Question about Royal 15MX Shredder
My paper shredder, Royal 15 mx does not go in reverse. Opened unit and know circuit is getting power since led light goes on. I believe the issue is with the circuit board which is not acting as a controlling device just acting as a power supply. Where can I buy the circuit board only to replace it? I looked at Royal website and see nothing relating to parts. I could repair the circuit board, but, need an electrical schematic of circuit board which can show me components used as well as test points. Do you know where to get the schematic for it? Thank you!
    Genius:
  • 1,218 Answers
Dont know if even Royal will have a schematic for the PCB,...most of these are "replace/throw away" pcb's in consumer machines...anyway you can contact Royal at 1-800-524-0799 and see what they say.
Posted on Nov 08, 2010
I have a Royal CX 66 Crosscut shredder and attempted to shred 10 pages. The unit shredded 1/2 of the papers and the other 1/2 are stuck in the shredder; the reverse mode will not release the papers. Is...
The Royal cx-6 shredder is a small consumer shredder rated for "up to 6 sheets at a time" so yes it will jam with anything more that 6.
If running it in reverse won't work you will have to try to open it up and see if you can manually turn things to get the paper back out...there is no other way if it wont run in reverse...hopefully when you have the paper removed the machine will still function.
Oct 27, 2010 | Royal CX6 CrossCut Shredder
Our Royal 15 mx cross cut shredder will back out material, but there is no green light and no ability to feed in paper. Is this a gearbox problem? Is there anything we can do? Nothing appears to be stuck...
Does it sound like the motor is running forward or is it just "dead" when you try to shred paper..... if the motor is running.....then its a gear...but most likely you have lost the pcb in the machine...give Royal a call at 1-800-524-0799 for info on parts and prices.
Jul 22, 2010 | Royal 15MX Shredder
Royal 85x crosscut shredder stopped working
Some shredders aren't designed to shred anything more than paper. Credit cards, staples, paper clips and the like could have jammed it up. Try running the shredder in reverse and oiling the blades. More help with paper shredder oil here: http://hubpages.com/hub/Paper-Shredder-Oil
If you can't get the paper shredder up and running, it looks like you might have to pick up a new paper shredder. Paper shredders can be pretty cheap though, great guide to cheap paper shredders here: http://hubpages.com/hub/Best-Paper-Shredders
May 25, 2010 | Royal 85X Shredder
Royal 15mx only works in reverse after clearing jammed paper
try resetting the shreddar, unplugging it waiting for about 20 seconds and then plugging back in. Check to make sure there is no paper or paper clips stuck in the shreddar, make sure the unit is properly mounted on bin, the overheat light isn't on is it? if none of this helps and you have a warranty on your shreddar now would be a good time ot call them as you might have a hardware problem.
Apr 15, 2009 | Royal 15MX Shredder
Red overload light is on
Try pouring some shredder oil into the throat where you normally insert the paper and run the machine in reverse.Put machine back into ready condition.
Put a piece of paper in the throat just enough so the machine should run but not all the way in so that the cutting mechanism catches the paper...all you want to do is make the machine run forwards but not actually be feeding in any paper.
If it wont even run in the forward direction you may have a pcb prob...give Royal a call at 1-800-524-0799 for parts assistance.
Jan 08, 2009 | Royal VF1012mx Shredder
Model 12x royal paper shreddewill run in reversre but not forward
move the control button on top of the shredder to the oppoiste direction.
Nov 28, 2008 | Royal CIA 12X Shredder
Royal 15MX Shredder Logo
337 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Marvin
Marvin
Ed
Ed
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
