Question about Honda Black Max 2600 PSI Pressure Washer
Do you mix fuel & oil together in a honda 2600 2.3 pressure washer?
I wanted now use only gas or gas whit oil
Posted on Nov 06, 2010
Rope pull start is stuck, won't pull out
Check the oil level, if it's very low or burnt then it may have siezed up internally.
It could also be that be that the cylinder is filled with oil or fuel.
if the washer was tipped over the fuel or oil may have migrated in to the piston combustion area.
Oct 20, 2014 | Honda Black Max 2600 PSI Pressure Washer
Change oil
contacted honda support and was told you have to tip the machine so I guess that would mean you have to empty the fuel tank before doing so
Aug 10, 2013 | Honda Black Max 2600 PSI Pressure Washer
The pump is leaking some gray fluid
Gray fluid is usually indicative of old oil with water mixed into it. First you have to determine if the fluid is coming out of the motor or pressure pump. Then change the oil in that, or both, and then watch the condition of the oil when you use the washer. With new oil, it won't turn gray but will get a milky coloration to it. There shouldn't be any way for water to get into the motor oil short of the engine being sprayed directly with high pressure water. If water is getting into the pump oil you'll have to check the seals inside the pump.
Feb 14, 2013 | Honda 5hp 5 Hp Engine Motor Xr2500 Xr 2600...
WHAT OIL SHOULD I USE FOR THE HONDA BM80913A PRESSURE WASHER . I HAVE OIL FOR 2 CYCLE ENGINES BUT I AM NOT SURE IF I CAN USE IT. I do not have the service manual available
If you are asking about the oil for the gasoline engine then you can use a 30 weight engine oil like you would use in a car engine. Pressure washer pumps use a special non-detergent oil which is not the same as the engine uses.
Jul 16, 2011 | Honda Black Max 2600 PSI Pressure Washer
I have the honda CG190 engine on the pressure washer and the manual has a section for draining the fuel tank and carburetor. (storing your engine) Draining the Gas tank is no problem. I do not seem to be...
Easy way to deplete fuel in bowl is to shut off fuel while you are using pressure washer and are about to finish your work. Just run the engine till it quits. Difficult way is to remove nut under the bowl. You might also look into new products designed to pour into tank for storing your engine and a method to displace the water from the pump and infuse oil. Good luck with your unit/
Jul 13, 2011 | Honda Black Max 2600 PSI Pressure Washer
How do you drainoil so you can change the oil in Honda Black Max 2600 pressure washer?
lornaa, you can get a copy of the user manual from this link. It has come directly from the manufacturer.
thanks and good luck
iain
May 04, 2011 | Honda Black Max 2600 PSI Pressure Washer
What gas and oil do I use on the Honda Excell 2600 pressure washr
That engine requires a separate gas and oil. There is an oil sump with oil level needle and cap on the side of the engine. This is where you fill it with special pressure washer pump oil available from any good outdoor store or place where pressure washers are sold. As for gas, Unleaded or Premium unleaded gas will work fine. Try not to use any fuel with ethanol blends however. Here is a list of oils that will give you an idea what to buy for the oil reservoir: http://www.amazon.com/gp/redirect.html?ie=UTF8&location=http%3A%2F%2Fwww.amazon.com%2Fs%3Fie%3DUTF8%26ref%255F%3Dnb%255Fss%255Fgw%26field-keywords%3Dpressure%2520washer%2520pump%2520oil%26url%3Dsearch-alias%253Daps&tag=onlinetoolrev-20&linkCode=ur2&camp=1789&creative=390957
Jun 14, 2009 | Honda Pressure Washer PSI 3000
I am wondering what type of oil to add to my pressure washer pump. I have lost the manual. It is a MCS Storm HG 202B washer with a honda motor.
They sell 'pump oil' I use the PRO JET brand universal pump oil. It can be hard to find. I get it from a local chain saw shop that sells pressure washers.
May 10, 2009 | Garden
Honda Black Max 2600 PSI Pressure Washer Logo
309 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
