Question about Flotec 14 Horsepower Portable Utility Pump
FPOS1800A can this pump run continuously? - Flotec 14 Horsepower Portable Utility Pump
  • 565 Answers
The FPOS1800A is listed for continuous duty: http://www.surpluscenter.com/pages/Catalog283-171.pdf
Posted on Nov 08, 2010
Where is this adjustment on the flotec laundry pump
Owner's Manuals - Flotec Pump
www.flotecpump.com > Flotec Resources
Are you having a hard time locating a hard copy of your owner's manual? No sweat. We've got it right here. 4" Submersible Pumps. FP3222 ' FP3232 ' FP3212 ...
Jul 26, 2014 | Flotec Fpos1800a 1/4hp Sump Pump
Where is this adjustment on the flotec laundry pump?
I figure that the air pocket activates the pump when it is in the up position.
Odes dominator 800
Turn key and Yes pump should run then shut off.The only time i've seen new pumps continue to burn out is if All(maybe more than one) fuel filters are not replaced.Hope this helped.Richard
Apr 28, 2014 | Computers & Internet
I have an 05 beetle 1.8 turbo the electric air injection pump continues running continues running and drains the battery
Remove and replace the fuel pump relay.
The electrical terminals inside the fuel pump relay are fuel.
Replace it before causing damage to fuel pump.
Jan 15, 2014 | 2005 Volkswagen New Beetle
2005 V-6 mustang , fuel pump will not run
it's designed to only run until it builds a specific pressure. once the pressure is reached it turns off. if the car isn't running and you suspect the fuel pump drop the tank take the fuel pump out. use two pieces of wire and hook it straight to the battery and see if it continues to run. if it run continuously thats is not your problem as it will continue to run trying to build up pressure but it won't be able to considering it's not in an air tight system
Jul 16, 2012 | Ford Mustang Cars & Trucks
My dog chewed the power cord off my FPOS1800A-08 submersible pump, From whom do I order a new cord.
After searching, a clear answer was found ... if the cord replacement exists, it costs a lot.
Flotec has a contact-us form that requires your personal information
http://www.flotecpump.com/
That being said, flotec FPOS thermoplastic sump pumps have pdf parts list.
Parts list shows cord as replacement part.
However, I don't see the FPOS1800 listed
http://www.flotecpump.com/pdf/FP0S6000A_08ReplacementParts.pdf
Flotec sell sheet shows FPOS1800 but does not show parts
http://www.flotecpump.com/pdf/Pg_6_2006.pdf
Website below sells flotec parts
http://www.pumpagents.com/FlotecPumps/flotec-pump-part-list.html
Random cordset price-check shows $46 for a cord
Another cord was $80
Another cord was unknown
Nov 14, 2010 | Flotec FP0S2400A-03 1/3 HP 2,500 GPH...
The fuel pump dont stop
Hi! The fuel pump is designed to run continuously as long as the ECM receives data that the engine is running. Excess fuel is passed back to the fuel tank.
The fuel pump is also designed to power up for 2-5 seconds when the ignition is turned to "RUN" to pressurize the fuel rail.
If your fuel pump runs continuously when the car is turned off, it may be a "stuck" fuel pump relay.
Oct 29, 2010 | 1994 Chevrolet Cavalier
Bosch SHX46A02UC-21
float switch is in the flood position and the drain pump is running.. there is water under the dishwasher or that switch is stuck up..
Aug 19, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Pump continuing to run -Asko D3100
Micro switch was actually faulty,moisture had entered the switch and caused internal tracking and shorting out the micro switch ,making the pump run continually as it thought it was still in flood mode.
Flood appears to have been caused by a pin hole in the water fill hose in the base of the dishwasher,causing water to spray on the micro switch and eventually biuld up in the base of the machine.
Aug 05, 2008 | Dishwashers
Flotec 14 Horsepower Portable Utility Pump Logo
107 people viewed this question
Top Flotec Garden Experts
Jay Finke
Jay Finke
Mike Raino
Level 1 Expert
Ryan Ross
Level 1 Expert
Are you a Flotec Garden Expert? Answer questions, earn points and help others
