Question about Dell Computers & Internet
Desktop does not power up but gives flashing amber at the power button.please help
  • 1,179 Answers
Your Computer is not POSTing, I recommend removing the BIOS/CMOS battery for about a minute then reinstall it in the correct orientation. This will reset the BIOS/CMOS, and bring the settings to defaults.
Clean your computer with a vacuum and paint brush, pay special attention to your CPU cooler, make sure sufficient airflow is achieved. Ensure all components are connected, clean the RAM fingers with tissue paper. Also do you hear the beep of the BIOS when a speaker is connected on the output pins. It's the pins that are located near the header for power and Hard drive LEDs.
Does your PC beep at you if you power on your PC without RAM installed, it should. If it doesn't then this confirms that your computer Mainboard is faulty.
However more often than not is your Mainboard that is faulty, the best thing to do is return it, if it is under warranty. If it is not under warranty the you will have to consider purchasing a new Mainboard.
Posted on Nov 06, 2010
Flashing amber light
Hi, on most Dells a flashing amber light on the power button indicates a problem with the PSU or a short on the main power rail, if this is the case you should have 2 flashing lights as well, 1 & 3.
May 05, 2014 | Dell OptiPlex 3010 MT Desktop Computer
Start button flashing
It depends on the color, if it's green or amber. This may indicate the computer is in sleep mode. Press the power button to see if you can turn on the pc. If it doesn't press and hold power button for five seconds. You may give more details. I hope this helps
Mar 10, 2011 | Dell OptiPlex GX260 PC Desktop
When I turn on my desktop the power button stays yellow and computer doesn't boot up.
A flashing Amber power button indicates a bad power supply. A solid amber means a motherboard failure or a failed component attached to the motherboard preventing post.
http://www.fixya.com/support/r4282412-find_no_post_diagnostic_information_dell
Jun 14, 2010 | Dell Dimension 2400 PC Desktop
Dell desktop 4700 problem
Flashing Amber power LED indicates a bad power supply.
http://www.newegg.com/Product/Product.aspx?Item=N82E16817822008&cm_re=atx_power_supply-_-17-822-008-_-Product
If the LED Is SOLID amber, it is likely either a component connected to the Motherboard or a bad motherboard
May 15, 2010 | Dell Dimension 4700 PC Desktop
Tower power button flashes amber but will not start
May 13, 2010 | Dell Dimension™ E510 PC Desktop
Dell Dimension power button flashes amber and will
open up your system get a can of air and blow all dust away could be an overheating fault
PC will NOT turn on;flashing amber lights
The power LED Flashing AMBER indicates the power supply in the tower has failed and needs replacement.
You can get a replacement here:
http://www.newegg.com/Product/Product.aspx?Item=N82E16817165004
Dec 20, 2009 | Dell Dimension 5150 Intel Pentium 4 w/HT...
Dell Dimension 5150 automatically turns off
That flashing amber light is usually a sign the power supply is failed or is failing. I would suspect the power supply is the problem in yours. It is the better of the two problems connected with the flashing amber light..the other is motherboard is failing. Arrrr!
hope this helps (it takes a standard- oh say 350 watt 20-24 pin power supply unit.)
Hope an answer helps.
Please leave rating, thankyou
May 05, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
The power button is flashing amber
A flashing amber light means a power supply problem usually caused by a bad power supply. Replace the power supply and everything should work fine for you.
Dec 20, 2008 | Dell OptiPlex GX280 PC Desktop
Does not power up
Is the amber light flashing on the monitor?
If so, you should get your power supply checked.
Jun 11, 2008 | Dell Dimension 2400 PC Desktop
Computers & Internet Logo
74 people viewed this question
Alun Cox
