Question about Viking 42 in Built In Professional Integrated Side by Side Refrigerator - VISB423
Both Doors have weak seal, alarm is going off
When you shut the refrig door the freezer door disengages a bit, it's still sealed but it's not like it was. When you close the freezer door the frig door disengages a bit. The seal I notice is not as strong, it's now very easy to open the door. Prior to this issue it took an a full grip of the handle to open the frig or freezer. a young child couldn't open it that's how sealed the unit was until now. The unit was new in 2003, and completely overhauled in 2003 due to compressor, and circut board issues, it's been working perfectly since 2004. The alarm has gone off today once, and a few weeks ago once. And now when I inspected the unit closer i noticed the difference in the doors. I also made sure there was nothing blocking the unit from closing.
  • 3 more comments
  • MikiL Jun 15, 2008
    thank you .. I'm going to check the doors, I don't think they are loose
    The seal looks new, is the magnetic seal magnetized metal inside the vinyl? the vinyl seal looks in excellent condition. Is this a common occurrence? Come to think of it when the doors were working properly, it was like a magnet like locking sound the doors made. Do I need to call service? Or is this something I can replace myself.
    okay, thanks.. I'll call Viking
    how do I rate this?? I'm a first time user. Do I hit the Accept button?
    I could not figure out how to rate the solutions. I clicked the button "accept'.. and the rating was added to one of the techs on Fixya, and my frig problem may or may not be fixed. I didn't intend to not rate both answers. My apologies. Both Techs were excellent responders, and gave me great starting advice. Thank you.
  • 1,879 Answers
The magnetic seal around the door lost it's magnetic power.
it needs replacement also.
Posted on Jun 15, 2008
    Master:
  • 638 Answers
PROBLEM WITH THE DOOR ALLIGNMENT
  • 6 more comments
  • hemant somaiya
    hemant somaiya Jun 15, 2008
    MAY BE THE SCREWS HOLDING YOUR DOORS IS LOOSENED UP COMPLETLY ,TIGHTEN THEM TO GET THE DOORS IN THE PROPER POSITION.YOU YOURSELF CAN DO IT . ITS VERY EASY.FEEL FREE FOR FURTHER ASSISTANCE.
    RATE THIS SOLUTION.
  • hemant somaiya
    DO U NEED ANY MORE ASSISTANCE.KEEP ME UPDATED I AM WAITIIING FOR YOUR REPLY.
  • hemant somaiya
    DO U NEED ANY TECNICIAN IN UR AREA FOR SERVICING OR SOME OTHER ASSISTANCE .LET ME KNOW UR ZIPCODE N LOCATION. OR RATE THIS SOLUTION AS FIXYA IF IT HELPS U UNDERSTAND N SOLVE UR PROBLEM.
  • hemant somaiya
    ITS EASY TO REPLACE BUT STILL ITS PREFARABLE TO CALL TECNICIAN IF U DONT HVE A PROPER KNOWLEDGE ABOUT UR UNIT.
  • hemant somaiya
    NOTHING TO WORRY ,UR DOORS WILL BE FINE AT A VERY VERY NEGLIGIBLE COST
  • hemant somaiya
    RATE THIS SOLUTION PLSE
  • hemant somaiya
    YES CLICK FIXYA TO ACCEPT
  • hemant somaiya
    ACEEPT THE PERSONS SOLUTION WHICH U FEEL HAS HELPED U
Refrigerator door seal has gap, and the alarm keeps going off
My refrigerator as delivered had noticeable gaps in the sealing gasket. The solution is to adjust the doors to eliminate the gap. The door hinges allow for adjustment by loosening hardware, adjusting, and tightening hardware again.
Sep 09, 2012 | Samsung Refrigerators
GE GSS25WGMC door open alarm beeps and both doors are OK and seal properly
check to make sure in fridge and freezer there are switches when the door make contact with it it shuts off the lights-check by hand by holding the swiches down and see if the interior lights go off, if not then you have a bad switch..if they go off then the control where the door alarm is located needs to be replaced
Oct 01, 2011 | Refrigerators
How many cu ft is it? need new seal for door hmg241770 admiral refrig
Not sure what the cubic feet for the doors for that refrig. but i have the part#'s for you
Fresh food gasket 61004010
Freezer door gasket 61004011
hope this is your looking for
Gene
Aug 01, 2011 | Kitchen Ranges
Alarm is going off (beeping) - ice accumulating on rear freezer wall.
hi check the doors seals if it closed perfectly and do not open the fridge or freezer door for long time because if you forgot one of the doors open it will make this problem and do not put hot or warm food inside most important to be sure that the seals stuck good when you close the fridge doors.
