Question about Coleman Propane Grill Stove 9921-700
I don't have an instruction manual for my Coleman grill stove #9921. Is it possible to get one? Thank you.
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 221 Answers
Sure! Go here http://tinyurl.com/28k8shq select the item you are looking for a manual for, enter your model and download a free manual.
Posted on Nov 10, 2010
How do you connect the propane to the stove
Assuming you are referring to the Coleman Campers Grill Stove which is a side by side grill and stove unit than it is a pretty simple set up. All portable Coleman stoves set up basically the same. There should be a arm known as a regulator that came with the stove. The narrow end of this attaches to the right side of the stove and screws in. Then the propane bottle screws into the other larger end. make sure all connections are screwed together tightly. For more clarification check out these instructions:
http://www.ehow.com/how_2106008_use-coleman-stove.html
https://www.youtube.com/watch?v=dbYil-YQ8-Y
Good Luck!
Jul 07, 2014 | Coleman Campers Grill
Coleman 9921 low flame stove
Tony B. s answer gave me the idea to try and spray carburetor cleaner to try and unclog the filter. Worked like a charm. I now have a full flame coming out of both burners.
Apr 10, 2014 | Coleman Propane Grill Stove 9921-700
How do you remove the burner part of a coleman grill/stove? I trying to give it a good clean. I got the 4 screws off and grill fuel bar, but for the of me, how do you remove the burner part. Kelly
The Coleman website has a pretty excellent list of owners manuals. (Here's the link for the 9921A700)
I believe that you unscrew the burner assembly on the right, which will then let you remove the cooktop to clean inside and re-assemble.
This procedure is not listed on the Coleman website or in the owners manual, however it appears to be fairly straightforward. I'd recommend using some teflon tape on the threads when screwing the burner assembly back on.
Aug 18, 2010 | Coleman Propane Grill Stove 9921-700
Coleman propane stove, tank got very cold. why?
as propane is used it can create frost on the tank or just cause the tank to feel cold. this is normal. this will be worse when the tank is almost empty.
May 28, 2010 | Coleman Propane Grill Stove 9921-700
Black is on the burners
the fuel to air mixture is set incorrectlty or your pressure at the ouitlet for the gas valve is too low.
you culd play around adjusting the first part of this but for the gas valve part you have to have a manaometer to check it out correctly. then it should be set at 10"wc. Good Luck
Jan 10, 2009 | Coleman Propane Grill Stove 9921-700
Coleman Propane Stove 2 Burner 5430E700
Ho cold waas it out? remember that when its cold out the presswure of the propane tanks are real low and you have to warm them for the pressure to go up. if your by your car then you can place them inside with the heater going till they warm up ofr now worm them up inside first. good luck
Sep 06, 2008 | Coleman Propane Grill Stove 9921-700
No gas going to grill.
It would appear that your regulator is not working.
Hope this helps ya
Jun 17, 2008 | Coleman Propane Grill Stove 9921-700
Coleman Propane Grill Stove 9921-700 Logo
346 people viewed this question
Top Coleman Grilling Experts
Dan Webster
Dan Webster
Paul Carew
Charles T Nevin
Charles T Nevin
Are you a Coleman Grilling Expert? Answer questions, earn points and help others
