Question about Honeywell Heating & Cooling
How do you remove a honeywell t8132 a thermostat? i can not see how you remove the cover to get at the wires?
    Problem Solver:
  • 16 Answers
Http://customer.honeywell.com/Techlit/pdf/69-0000s/69-0740b.pdf Here is ur guide :-) azeddysac@yahoo.com
Posted on Nov 06, 2010
I have a black wire on my old thermostat that went to the c terminal my new Honeywell rth2300b does not have a c terminal any ideas which one I should put it to
Cover the bare end of the C wire with electrical tape so that it doesn't contact any of the other wires or parts of the Honeywell thermostat. The C wire carries continuous power from the red wire to some thermostats; this is required for some of the Smart thermostats (with the ability to communicate with your wireless computer network).
The installation directions for the thermostat include how to handle the C wire when installing the RTH2300B. You can find the manual on the product page in several places, including the Honeywell product site: https://www.honeywellstore.com/store/products/5-2-day-programmable-thermostat-honeywell-rth2300b.htm . The direct link to the manual is https://www.honeywellstore.com/store/images/pdf/rth2300b1012-u-5-2-day-programmable-thermostat.pdf .
I hope this helps.
Oct 28, 2018 | Honeywell Heating & Cooling
How to take a honeywell radiator off the wall
Turn off the circuit breaker to the AC and heating unit. The circuit breaker is inside the home electrical box. The door of your electrical box has a guide indicating which circuit breaker controls the cooling and heating system.Pull the cover off the Honeywell manual thermostat. If necessary, use a flat-head screwdriver to pry the cover away from the base of the thermostat. Locate the two small screws securing the sub-base to the base of the thermostat. The sub-base is the portion of the thermostat that has the indicator dial or indicator lever. Remove the screws with a Phillips-head screwdriver, and pull the sub-base away from the thermostat.Remove the screws securing the base of the thermostat to the wall with the Phillips-head screwdriver. Pull the thermostat base away from the wall so you can access the wires.Loosen the terminal screws securing the wires to the back of the thermostat with the flat-head screwdriver. Wrap the wires around a pencil or a large screw. This will prevent the wires from accidentally falling inside the wall cavity.
Jun 12, 2011 | Honeywell Heating & Cooling
How do I short my thermostat?
If you are asking how to bypass thermostat to make heat work then remove cover plate from t-stat and remove screws that hold base to wall. Disconnect wires to Rh and W and jumper together. This should make heater run non stop. Thank you.
Dec 25, 2010 | Honeywell Programmable Thermostat Heater
Honeywell Thermostat Lock Cover
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
May 31, 2010 | Honeywell Electronic Programmable...
How do you remove cover from honeywell ST699B
Go to honeywell.com
Feb 20, 2010 | Honeywell Programmable Thermostat Heater
How to remove thermostat cover to replace
the cover pulls off if it has a green screen then most likely takes batteries if does not light up then no batteries with a small piece of insulated wire jump from green to red if indoor fan does not come on then transformer bad
May 15, 2009 | Honeywell Programmable Thermostat Heater
Wiring honeywell DT200(T6620B)
HONEYWELL WEBSITE:
Go to honeywell.com
Apr 11, 2009 | Honeywell Programmable Thermostat Heater
My Honeywell PRO 3000 thermostat is not activating the cooling system when prompted.
R==power w=heat y=cool g=fan remove the front cover to reveal the 4-wires and take a jumper wire from r-----to ---g ,to see if the fan operates. Then take the jumper wire from r----to--y, to see if the cooling system works outside, because when calling for cool, the thermostat is internaly connected to g--for fan.. Then if it kicks in, then you have a bad thermostat!
Sep 04, 2008 | Honeywell Heating & Cooling
Heating & Cooling Logo
361 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
