Question about Garden
I have a King Canada 5 ton electric log splitter and the log pusher won't push the logs. And now it won't even turn on at all even though it is plugged in. I've added hydraulic oil. What can be the problem?
    Brigadier General:
  • 4,088 Answers
Plug a known working lamp into the power socket to verify that power is there. This unit should be used on a 20 ampere circuit and use a heavy 12 gauge extension cord if required. When the motor runs, it also drives the pump. The pump could be in poor condition or the piston may be passing hydraulic fluid by it. Service of these units should be left to an experienced hydraulic mechanic who will have the necessary pressure gauges and other specific tools. If you just obtained this splitter, take it back for warranty service or replacement. Hydraulic service is not cheap! Hope this helps!
Posted on Nov 07, 2010
Works for 15 min and then ,the ram moves to log and stops,checked fluid ok, voltage 115 ok
My thought is that there is air in the line. I had problem like that with my splitter. To cure it I had to stand the splitter on end because the oil fill is at the wedge end. I filled it. set it back horizontal and cycled the ram full length 3 times. I stood it on end again and could add more fluid. When I filled again it was now full of fluid and works properly. It also could be that the splitter is not powerful enough to split that size log down the middle. I must take a smaller bite then it works.
Dec 13, 2015 | Earthquake 5 - Ton Electric Log Splitter
Timber tuff 5 ton eletric log splitter will not move
check/replace the start/run capacitor/s
check that the hydraulic pump is not seized
Oct 26, 2015 | Timber Tuff 5-Ton Electric Log Splitter
Electric log splitter motor hums but won't run
suggest you get information on repairing log splitter, not dryer. have the same problem, and no replacement parts available. must be in the electrical, easiest would be capacitor, less the motor itself, take apart and see if windings burned, or smell electrical
Oct 13, 2012 | Dryers
5 ton electric woodsplittr wont return to start
look for a limit switch that might have debri in it not allowing it to read properly.
Mar 15, 2011 | McCulloch 4 Ton Electric Log Splitter #...
I have a 4052 mcCulloch 4 ton log splitter. What kind of oil does it take for the hydraulics
Not having a mcCULLOCH manual I dont know what they reccomend,but on mine I just use HI grade industrial/commercial hydraulic fluid. I have been using this for 15 years and have had no trouble. I change oil and filter every year. Thank you.
Nov 06, 2010 | McCulloch 4 Ton Electric Log Splitter #...
Splitter (2 years old) motor won't shut off.
First of all, I hate to, but have to ask, have you verified oil level is up to proper level? Have you checked power at directional solenoid when handle is moved to different directions, as well as released? Obviously when handle is in stop position, there shouldn't be power to motor in either direction. I can't see exact model, or design obviously,but that would be a good place to start.
Jan 31, 2010 | McCulloch 4 Ton Electric Log Splitter #...
Swisher 22-Ton 7 HP Log Splitter #LS722
For all swisher log splitter problems go to swisherinc.com.
Dec 10, 2008 | Garden
Garden Logo
932 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
