Question about Frigidaire Washing Machines
I just got a Frigidaire Affinity 6700 front-load washer. If I put in anything less than a full load, it briefly adds water, then spins intermittently (in one direction only), then after a couple of minutes goes to pause, and if I don't do anything will eventually turn off. I read somewhere to push the start and cancel buttons simultaneously, and when I do I get "E11". If I press the start button again, it fills with considerably more water, and then seems to finish the cycle normally. What's up with this?
  • edsgt Jun 15, 2008
    Thanks. After re-reading the manual and doing some more loads, I think it's just a matter of getting used to how my new washer works. Subsequent loads have worked fine.
  • 1,036 Answers
Hi there!
It's possible that this is part of the normal wash program for this machine.
Have a read of the user maunal about washing small items or half loads.
If it does not work acording to the manual. You should still be covered under the warranty.
Read this carefully, and contact the supplier or the manufacturer for the next step.
They may arrange a delivery of a new unit, or send a technician to repair it free of charge.
If you have any problems with this, contact me again and I will try to assist further.
If you resolve this problem, please take a moment to rate this advice - Fixya being advice that lead to a solution.
Thank you for using Fixya!
Posted on Jun 15, 2008
Frigidaire Affinity Glacier Stackable upright washer. Washer will not agitate and makes a buzzing sound from the pump that extracts water from the drum. Water collects and remains in bottom of washer.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
Aug 29, 2010 | Frigidaire Affinity ATF6000ES 3.5 Cu. Ft....
Fridgidare affinity washer will not spin, makes a growling noise
use a shop vac and attach it to the end of the drain hose remove all the water then you need to check the drain pump and see if there is anything blocking the pump.
Sep 27, 2009 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire affinity front load washer doesn't start
mabye there is something keepin the door open, thats usually why most washers dont start
May 11, 2009 | Frigidaire Affinity ATF6000ES 3.5 Cu. Ft....
Affinity front load washer
my front load washer won't spin water out
Jan 21, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire affinity king-size capacity washer
my washer is not spinning the water out.what could be the problem?
Sep 23, 2007 | Frigidaire ATF6000ES Front Load Washer
Washing Machines Logo
182 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
