Question about Sewing Machines
Thread tension dial has come off - Janome Combi 10
I've foolishly taken the tread tension dial off my machine, and now I can't get it back on!
I've included a picture of the parts that came off.
  • Marilyn Jones Dec 14, 2008
    The tension knob came off (with all the other parts) and I don't know how to put it back together.
  • aimun
    aimun Jun 10, 2014
    i have same knob parts and i fix them in given manner....try this it works!!!
    New Friend:
If you put a number in your picture like this
1 2 3 4
5 6 7 8
9 10 11 12
Its easy but you must do it exactly like what i say
A - put (1) into the handle so that the pitch goes in to the gear of the handle -make sure that (1) goes in to the handle like this shape 9
after instalation of this "check spring" , u need to bend twist it clockwise little bit so that u improvise the spring in its place (approximately 45 degree)
from now u need to hold the (1) with something so that doesnt move (screw driver or long needle )
B - (12) while u hold the "check spring" with needle , u need to open up its legs so that number (12) which is callled thread controler ( because im not familiar with terms so i explain- haha - it has two Rod, small and large Rod) small rod must go into the hole
c - (10) while u hold the "check spring" with needle , u need to open up its legs so that number (10) it goes through the handle - make sure its top hole goes into the black rod which comes out of the sweing machine - note that u must embed it in the manner that bigger peripheral put in the right hand side.
d - (5) while u hold the "check spring" with needle , u need to open up its legs so that number (5disk) goes through the handle
e - (6) while u hold the "check spring" with needle , u need to open up its legs so that number (6disk) goes through the handle
f - (11) while u hold the "check spring" with needle , u need to open up its legs so that number (11) goes through the handle
g - (9) while u hold the "check spring" with needle , u need to open up its legs so that number (9) goes through the handle - make sure its top half circle hole goes through the black rod which came out from the sewing machine.
h - (7) here you dont need to open the check spring needle . so release its leg and put the plastic male into the handle while males go in to the hole of (9)
I - (2)
J - (3)
K - (8)
ll - (4)
Done. Great Is The Lord
Posted on Mar 17, 2015
  • Jawad
    Jawad Nov 01, 2015
    I had same problem... Got fixed... Thanks Hoseni
  • 323 Answers
I would look for a dealer who has been working on machines for about 20 years and ask him to reassemble everything. I think it is going to be hard to find a tension assembly for this specialty New Home Janome Combi. It's not that hard to reassemble everything when all your parts are in your hand. Of course, once everything is reassembled your tension will need to be recalibrated.
Why did you disassemble this part? It's possible you may need a service to make the machine work properly and the dealer I described to you earlier should be considered. Talk to your friends and see how they have been treated by this dealer and if they were happy with the work that was done.
Posted on Jun 18, 2008
Go to for a picture of the assembly.
Posted on Sep 05, 2008
    Problem Solver:
  • 7 Answers
Buy a new tention dial they are very hard to get to work right after being taken apart...I know because I had to replace them on several machine that I fixed for my customers
Posted on Jun 17, 2008
Janome one step Despite altering the tension dial the top thread is looping on underside of material and when pressing the reverse button material puckers.I tried adjusting the tension dial from 0-9
Usually, this occurs because the top thread is not fully seated in the tension disk.
Remove the top thread from the machine.
ALWAYS RAISE the presser foot and rethread from the beginning.
Reset your top tension to the midway point and then tweak it.
What causes Bird Nests Superior Threads
Birds nest under the fabric big loops of thread top side looks good...
Jun 07, 2017 | Janome Sewing Machines
The bobbin thread is pulling on my janome combi 10
The bobbin tension could be too tight or the bobbin may not be installed and threaded correctly in the bobbin case.
Understanding Thread Tension Threads
May 13, 2017 | Janome Sewing Machines
My janome 1600p db tension is to tight even on the low number on dial
check again how it is threaded as the thread can get behind the tension plates and jam around the threaded bolt mostly unnoticed during the process
Oct 03, 2016 | Janome Sewing Machines
My memory craft 350e won't keep the tension tight. What can I do to fix this? Please help.
Balancing Thread Tension - Janome MEMORY CRAFT ... > ... > MEMORY CRAFT 4900 QC > User manual
Janome MEMORY CRAFT 4900 QC Manual Online: Balancing Thread ... Auto-threadtension When the thread tension dial is set at AUTO for ... to increase the threadtension. ... Sewing Machine Janome Memory Craft 350e Instruction Book.
Sep 19, 2015 | Sewing Machines
How do I clean thread tension plates ?
you can try cleaning them with thread or unwaxed dental floss
and maybe a can of computer air and if that doesn't help then it
would be a good idea to have the machine checked to see if the tension dial needs to be replaced.
Feb 08, 2013 | Janome 6019QC Mechanical Sewing Machine
How to fix the tension on a memory craft 8000-way too loose at the top
it's possible that the tension dial has gone bad & needs to be replaced
at a sewing machine repair shop
Feb 27, 2012 | Janome Sewing Machines
Tension dial on my sewing machine is not working
Hi, Liz. When you adjust your tension, be sure the pressure foot is down. The pressure foot needs to be up when you thread the machine so the thread will slip easily between the tension disks, but when you adjust the tension the disks have to be tight (pressure foot down).
There are other possibilities, but this is the best place to start running the problem down. Please let me know if this does the trick, ok, and if not, we can try something ele.
Happy Sewing
Apr 01, 2010 | Janome Harmony 2039 Mechanical Sewing...
Top tread bird nesting.
When you say top thread nesting, I supose you mean that the thread is messed up at the top of the needle plate.
If so,
1st, either your bobbin thread is completely loose, or the bobbin thread is not held under the bobbin case spring,
or lint has been accumulated under the bobbin case spring.
2nd, the top thread is very tight,
or both.
Jun 10, 2008 | Janome Sewing Machines
Thread tension dial
Hi , the two washer are assemble the curve should be back each other , first put a piece of thin tosser like a small nail put spacer can struck the tosser ,put washer back to back cone retainer next spring next cover with number indicating tensioner of thread next the knob.Put the tread between two cuve for enough tension.
Feb 22, 2008 | Euro-Pro Dressmaker 998B
Tension Problems with Janome DC3050
If your machine is binding. It sounds like you have a threading problem. Check your manual and rethread the machine. The A is for Automatic tension I would not change that. I would also notify your dealer and see if you have thread under the bobbin case. All sewing machines should be serviced each year.
Dec 13, 2007 | Sewing Machines
Sewing Machines Logo
1,873 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
