Question about LaCie 4big Quadra 4000 GB
I've attempted to change the RAID to Concatation. When I try to reformat with Disk utility, it won't and I get the message "resource busy" I've tried everything I can think of. I don't get an icon on the desktop... george
  • 18 Answers
Does your raid contain partitions from your boot disk? If so you will need to boot from the OS disk or another bootable drive.
Posted on Nov 06, 2010
Unable to format Seagate ST9500423AS
Have you tried reformatting your hard disk? this happened to me when i tried to us PartionMagic tool. my hard disk stopped working tho' it's still showing up when i plug it in another PC. this is how i get it working again:
i plugged my hard drive to another PC and i used DiskPart to clean it and i formatted it in Windows Disk Management.
it worked for me and i doubt, there was an error partitioning my hard disk so i needed to make it fresh again.
Apr 18, 2013 | Seagate 500GB ST9500423AS 7200rpm SATA2...
DV 8408 teardown
Repair a Dead SATA Hard Drive
A SATA hard drive is drive that uses the SATA interface standard when sending information to and from the system memory on the computer. Repairing a dead SATA drive might seem impossible, but you owe it to yourself to at least attempt a drive repair before giving up and purchasing a new hard drive. Accomplish this with the disk repair tools in your computer's operating system.
Click the "Start" menu. Type "cmd" in the "Search" box and press & quot;Enter." Type "chkdsk x: /r", substituting "x" for the letter of the supposedly dead SATA drive. Press "Enter" to run the drive diagnostic and repair utility. The computer will attempt to repair and fix the dead areas on your SATA drive.
http://www.microsoft.com/resources/documentation/windows/xp/all/proddocs/en-us/chkdsk.mspx?mfr=true
Feb 07, 2013 | HP Computers & Internet
External Hard Drive won't format. Should I wipe it and then, try again?
try to format it through the disk management program in the control panel
Feb 07, 2013 | Western Digital Computers & Internet
Non system disk or disk error' 'replace and strike any key when ready' 'Media test failure Check cable' When l performed the Boot Utility test it returned an error message 'f
Sounds like a disk issue. It kind find the OS so it's then trying to PXE boot (boot from the network). Have you changed the boot order recently? or do you have a USB key connected to your server? are you able to connect to the management interface (hp ilo, dell drac) to see if you had any raid or other hardware issues?
Jan 09, 2013 | Computers & Internet
Primary Hard Disk Drive 1 not found
It means your hard drive has probably lost it's boot sector.
What you can do is mount the drive as a slave drive in another system, if it locates it, because then it does not have to mount it as an operating sytem and boot, then you can copy your data from it so as not to lose it.
After that, then try running a diagnostic utility to ensure the drive is not damaged. If it shows the drive as OK to use, then try reformatting it and reinstalling the OS. A complete reformat will then write the correct track zero information to make it bootable again.
Usually however with that error depending on the size and type of drive it is toast and may or may not start a limited number of times to recover data to another drive.
You might also find with some SATA drives - turning the machine off and reseating the connections or cables will cause it to work again as they sometimes partially work loose and then the drive is not mountable.
Dec 26, 2011 | Microsoft Windows XP Home Edition English...
Where can i download raid drivers for my caliber xn9010?
The driver you need is based on your raid controller on your motherboard or if you have one your raid card, so you need to determine the motherboard manufacturer or raid card manufacturer and get the chipset drivers from their website.
djbr1ck
May 12, 2011 | Cybertron Caliber XN9010 Server
I have asus m2n-e board, i used 80 gb hard drive in sata 1 socket, used 4 hard disk of 250GB in from 2-5 ports and used 320 gb hard disk in port 6, configured 4 250gb hard disks in raid 5 using the mother...
USE DIFFERENT PORT FOR PROBLEM OCCURED HARD DRIVE AND CHECK SAME PROBLEM CONING TO THAT PORT ALSO .THEN THE PROBLEM IS WITH YOUR HARD DRIVE .REPLACE IT.
Dec 31, 2008 | ASUS M2N-E Motherboard
LaCie 4big Quadra  4000 GB Logo
218 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
