Question about Gateway FPD2275W LCD Monitor
TFT Monitor Dislay fault
Purchased a monitor at a PC Fair, but at boot up, screen goes straght to an all over yellow screen.Does not even show post instructions on black background. PC appears to carry on booting up OK, but screens stays all yellow even after waiting for 5 minutes or so. Is ther some thing I can do to alter picture resolution ( someone told me to try altering horizontal and vertical kHz and Hz ), but do not want to try this without confirmation. I am using VGA connection (HD15), but the monitor also has a DVI-I conection (not tried ). At self test with PC connection disconnected, I get all color bars showing correctly, but after connecting PC lead, I get the No signal received message. Any help would be greatly appreciated . This seems to be a great monitor if I can get it working. My OS is Windows XP Home. Many Regards, Dave
  • 106 Answers
This is a hardware issue with the monitor. I hope you kept a receipt with contact information for the seller.
Make sure the cable doesn't have any bent pins too on both ends.
Posted on Jun 15, 2008
After post screen monitor goes into standby and cannot boot from dvd
Not picking up video card, or rather losing communications. Use VGA port if available on you card, and make sure monitor is set to same connection port.
Nov 11, 2012 | Computers & Internet
Acer x193w Monitor won't come on flashes blue light you see word "Acer" it goes to flashing Yellow light and keeps repeating that.
you disconnect the monitor from PC
& see: it will show no signal or check signal cable. that means the monitor is OK problem is in PC. may be you PC is not booting properly. if monitor does not come on there may be fault in the main board of your monitor.
Oct 13, 2011 | Acer X193W LCD Monitor
The screen boots up with the commands and then it
The picture board on your monitor is faulty or bad, since it goes black after booting, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself. in order not to complicate issues.
Take care.
Apr 21, 2010 | Gateway 19" Widescreen Flat Panel TFT LCD...
Image for first 3 secs... light still on green
correodemie, Your ACER AL2016 will need to have it's "switch-mode-power-supply/CCFL inverter supply" trouble shooted and repaired. DIY repair cost less than $30. Out of warranty service $35 to $75, more if circuit board replaced. Read my and other techs FIXYA profiles to discover all the options you have for your BLACK screen symptom. Follow the links to other web sites for even more useful info. DO THAT before you do anything else. 12fixlouie
Feb 03, 2010 | Acer AL2016 W 20" TFT LCD Monitor
Monitor boots ok, then "Analog" appears/monitor shuts off
Does it have a digital port being used? If you are using the DVI port, it is probably digital. Try using the menu to selct the port. If it doesn't work, not sure from here. What is the model number?
Aug 01, 2009 | E-Machines 19" Widescreen Flat Panel TFT...
About 2 inch yellow stripe appears on the LCD screen
This typically is a sign of either a problem with the monitor itself, the cable, or the computer.
Fault isolation is key here. If you have access to another monitor, I would suggest connecting that to the computer, or vice versa. That way you can figure out what's broken.
If it's the computer, you might be able to purchase a replacement video card. If it's the monitor - you're out of luck, and likely need to purchase a new one.
Nov 15, 2017 | E-Machines 19" Widescreen Flat Panel TFT...
LG LCD monitor goes in power saving mode
That means theres no signal coming from the PC. either the PC is not booting up or the VGA coard is faulty.
Nov 25, 2008 | LG L1915S 19" LCD Monitor
Pc wont read monitor
If you look at the monitor there will be an led light on the front that is always orange or yellow when the computer is off but still connected to the monitor. This led will turn green when the computer boots up, sometimes even showing a "no signal" display before boot. If you see the 'command line'  text during the boot process (video info, BIOS version, POST text, etc) then the monitor is being recognized by the computer. If that text goes away and the led goes back to orange then it is a driver or operating system problem. Pressing whatever key is prompted at the lower left of the display, if you have a display, like F1, F2, F10, Delete or whatever will get you to the setup program and all is good with the display/computer connection and a green light will stay on. If you never get that green led light then either the video card is bad or not seated properly
Nov 16, 2008 | HP PAVILION A6230N DESKTOP PC
LG CB553H monitor has power and menu that sais no data. When I connect to a pc there is no display.
A monitor display showing "No Data" indicates that either the PC is not sending any usable video signal or the monitor is not capable of displaying the incoming video signal. To determine which is at fault, you would need either a known good second monitor or a known good second PC.
Additionally, it is also possible that neither is at fault and that you simply need to lower down the Screen Resolution and/or the Screen Refresh Rate of the computer's display properties to match the limitation/capability of the monitor. A method of verifying if this is the case is to start the PC in "Safe Mode" by pressing F8 after POST before Windows boot.
Alternately, there are some instances that it is the video cable that is the issue. To verify, you can try wiggling the cable to the connector end that goes to the PC's Video output.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jul 02, 2008 | Compaq FS 7550 17" CRT Monitor
Gateway FPD2275W LCD Monitor Logo
66 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
