Question about Classic Accessories QuadGear UTV Seat Cover (Black Fits Yamaha Bucket) ()
The indicators flash too rapidly when one either left/right but they are ok when on hazards
  • 712 Answers
You could try cleaning/replacing the fuses. But I feel the real cause is the earthing. Have a look on the earth wires. This will be the case with a chance of 90%.
Hope this helped. If you need any more assistance, don't hesitate to come back to us. Else, if the problem is solved, please DO ACCEPT this solution. Best Wishes. Thanks for using FixYa.
Posted on Nov 07, 2010
02 Buick LeSabre Ltd. Rear flashers work (blinking rapidly), front bulbs stay on, inside indicators also flash rapidly. Replaced control module under the dash. Did not help. What else could it be?
Hi there., when flashers/indicators work rapidly on the dashboard you should check whether it is the same on the actual bulds. Fadt flashing is usually a sign of a bulb failure somewhere. If everything is functioning ok externally I would consult a competent technician for a diagnosis.
Jun 08, 2015 | 2002 Buick LeSabre
Rear right turn signal does not work. Bulb is ok. Flashes rapidly on the dash when I put the right turn signal on, ideas?
the flasher unit is out ..needs replaced i believe it is part of the hazard switch on those cars
May 26, 2015 | 2006 Chevrolet Impala
I have an 02 kia sportage. my signal lights come on but dont blink outside. no lights for the signal lights come on on the dash at all. also, no hazard lights.
If the 15A HAZARD fuse in the passenger compartment fuse box is OK, power is getting to the hazard function of the flasher unit. Pressing the hzard switch should cause the hazard lights to flash. HOWEVER, there is an electronic time and warning indication system module connected to to the hazard switch lead and that may be affecting things. If the 10A TURN fuse is OK, power is applied to the turn switch (with the engine in START or RUN) and you state you can select a right or left turn. HOWEVER, the RED/WHT and RED/BLU outputs from the flasher unit connect directly to the front and rear turn lamps and the instrument cluster turn indicators so you are not getting any flasher output. Again, that electronic time & warning indication system module could be affecting things
Oct 26, 2012 | Cars & Trucks
2003 Jeep liberty right front turn signal
why skip RR lamp? what does IT DO? be like 1st 1st look.
dim, out, fast?
the rapid is talking to you
it means current is wrong,
shorted, or open lines. to the right.
its the wiring
if the bulbs are like 1157 brass base bulbs
why not replace them first , they can short inside,
asking online for guessing is silly, why listen to 10 examples for this.
but is cut wires.
shorted wires.
keep i mind the blinker asks funny for both opens and shorts
its a feature, that.
low current or too much.
the acid test is connect 2 TEST bulbs in parallel to the multi-function switch output right side,
blinks ok now, bingo bad lamps or bad wiring, from there to the right side.
if the hazard fails you never said????
if rigth front is dim or dead the bulb is blown or shorted
if new bulb there , then the wires are shorted.
to it.
the only help on line worth squat is how to test and use your meter.
you can, check for voltage
you can check continuity on that line (its just 1 wire)
and check for shorts on that wire to ground (lamps pulled right side to do that, lamps read 0 ohms cold)
look for collision damage RF? behind lamp sockets?
be first.
in my book.
looking is always first. sure.
I have your SM book open now, chapter 8w-50
the haz/blink module has just 2 pins, left and right out.
pin 3 on the module runs front and rear blinks, (a fact to know)
RF is BR/RD, brown -red stripe?
all comments USA on USA forum. USA car.
ok?
the right side lamp (sidemaker) only blinks turns if parks ARE oFF
Id try 2 new blinker lamps front and 1 rear.
that be first. or test the lamp on a battery , and no not get burned fingers hot wring a shorted lamp.
wish i knew
what rear did
and what both did on HAZ
out, dim or to fast.
Mar 23, 2017 | 2003 Jeep Liberty
Left turn signal lights are not working
In my case the left front turn indicator lamp worked, but not the left rear indicator, although all the lamps would turn on with running lights activated, as well as the backup light and 'night-light' mode. The left rear turn indicator would not work with the hazard lights activated. I tested the combination switch (this is the left/right turn indicator switch you use when driving to indicate which direction you are going and is mounted/located on the steering column) and it tested O.K.. I had good continuity from the combination switch black wire, and resistance on the blue-white wire from there to the left rear turn indicator lamp, as well as good continuity on all wires going out from the left parking light fuse. Since the Haynes manual indicated that the flasher module was probably good if it made the tell-tale clicking sound, I was feeling perplexed. So I took it into a local shop that specialized in auto electrics and it turned out to be the flasher module. I was under the impression that it operated in a straight-forward left-right manner, but apparently it has a different circuit for each turn indicator lamp. So even if it is making the appropriate clicking sound when the combo switch is flipped, it could still be the flasher module. Obviously the manual leaves a bit to be desired in the troubleshooting of malfunctioning turn indicators.
Sep 07, 2012 | 1998 Dodge Caravan
Left turn indicator does not work.Right works fine. Left flashes Ok when hazards are opertated all 4 turn indicators flash and cancel fro the left switch so seems to show the switches are working as are...
If you will contact me directly, I can give you a complete troubleshooting guide for the turn signals. I cannot send it via this forum. E-mail me at wd4ity@bellsouth.net Don't forget to tell me what you need.
Good Luck
Steve
Aug 17, 2010 | 2004 Harley Davidson XL 883 Sportster
2001 Toyota Avalon - Rear signals
Check the front lights. Usually if i flashes fast it indicate a bulb is out on that side.
Aug 02, 2009 | 2001 Toyota Avalon
Problem with right-hand indicator.
If you have all of the correct wattage bulbs installed, and they all do indeed work, I would be looking for a bad ground point on the sockets of the bulbs that are flashing rapidly. A corroded ground will cause the bulbs to flash, or "flicker" rapidly, as there is not sufficient body ground for the bulb. Clean all of the sockets if any corrosion/rust/oxidation is present.
Sep 29, 2008 | 1993 Toyota Corolla
Classic Accessories QuadGear UTV Seat Cover (Black Fits Yamaha Bucket) () Logo
Top Classic Accessories Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Classic Accessories Boating Expert? Answer questions, earn points and help others