Sep 11, 2010 | Liebherr Refrigerators
Frigidaire FRT17G4BW9 doors not staying closed
Adjust the front legs of your refrigerator slightly to raise the refrigerator. and and store items on the freezer door shelves to add weight. This is a problem of pneumatics and a testament to how tight newer refrigerators are. When you close the large refrigerator door it compresses the air in the refrigerator compartment. Both compartments are connected by air passages and thus the pressure change is transferred to the freezer causing the freezer door to pop open.
Raising the front of the refrigerator a tiny bit will help both doors close from the 90 degree point, which is desirable. Adding weight to the shelf will just help the process.
An additional aid in self-closure will be to use vegetable oil on a paper towel to wipe down the hinge side face of both door seals. All these maneuvers should aid in causing the door to stay closed and re-close if it should open slightly. Good Luck
Aug 23, 2009 | Frigidaire 20.6 cu. ft. Top Freezer...
Bottom freezer icing up
You need to address the bad magnetic seal on the freezers door. Replace if nessesary. Sometimes a door adjustment (hinges) can improve the seal as well.
Jul 22, 2009 | Refrigerators
Sub-zero 500 series refrigerator door wont stay closed
If Your Refrigerator's Freezer Door Pops Open When You Close the Fresh Food Door... If a 'top-freezer' refrigerator's freezer door pops open when the larger fresh food door's closed, it's actually a good thing. That tells us the seals are in great shape, sealing well.
Some freezer door 'pop' is unavoidable bc the bottom door's so much larger than the top one and the hydraulic effect of compressing all that air kicks in. The two compartments share the same air via a duct between them, and that compressed air rushes up into the freezer compartment and can 'pop' the door.
To improve the situation, apply a few drops of oil (sewing machine oil or 'three in one' - NOT WD-40) to each freezer door hinge pin. (Even better: if you can, pull the doors and coat the hinge pins with petroleum jelly). This will help the freezer door swing back closed by itself. The freezer door usually stays ajar because it's binding a bit, and that's usually caused by it's swinging 'dry', with no lubrication.
It’s also a good idea to ‘kick’ the habit of letting the refrig door close hard.
Sep 04, 2008 | Refrigerators
Freezer will Not Go Below 8 degrees and Alarm keeps sounding
Our manual says it can take our freezer up to 48 hours to get back to the correct temperature. I found that to be the case when we loaded it fully for the first time.
Jun 15, 2008 | Frigidaire Freezers
Freezer door pops open.
normal operation actually, gaskets are designed to seal door closed not to hold them closed, first off check the items on the shelves make sure nothing stick to far out preventing good closing.next the refrig should be tilted slightly back. to aid in the doors swinging closed( the should close automatically form 45 degrees.)ok for them to "pop" open so long as they close back shut. this works on top freezers and bottomr freezer refigs, sidex sides use a differnet system of closing, if htats the case look into replacing door closures(cams) located under hte door assy
Mar 04, 2008 | Refrigerators
REFRIG SIDE NOT COOLING
The sweating inside is from the door not making a proper seal, and you are getting condensation build-up. The door not shutting is not as unusual as you may think. First check the gasket condition, a new one may not be a bad idea. On these refers with the revisable doors, try removing the freezer door and then loosening the fridge door hinges and adjusting the mounts. Its a trial and error procedure so don't get frustrated. Another trick is to wad up a wash cloth into a ball and wedging it into the door gap after you open it on the hinge side, then close the door. You should have some tension, but not too much. This bends the door a little. If you can get the door to make a good seal it should solve the other problems with the temperature. If not, you are going in the right direction by locating and cleaning the vents. All the cool air in the fridge comes from the freezer.
Nov 13, 2007 | Whirlpool ED5SHAXM Side by Side...
Viking 42 in Built In Professional Integrated Side by Side Refrigerator - VISB423 Logo
447 people viewed this question
Top Viking Refrigerators Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Viking Refrigerator Expert? Answer questions, earn points and help others
