Question about Sony MFM-HT75W 17 in. HD-Ready LCD Television
My Sony MFM-HT75W TV has a blank screen after 2-3 seconds. It is connected to a digi box via cables and scart pin
4 Suggested Answers
SOURCE: Does Sony MFM-HT75W LCD TV need a HD converter?
Sony style has an e-support system that provided the information I needed. It was obviously FREE!
Posted on Nov 23, 2008
atvc
SOURCE: User Manual download download required please, I have tried many sites, no luck
here is a link to Operating Instructions
Posted on May 07, 2009
SOURCE: droped my Sony MFM-HT95 19 in. TV
Hi Leonardzap
Can you advise if you found a solution to this problem as I too have this screen and it is cracked
thanks
Posted on Dec 20, 2010
How can I set up a Bush Digi Box with 2 scart sockets to a Sony combined DVD & Videao Recorder with 2 scarts to a Sony TV with 3 scarts
Bush Digi box - 'TV' SCART to TV
Bush Digi box - 'VCR' SCART to DVD/Video recorder 'TV' SCART
The digibox will pass through when the DVD/VCR is playing.
Aug 30, 2014 | Televison & Video
Cannot get vcr working so maybe I am connecting it wrong, please help. thanks
with a scart lead Connect the VCR's Scat (TV OUT PUT) to The TV's Scart ( IN PUT) Port 1 or 2 it doesn't matter which one, then take your aerial cable coming in from the roof & put it in your digi box(ANTENNA IN) Then a cable from (TV OUT ) on digi box in to(ANTENNA IN) on VCR or from digi box out to the VCR's SCAT IN with a scart lead.
Mar 31, 2011 | Televison & Video
Sony tv mfm ht75w tv doesn't stay on, works for 10min sometimes,, other times only sec. i opened it all the caps seem ok, any ideas
Please clarify whether the entire tv powers off or only the screen turns off and you can hear the sound so that we can continue with the diagnosis. Sony LCDs are notorious for backlight inverter failures.
May 06, 2010 | Televison & Video
How do you set up digi box with VHS recorderand Tv. Digi box has two scart leads
Take one scart from the digi-box & connect the other end to the TV, & the second scart on the digi-box can connect to the VCR. To record from the digi-box, the VCR must be set to the AUX input (or AV ). The TV will also be set to the AV input, this set up will let you watch digital channels & to record a digital source. Be aware depending on your type of digi-box, you may not be able to record & watch two different digital channels at the same time.
Oct 14, 2009 | Electronics - Others
Equipment and Locations (Denons are physically 15ft apart) Room 1 Sky Plus Satellite Digibox; (without HDMI outlet), but with one optical, one scart-video, and two Scart outlets. Panasonic DMR-EX77EB DVD...
Hi Martin,
A wiring Schematic is not that you should be looking. What you need is large feeders to understand hot to connect to various ports to give your desired output.
Jul 03, 2009 | Denon Audio Players & Recorders
Sony mfm-ht75w no speaker sound when in computer mode
go into your computer and find the speaker control
it may be turned off or reseted
Jan 31, 2009 | Labtec LCS 1040 Computer Speakers
Nov 22, 2008 | Sony MFM-HT75W 17 in. HD-Ready LCD...
DVD recording.
Sounds like the DVDR is recording from the digi-box through the TV, so when the TV is switched of or into standby the signal is lost, causing the recorder to pause.
Assuming the digi-box has two scart sockets, connect as follows:
  • Scart 1 or TV scart of the digi-box to the TV.
  • Scart 2 or VCR/DVD scart of the digi-box to scart 1 of the DVDR3380.
The TV aerial should already be connected through the digi-box and DVDR3380 to the TV
To record from the digi-box, select AV1 / E1 / EXT1 on the DVDR3380
Feb 05, 2008 | Philips DVDR3380/05 DVD Recorder
Can't tune stations from freeview box to DVDR3380/5
You can only record freeview channels through your box.
If you are doing timer recordings, you will also need to leave the freeview box on the channel you wish to record, or set the freeview box timer.
Dec 15, 2007 | Philips DVDR3380/05 DVD Recorder
Sony MFM-HT75W 17in Multifunction Display
Hi, I was able to fix my set by changing only three out of the six capacitors between the heat sinks opposite the plug on the board. I noticed under a microscope the caps looked a little puffy, but not much, and I checked them with a capacitance meter, but they were in tolerance, but decided to change the three closes to the edge of the board with a 1000uf, 50v, 1000uf 25v and 1000uf, 50v with the one that is 25v going in the middle, I didn't have another 1000uf,50v for the middle one. (sometimes you gotta use what you got to get what you want) So I powered my set up and it stays on . I hope this helps. I may go back and replace all six with 1000uf, 50v, but the space in there is limited and those are some large caps. I will wait until the set acts up again before i do that. I am satisfied with it for now. Again I hope this will help with what you've got going on with yours.10_25_2011_8_27_53_pm.jpg
Nov 26, 2007 | Labtec LCS 1040 Computer Speakers
Sony MFM-HT75W 17 in. HD-Ready LCD Television Logo
97 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
