Question about Hitachi 46F500 46" Rear Projection HDTV-Ready Television
Hitachi 46f500 screen messed up after welding on same circuit
I have the 46F500 Hitachi Projection TV. The set has blue sagging down from the left side of screen and also has blue shadows. I removed the back cover to see if anything noticeable stood out. Wow was it dirty? I cleaned it out and noticed that on top of the red lense there is a piece of narrow tape stuck to it. Should it be there? After cleaning no change in picture. I also tried to do manual convergence and the blue lines will not line up on the left side of the screen. Running magic focus in AUTO it would hang up on the blue and end showing a number "5". Any ideas what is wrong? The trouble started after welding on the same circuit. Coincidence?
  • Anonymous Sep 08, 2008
    Same problem but no welding or other activity to trigger it. It just started.
    Any diagrams, plans or links toparts might help... Thanks!
    Novelist:
    Champion:
  • 203 Answers
If you did manual conv. You have to redo it when you replace the bad parts. Them being conv. ic's replace them and check 1/4 watt resistors that are low value right beneath amps. Careful not to solder any foil pads together or you will have major problems. Very common for do-it-yourselfers. Good luck, Russmann.
Posted on Sep 02, 2008
Have a 46f500 hitachi projection television. Started out with a blue reversed arc hanging down on upper right. Now images are not focused, and red, blue and green are layered. Double images. I looked...
It is a convergence problem and set uses two of the STK-392-150 CHIPS. Both will have to be replaced and the set adjusted.
for more information let me know if you can solder and your skill levels.
SD TECH
Jan 11, 2011 | Hitachi 46F500 46" Rear Projection...
Hitachi 46f500 46 in problem double picture end two collor
This is symptom of convergence output chips failure in rear projection tv, replacement of convergence output chips will fix the problem.
Chips/ IC replacement requires soldering work in circuit board, if you are not familiar with electronics stuff fixing an soldering work, call local tv repairman to help you.
Thanks.
Oct 26, 2010 | Hitachi 46F500 46" Rear Projection...
I have a Hitachi 46F500 tv and the red crt bowed
I just had the convergence replaced and have a great picture
Aug 16, 2009 | Hitachi 46F500 46" Rear Projection...
My wife let the Wii remote and broke the front plexi-glass.
You can find a new Hitachi replacement protective screen and screen assembly for a model # 46F500 from a major Hitachi distributor at the following links:
Hitachi 46F500 Replacement Part Screen Assembly
Hitachi 46F500 Replacement Part Protective Screen / Ultra Shield
Feb 03, 2009 | Hitachi 46F500 46" Rear Projection...
Hitachi 46F500
Having yellow and blue shadows outlines show up on picture.
Oct 03, 2008 | Hitachi 46F500 46" Rear Projection...
Hitachi 46f500 convergence?
a common problem wich i also have with convergence with blue and red convergence.
the image converge amplifiers are burnet out wich in turn blow out resisters that control individual color convergence.
Jun 19, 2008 | Hitachi 46F500 46" Rear Projection...
Convergence on Hitachi 46f500
replace convergence IC's,then re-check alignment
Sep 17, 2007 | Hitachi 46F500 46" Rear Projection...
Color convergence?
Can anyone give me the resistor values for location RK 42, RK 46 and RK 62? Hitachi 46F500 TV. Or can I be pointed to the location of a service manual?
Tony
Sep 13, 2007 | Hitachi 46F500 46" Rear Projection...
Hitachi 46F500 46" Rear Projection HDTV-Ready Television Logo
135 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
