Question about Singer 1507
My Handwheel will not turn towards me only turn backwards and makes a clicking noise when it does. What is wrong and how do I fix it?
    Genius:
  • 1,788 Answers
You should take it in for service because it may be your timing. If, it is new it probably will not cost you anything. Turning the handwheel away from you will definately mess up the timing.
Posted on Nov 12, 2010
My bobbin theses is not getting picked up by the the needle, I tried opening the bottom, nothing wrong. I didn't use my new sewing machine for over a year. Before that I used it twice.
The bobbin may be in backwards
the needle is not the correct one for the machine
the needle isn't correctly seated in the needle clamp
the machine is a little bit out of time.
Remember to hang on to the needle thread when you're trying to pick up the bobbin thread
Turn the handwheel in the direction that would advance the fabric from the front to the back of the machine
make sure the bobbin-winding spindle has been pushed back to the left for sewing
make sure your needle is inserted correctly as far as it will go with the flat side facing back
and that the upper tension disks of your machine are threaded correctly.
Make sure the presser foot is up when seating the thread through the upper tension.
Turn the hand wheel (TOWARDS YOU ONLY) never turn the hand wheel away from you and hold the needle thread lightly. .
pull the loop up and then pull both threads (top and bobbin) under the foot and toward the back of the machine.
Also could be a timing problem
Mar 13, 2016 | Sewing Machines
How do I get the needle back to the stop position?
Charolette, Re POST , make, model #, and complete question and we may be able to find you a Manuel for your reference.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Mar 05, 2016 | Sewing Machines
Janome hello kitty 525 won't feed fabric or needle does not move up and down. Everything seem to be thread correctly and clean.
Hi Thi: make sure the machine is not set to wind the bobbin. Turn the handwheel towards you and see if the needle moves. You may have a belt that has come off. Does the machine make noise like the motor is running when you press the foot control?
Sep 02, 2013 | Janome Sewing Machines
Tesco ej09 sewing machine - handwheel wont turn
I actually had the same problem, it turned out that after threading a bobbin I'd forgot to slide the bobbin holder back into place (just push it to the left) Hope this helps
Apr 14, 2012 | Sewing Machines
Threading a needle
1. Turn handwheel toward you 2. Raise presser foot up 3. Pull thread from spool and pull taut under each tension disk. It's important to "feel" the "click" if you are new to threading machine 4.Make sure after all tension disks threaded that you put thread behind the slot in back of your needle. It's a little groove to hold thread securely. 5. Pull thread toward you 6. Thread needle eye front to back 7. Pick up thread under gently pull taut in front of you 8. Lower presser foot and turn handwheel toward you. A loop will form under the needle where needle thread has picked up the bobbin thread. Carefully take both threads that have made a single loop and pull toward you 9. Put threads under presser foot just lift put threads under and pull 5 -6 inches thread BACK and UNDER that presser foot Done! Hope this helps, my friend! Jimmy
Mar 30, 2012 | Sewing Machines
Sewing machine handwheel turns and whirrs but needle bar stuck?
my suggestion is that the machine needs to be serviced at a sewing machine shop, because for 1.it's not responding 2. it used & you don't know when the last time it was serviced 3.something is wrong with the machine.
hopefully there are no broken parts, but having the machine serviced will tell that.
as for a manual
Go to the singer website
Go to the home page
Go to customer service--click on it--it will show a small menu--click on instruction manual
In the box put the model number (example w510 ) & click search
Mar 18, 2012 | White Sewing Sewing Machines
Bernina 140 which has a sqeak in its Handwheel How do I fix it
it's sounds like the machine needs to be serviced when they start sqeaking or making odd noises
Mar 06, 2012 | Bernina Activa 140
I can hear a clicking when serging
Sounds like your looper timing is off. you will have to have your local shop re-time it. Find a shop that gives free estimates first.
Hope that helps,
-Chris
Jun 06, 2010 | Janome 7034D Sewing Machine
I can't get the needle to pick up the thread from bobbin why not?
Take the thread out of the machine.
Make sure that a new needle is inserted properly; this is critical.
Place the presser foot up and turn the handwheel towards you until the take-up lever is at its highest position.
Thread the machine.
Always turn the handwheel towards you. If you look at it from the right side it should turn counter-clockwise.
If it still doesn't pick up the bobbin, reply.
Jul 24, 2009 | Juki Sewing Machines
Not making stitch
a.gif Dear Joan,
On the top of the machine there is a button. Push the button while turning the handwheel toward you. When the button drops into the machine, you are ready to adjust the length. Keep holding the button in the machine and turn the handwheel forwards or backwards, noting the numbers on the inside of the handwheel. Turning the handwheel to the back decreases the size of the stitch, and turning the handwheel forward decreases the size of the stitch. Release the button and then begin to s
Apr 09, 2009 | Juki Sewing Machines
Singer 1507 Logo
230 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
