Question about All-Clad (HCOF8H2MZQ) 65Quart Slow Cooker
All Clad crock pot doesn't get warm enough. I suspect one heater element has failed. How do I take it apart?
I need a manual for an All Clad slow cooker Model #AC-65EB
Do a Google search for your make model and manual and you should get a .pdf of your manual that you can download.
Nov 20, 2014 | Crock Pots & Slow Cookers
All-Clad AC-65EB Slow Cooker Repair parts
Repair parts can be found on amazon, click here and take a look: Amazon com all clad slow cooker. I hope this was helpful. Cheers
Jan 08, 2013 | All-Clad Crock Pots & Slow Cookers
All clad slow cooker won't heat up.
I tried to locate the manual with google, and had luck to find this page, they have the manual!
Enjoy my help.
Sep 20, 2012 | All-Clad (HCOF8H2MZQ) 65Quart Slow Cooker
Rival crock pot smart pot - low, keep warm & hot lights blink and pot will not heat. is there something i can fix or is the pot destined for the garbage truck?
Some times it can be fix wit heat element.The manufacturer may have this part available to buy.Go to the website with your model number.Find it buy it install it do it your self and save.It may need some soldering done,or it may just unplug.Good Luck!
Aug 08, 2010 | Rival 38601 Smart Pot 6-Quart
I just put some precooked, still warm food in my crockpot. I tried to set the control to warm so I could serve later. Can't get warm to turn on. How can I?
To better diagnose your problem I need more information. Does your crockpot have a light that indicates when your heating element is ON? If so, increase the temp of the crock pot knob to find out if the LED light comes on at all. (you may also wish to make sure the unit is plugged in and the outlet is working properly.)
Since all crockpots work using a temp sensor, it could be that the temp of the food is still warm enough that the crockpot thermostat is not calling for additional heat to maintain the temperature. If you can, remove the crockpot liner and let the unit cool somewhat to allow the thermostat to return to room temp and reset.
If this doesnt solve your problem, chances are that the sensor/thermostat may be faulty or one of the circuits to the heating element may have overheated causing a wire to become disconnected or burn out. Appliances can wear out with use or age and even power surges can 'fry' delicate circuitry.
May 18, 2009 | Rival 38601 Smart Pot 6-Quart
Outside of Crock Pot Extremely Hot....Is This Normal?
This is not normal. Thermal switch is not functioning correctly. Wiring inside not easy to replace. Crock pots cause a lot of home fires. Cheaper to simply buy a new one.
Feb 27, 2007 | Rival 3040-VG 4-Quart
All-Clad (HCOF8H2MZQ) 65Quart Slow Cooker Logo
46 people viewed this question
Top All-Clad Crock Pots & Slow Cookers Experts
Irene Tulloch
Tom Chichester
Bill Boyd
Are you an All-Clad Crock Pot and Slow Cooker Expert? Answer questions, earn points and help others
