Question about Universal Power Group 24V 5A Universal Scooter Power Wheelchair Battery Charger
After a few seconds cooling fan stops and it doesn't charge.
    Novelist:
    Champion:
  • 232 Answers
This usually indicates that the battery is fully charged. Does the indicator light change? Have the batteries been sitting unused for a while? If so, they may have oxidized inside and will no longer take a charge. The charger is indicating they are full, but instead of being full of energy, they are full of crud and need to be replaced.
Posted on Nov 09, 2010
2010 Lincoln MKS Heated Seat on driver's side stopped working (Light in button turns off on its' own)
The most common cause of this problem is that the drivers seat heater grid is open or burned out. That is based on 25 years as a Ford dealer technician.
Feb 27, 2017 | Lincoln Cars & Trucks
Recently I cleaned cooling fan of my Toshiba L300 laptop. When press power button to start, fan runs few seconds and stop. Is his normal or any other problem? I dont know how it work originally before the...
the fan is used to keep the motherboard cool. if the motherboard dosnt reach a high tep the fan will not kick on. it's a good thing. means motherboard is staying cool.
Oct 26, 2013 | Toshiba Satellite A135-S2276 Notebook
Why won't the air conditioner blow air?
The very first thing you need to do is to check for fuses or say faulty fuse. Secondly check fan which starts along with air conditioner, it might be manually switched off or the fan may have been clogged. Also reason can be lack of refrigerant - charge your air conditioner with refrigerant. Last thing you need to check is cooling coil - the cooling coil may freeze if there is no refrigerant in the system.
Jun 11, 2013 | Ford Explorer Cars & Trucks
Battery not charging,cooling blowing fuse
Disconnect the fan motor and see if the fuse still blows, if it doesn't you may have found the problem and the fan needs to be rep[laced a 30 minute job just a few bolts..
Oct 31, 2012 | 1992 Chevrolet Camaro
No Display - Spontaneous Power Cuts
first i hope you didnt get any lubricant on any of the components in the computer.
second, since this i think is a laptop. there is only one fan that covers the processor. if the fan was intermittently working the reason your laptop was turning off and on is because it was overheating. now when you put the graphite spray and fan stopped working a few minutes later. the laptop might have went too long without a fan and toasted your processor.
so my opinion is one of two things could be why your computer no longer works.
oil leaked on to some of components and shorted something out.
or the processor finally overheated from a malfunctioning fan.
i hope im wrong and your pc works again.
good luck
Feb 27, 2017 | Computers & Internet
My cooling fan stop working. The a/c is cold as long as my car is moving. When i am at a red light i can hear the moment when the cooling fan should turn on, but hte fan doesn't turn on and the a/c is...
Hi there, ya that sounds like your fan stopped working. There is a few different things you can check. The fuse for the fans The relay that controls the fans, and the fans themselves. You really should get that checked out, eventually your engine will start to overheat which can lead to major damage. If you dont feel up to do the job yourself any compitant auto shop can check it out for you. Hope that is helpfull.
Aug 17, 2011 | 2003 Saturn ION
The starter on my 1995 saturn sl2 stopped working i can still push start the car but in the same day the heater fan and cooling fan stops working but then starts working again when the fans don't work the...
You have a electrical power shortage, when componets demand power it's not there [ that's why some componets slow or stop working ]. Start by cleaning the battery terminals and testing the battery to see if it holds a proper charge [ after fully charging, let the battery sit for a few hours and check the voltage = it should be at least 12 volts. If not, replace. Then check the output of the charging system = mininum of 13.8 volts to maxinum of 15.3 volts, & up to 78 ampress when @ maxinum charing. Then check the starter draw = should be around 260 amps, if it's higher then 300 amps. then replace.
Feb 21, 2011 | Saturn SL2 Cars & Trucks
Air conditioning system takes a charge, but the
high pressure switch is kicking out on overload, replace it or you might have too much freon
Jun 27, 2010 | 2000 GMC Jimmy
I am having Daewoo refrigerator Model DIR220. When I switch on the refrigerator the compressor starts after about 3minuites and stops in few seconds. fan motor works continuously. As the compressor stops...
the compressor has an internal overload to protect it from overheating. the compressor is cooled by the refrigerant passing over it. It could be a bad compressor,, bad charge of refrigerant, or simply dirty coils not allowing air movement
Nov 26, 2009 | Dehumidifiers
Universal Power Group 24V 5A Universal Scooter Power Wheelchair Battery Charger Logo
113 people viewed this question
Top Universal Power Group Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you an Universal Power Group Health and Beauty Expert? Answer questions, earn points and help others
