Aspire laptop 5534 pxe e61 error message problem
  • 2 more comments
  • jjackson349 Nov 06, 2010
    This did not work. I don't have the (HDD 0) option in the "Boot Menu" . Is there anything else I can try.
    This did not work. Do you have any other suggestions? I don't have the (HDD 0) option to select from my "Boot Menu) screen options.
    When I got to the "Exit" menu, my option for default is...."Load Setup Default" when I select that and walk through the steps to F10 and Yes....it automatically reboots but to the same PXE E61 error message.
    I am now getting an "unbootable" message. I would appreciate it if you would continue to help me when you are available again. Thanks,
  • 4,737 Answers
If I am right, you must be seeing this message "pxe-e61: media test failure, check cable pxe-m0f: exiting nvidia boot agent" or with similar error when you try to boot the system. This means that it's the first boot option had been selected to "Pxe Rom". You have to disable this option and select Hard Disk from the bios. Power on the laptop and hit the F2 key on the keyboard a few times once it boots up, you'll be taken to the Bios Settings. In the bios settings, use your keyboard's up-down-left-right arrow keys and locate "Boot Menu" press enter and select hard disk (HDD 0) to be the first options and exit the bios by pressing F10 (and then "Yes"), the system will automatically restart and should boot up normally from the Hard disk.
If the problem persists, or if there's another problem, let me know.
Good luck.
Thanks for using FixYa.
Posted on Nov 06, 2010
  • 1 more comment
  • Lebanon Raingam
    Lebanon Raingam Nov 06, 2010
    Oh.. Ok.. no problem, you misunderstood what I mean. I didn't mean to select that particular HDD 0, I only mentioned it as an example so that you'd be able to pick up one from the lists... Well, didn't you see any HDD there? or Hard Disk?
    If you are still confused, go to "Exit" menu and locate "Default Optimized...." or just anything mentioned about the default..select it and try again.
  • Lebanon Raingam
    Ok..
    Once the system boots up, can you see the hard disk being detected by the Bios? You should see lists of detected devices with their respective names in white texts and black background. If you can't see it or you have are not sure, once again go into the Bios settings and look for the hard driver i.e. IDE Primary Master 1 etc...etc.. if you find nothing on all the lists, then it musn't be detected by the Bios, means there's something wrong with the Hard Disk Drive.
    Also, Please re-check the Boot Menu in the Bios and let the Hard Drive be the first boot device.
    I would also like to request you to please let me continue with you as I have to retire now.
    Thanks and awaiting confirmation from you.
  • Lebanon Raingam
    Thanks, it's clear that there's something wrong with the Hard Disk. Let's pray it's not a hard disk failure, but only a connection or other minor issues. I'll definitely get back to you when I am available. Till then take care.
Aspire 5315
If your computer is working fine then, disable PXE boot in BIOS or remove from 1st boot option. This is a LAN (network) boot option. It can't find a DHCP server, and is usually used to load an OS image. That's why is says check cable.
For the most part not a real problem. More of a warning.
Sep 26, 2012 | Acer Aspire 3680 Laptop
Tip
PXE-E61: Media Test Failure
Issue:
My computer gets this message when I try to boot it:
PXE-E61: Media test failure, check cable
PXE-M0F: Exiting Intel PXE ROM.
Solution:
Your computer is set to boot from the network (PXE = Netboot).
Go to your BIOS and make sure you boot from your hard drive.
Remarks:
Shouldn't be enabled by default
[more...]
on Jan 04, 2009 | Acer Aspire 3680 Laptop
Acer 5534 will not boot up....tried recovery disk....but nothing......error message PXE-E61-media test failure..........no bootable device
Hello:
Your Acer laptop is not detecting a bootable device, for sure your hard disk is:
1.- Malfunctioning and has lost its master boot record.
2.- It can be ruined and must be replaced.
In the first case, primary and recovery partition are bad, as you mention the recovery process failed (ctrl +F11). First, press F2 during POST, when "a enter Setup message" is prompted on the bottom of screen to check if the hard disk is listed on the Main BIOS properties. If detected, the hard disk can be recovered booting from DVD-ROM. In the BIOS setup utility, you need to select boot from de DVD-RW. Insert Windows 7 setup disk and it will check for possible boot errors, choose repair when prompted. Follow the instructions. The system will restart.
If the hard disk was not detected in BIOS properties, you should ask Acer for guarantee.
You may review this link for further information: http://www.acerlaptoprepairs.info/aspire-5534/
I hope this helps. Thanks
Jan 30, 2011 | Acer Computers & Internet
I get an error message on startup on my Acer Aspire 5100, it says Realtek RTL8139(x)/8130/810x PCI Fast Ethernet Controller v2.13 (020326) PXE-E61: Media test failure, check cable PXE-M0F: Exiting PXE...
It is beacuse your Hard drive is not detected on the computer properly.
Try resetting BIOS.
If that doesnt work, Check whether your hard drive is good.
Nov 28, 2010 | Acer Aspire 5100 Notebook
Hi, I have an Acer Aspire 5536 (am in UK by the way) I updated some Microsoft items when prompted last weekend, when I tried to restart I kept getting message PXE-2.1 or PXE-E61 Media Test Failure and...
The PXE-E61 error usually caused by a faulty hard drive or a faulty connection between the hard drive and the motherboard. Please click on this link and follow my instructions to fix this problem :-
http://www.fixya.com/support/r4377704-pxe_e61_error
Aug 13, 2010 | Computers & Internet
When I turn my laptop on a black screen appears with: PXE-E61: Media test faliure, check cable PXE-M0F: Exiting Broadcom PXE ROM. No bootable device -- insert boot disk and press any key I do this and...
The error PXE-E61: Media test failure usually means the hard disk has failed or the hard disk needs re-seating or the disk controller is faulty. Please click on this link and follow my instructions :- http://www.fixya.com/support/r4377704-pxe_e61_error
May 29, 2010 | Acer Aspire 5720-6661 Notebook PC
Cant get to home page
Your laptop doesn't recognised hdd.
You should go to bios to see if your hdd is there.
if you don't see your hdd in the bios, most of the time is harddrive problem (dead).
In this case, you can replace your hdd.
but if you see your hdd and you get PXE-E61 error message, your OS might be corrupted.
Oct 16, 2008 | Acer Aspire 5630 Notebook
your e-machine is set to boot from the network (PXE = Netboot)
go to your BIOS and make sure you boot from your hard drive
Aug 31, 2008 | Acer Aspire 3680 Laptop
PXE-E61:Media Test Failure
you got that error message because your harddrive isnot detected so it try to boot from network and you don't have OS in the network.
Most of the time is your hdd is dead. In some cases the motherboard is dead.
You can replace your hdd.
for OS (vista vs XP), if you have enough rams and high cpu, you should install vista, but for me, I prefer XP.
for the price, you should call microsoft seller.
Jul 05, 2008 | Acer Aspire 5050-3242 Notebook
Computers & Internet Logo
46 people viewed this question
David Payne
David Payne
