Question about Haier Mechanical Air Conditioner HWF05XC7
Haier 5,200 BTU
Doesn't drain, and sounds like fan is smacking a puddle all the time. I have tilted it more and more to try to help the problem, but how far must I go. It's already tilted as far if not farther than all my previous A/C's.
  • pakieser Jun 20, 2008
    Have the same problem, can't find any plugs or drain holes on the unit. I've also tried tilting it but it does not help.
I drilled two 1/8" holes in the back outside corners on the bottom, about 1/2" in from the back. It's safe and you do not hit any inside parts doing this. It allows the water to drain and solves the problem.
Posted on Jun 22, 2008
    Scholar:
  • 149 Answers
There should be a rubber plug on the right hand side from the outside 2 black round " corks" if you see them remove them and your problem should be solved
Posted on Jun 15, 2008
I have a10,000 btu Haier window a/c from walmart ,whenever it rains the insulation that directs the air flow collects water and spits it out into my room. Any advice on this problem?
Andy, from what you have described, it sounds like the drip pan drain under the you is clogged and/or there is not enough downward tilt on the rear of the unit. The general rule of thumb is 1/4" to 1/2" downward tilt. The allows the water to flow to the rear of the unit, where the drain hole is located.
Resolving those two things, should solve the problem. Thanks for choosing FixYa.
Aug 14, 2011 | Haier Heating & Cooling
Does the Haier 5000 btu window unit drain water?
yes they do.. just be certain you keep the filter clean and the unit tilted to theout side about 1 inch or so.. Hope the helps let me know jon
Jul 31, 2011 | Haier hwr10xc6 Air Conditioner
My haier 8,000 btu window unit sounds like the fan is hitting the housing when it is installed in the window. the only way it doesn't hit is if you tilt in inward towards the inside of the windows inside...
Somebody is going to have to adjust the squirrel cage blower to keep it from hitting. This happens in a lot of heat/cool window units. Sorry probably not what you wanted to hear.
Apr 12, 2011 | Haier HWR06XC6 Wall/Window Air Conditioner
I have a Haier 5,200 btu air conditioner that
E-1. Indoor room temp sensor defective. replace it.
Jul 23, 2010 | Haier Energy Star ESA3183 Air Conditioner
When I plug in the unit it trips the reset button every time. Its
This is only a 5,200 BTU unit - for single room use.
If you're sure the voltage ok, it sounds like the unit is new and should be under warranty.
Jul 25, 2009 | Heating & Cooling
Haier 5000 btu thru wall or window vents on top and both sides how far out the window should it be?
just a few inches, main thing is that its slightly tilted at the back to drain the condensated water outside
Jul 23, 2009 | Haier hwr10xc6 Air Conditioner
Air Conditioner will not cool. Only fan lights up
My AC seems to be running but it is not blowing cold air out. What maybe the problem?
Jul 16, 2009 | Dometic Rooftop RV Air Conditioner
My Haier 5,200-BTU Window Air Conditioner keeps freezing up. how do I remedied this?
You need to clean the unit outside(take it out of the window) with a water hose because it is dirty inside( you have to remove screws on cover and take cover off), be sure to cover the electronic control board with plastic so you don't get it wet.Clean fins on front and back with water hose and inside .
Sep 02, 2008 | Haier hwr10xc6 Air Conditioner
Haier Mechanical Air Conditioner HWF05XC7 Logo
375 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Michelle Balcom
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
