Question about HP PSC 2210 All-In-One InkJet Printer
I changed the ink cartrige,it keeps saying alignment cancelled and the copy button keeps flashing - when i open it up the ink cartrige wont slide back out it seems stuck.
  • 823 Answers
The printer needs to be aligned and it wasn't done after changing the catridge so it does not want to continue. Have you tried pushing the flashing copy button to print another alignment page? Do you know how to align the printer?
After changing a cartridge the printer wants to print an alignment page to make sure that it prints correctly. Some printers have you print a page and they auto align themselves. Others cue you to print the alignment page which has a picture or other graphics that are in specific places and then it instructs you to insert the alignment page face down and press "ok". The printer scans the alignment page and configures the print heads to set up by the marks. It uses the alignment page as a map of where the print should be on the paper.
Try unplugging the printer from the power supply and wait about 30 seconds. Then plug it back in and turn it on. The display should say "print alignment page". Choose yes or confirm to continue. Your printer will either print the page and align itself, or print the page and tell you to insert it and continue. Either way follow the prompts and complete the alignment process in order to continue printing as normal.
If you are unable to get the printer to reset and start the alignment procedure over again, please advise and I will help you solve this problem.
Posted on Nov 07, 2010
Not printing correctly. Says to align cartriges. After aligning cartriges, it stills prints incorrectly no mater how many times I align cartriges.
Clean the ink cartrige and the cartrige carrier with lukewarm water or alcohol on a cotton cloth and then install the cartridge. Even if that does not work then you will have to reset the printer for which turn off the printer and then press and hold power and start buttons for 10-15sec and then release.. Then try it again.
Oct 21, 2010 | Dell 964 All-In-One InkJet Printer
New cartrige wont align
My Lexmark was giving me that message, even after I aligned it twice, and wasted ink in the process (part of the reason they do it). I finally pushed the red "X" to cancel the alignment, and it still kept giving me the message. Finally, after 3 or 4 times of cancelling the alignment, it gave up or fixed itself, and now doesn't give me the message. Not knowing what kind of printer you have, I can't tell you more, but hope this helps.
Jun 11, 2010 | Office Equipment & Supplies
Hp printer power light keeps blinking -- wont print any document
Turn both your printer and computer off then after a few minutes turn back on. This should cancel the print job.
May 28, 2010 | HP PSC 2410 All-In-One InkJet Printer
Replaced ink cartlidge and now wont print
After replacing the ink cartridge you should print the alignment page to work product perfectly.
Follow the below instructions to print alignment page:
  1. Turn on the HP PSC 1200 or 1300 series product.
  2. Disconnect the USB cable from the all-in-one.
  3. Press the sequence of front panel buttons below to start the print cartridge alignment process. The button-press sequence must be completed within ten seconds. It might take several tries to complete the sequence within ten seconds.
    1. Press and hold Cancel .
    2. While holding Cancel , press On .
    3. When the Check Paper and Check Print Cartridge lights begin to blink simultaneously, release both buttons.
    4. Press Cancel again.
    5. Press Copies .
    6. Press Paper Type .
    7. Press Color Start Copy . The alignment page will begin printing. If the alignment page does not print, repeat the button-press sequence in this step.
  4. When the alignment page has printed, place the page face down on the scanner glass and press Scan . The alignment is complete when the On light stops blinking.
  5. Reconnect the USB cable.
If the issue still persists, perform semifull reset by following the below instructions
  1. Unplug the power cord from the wall outlet.
  2. Unplug the power cord from the back of the all-in-one.
  3. Wait 30 seconds and plug the power cord back into the wall outlet.
  4. Plug the power cord to the back of the all-in-one.
  5. When the lights begin to flash, press and hold the On/Resume and Number of Copies Buttons.
  6. When only the On/Resume light is flashing, release the buttons.
  7. When the On/Resume light is steady, the reset is complete.
Oct 12, 2009 | HP PSC 1350 All-In-One Thermal Printer
Both the ink and paper feed button are flashing (Epsom c66 printer)
check for a paper jam or an ink cartridge jam which was not properly aligned. usually thse are reasons. also check your ink levels and never touch the part of the ink cartridge connected to the printer. just keep pressing cancel or X, cancel the documents, then load another paper then press on start copy. this should work.
Jul 08, 2009 | Epson Stylus C66 Inkjet Printer
Printer cartridge alignment
You can also bypass the alignment. When the message for alignment displays on the display => Press Setup and Options (or Copy Options ) simaltanious.The last known alignment is used when the alignment is bypassed.
Sep 04, 2008 | HP PSC 2175 All-In-One InkJet Printer
My printer
sure....did you do a clean and alignment service after changing that black cartridge?
Aug 03, 2008 | Canon PIXMA MP510 All-In-One InkJet...
No printing
If you brought new Lexmark cartridges please change it as it comes with one year warranty but before try to perform a self test, (i.e make a copy) if it works then try printing , if get the error then change the cart.........................
May 13, 2008 | Lexmark X4270 All-In-One InkJet Printer
Put in a new cartridge
i don't have driver
i want to load driver printer hp psc2210
Apr 21, 2008 | HP PSC 2210 All-In-One InkJet Printer
Printer Issues
my hp psc 2210 after putting in new cartridge keeps saying press enter to align cartridge. it keeps repeating the same reading.
Apr 08, 2008 | HP PSC 2210 All-In-One InkJet Printer
HP PSC 2210 All-In-One InkJet Printer Logo
387 people viewed this question
Clive
Clive
