Speaker Positive Wire (+): White/Red
Right Front Speaker Negative Wire (-): Black/Red
Rear Speakers Size: N/A
Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Yellow/Blue
Left Rear Speaker Negative Wire (-): Gray/Blue
Right Rear Speaker Positive Wire (+): Yellow/Red
Right Rear Speaker Negative Wire (-): Gray/Red
pls rate
Mar 15, 2009 | 2003 Mitsubishi Galant
Trying to install 3 way cord with a 4 way replacement cord. I have disconnected all wires and put them back. My question is concerning the white wire.The wires that are already connected to the dryer red,...
In a three wire system you have 2 hot wires (black and red) and a neutral (white). the ground is connected to the neutral at the dryer. In a 4 wire system you have the 2 hot wires, neutral, and a ground. (green). The ground is connected with the neutral at the circuit panel. The hot wires at the dryer should be on the outside scres, the neutral should be in the center and the ground should be under the green screw. *****. .
Sep 23, 2008 | Dryers
Heating & Cooling Logo
24 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Donni Steen
Marvin
Marvin
