Question about General Washing Machines
Model sr2120j water lets out but doesnt spin - General Washing Machines
    Problem Solver:
It sounds like a wire is loose inside the machine itself, and the seal is broken. I would reccomend seeking help for this one unless you know more than most about electrical power.
Posted on Nov 06, 2010
I have a waring pro blender Model WF2111211 It's glass he blade part doesnt come off. motor runs fine but blade really tight won't spin so the motor smells burn out trying to get it to free.
Heat up a cup of water in microwave until boiling in a two cup Pyrex measuring cup. Add one more cup of tap water. Our it in the blender and let it soak. If it doesn't work, repeat but with less tap water.
Sep 15, 2015 | Waring Blenders
When it's time to rinse at the end of the washing all the water s
Please clarify, it doesnt spin, it doesnt pump out the water. it never filled with rinse water. We all need to know more.please. also make and model number would be helpful
Dec 30, 2009 | Washing Machines
Wont spin and drain
What brand is this? If it a whirlpool or kenmore (or roper, estate) It is you lid switch. A very common problem but is cheap and easy to fix. Get me the model number and i can give you the part number for the switch.
Nov 21, 2008 | Washing Machines
Kenmore 70 series
First thing is to remove the 2 screws from the console, they may be hidden in the front or bacl of console. After removing screws, lightly push the base of the console towards the front of the washer and pick up. This will expose your lid switch connection. Using a jumper wire, jump out the black and white wires then try advancing your washer into spin/drain. The culprit will usually be the lid switch assy.
Apr 04, 2008 | Kenmore 24032\24036 Top Load Washer
LTF2140E Front loader washer
My Frigidaire front loader washer model LTF2140E doesnt want to drain the water when set to wash (heavy-normal-quick selectors). It washes put thats it. I have to switch the selector to drain/spin then rinse/spin cycle to finish the load. I checked the drain hose for any clogs....everything is clear. Any suggestions? Also,iIs2.gif their any reset buttons for this type of washer?
Dec 13, 2007 | Frigidaire 24 in. FDB510LC Free-standing...
Maytag jet clean model#dwc7400aaw
Check to see in you have enough water in tank. The dishwasher fills then recirculates this water under pressure. If you have water in tank, listen to see if motor is running or not. If it is, you may have clogged jet holes in the wash arms.
Jul 31, 2007 | Maytag MDB9600A Jetclean II Built-in...
Maytag stacked washer/dryer Model LS7804
OK it may be one of 2 things. I would check the lid switch first. On some maytags the have a lid switch that if it is not working properly it will not let the washer fill. If it will not fill the washer will not wash because the pressure switch did not activate the timer to wash. If the switch checks good you might have a bad timer. If you open the control panel you will find a tech sheet with the wiring diagram. I would follow the fill cycle and check the components. You might also check the water valve to make sure its ok too. But its very rear that both the hot and cold would go at the same time. Good luck!
Jul 11, 2007 | Maytag LSE7806A Top Load Stacked...
Washing Machines Logo
Top General Washing Machines Experts
Dan Webster
Dan Webster
Sal DeAngelo
Chris Goulet
Are you a General Washing Machine Expert? Answer questions, earn points and help others
