Question about Electrolux Dishwashers
Dishwasher ELECTROLUX ESF 6121 WHEN STARTING propels the water, and then stop and blink SIJALICE WASHING AND PROGRAM. PROVERENO solenoid which operates. WHAT IS THE PROBLEM. Thank you, Darko
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 174 Answers
This fault can be the heater which has an electrical earth fault. You need an insulation tester to test it. The heater is accessed from the right hand side and is a cartridge type insert in the flow to the top spray water supply.
Posted on Nov 06, 2010
The anti-flood system has been triggered on ELECTROLUX ESF 656 how can I fix it?
The anti-flood system has been triggered means that water remains in base because leakage or overflow. In this case, in order to prevent flooding, drain pump running continuously.
Remedy: you should first remove the water from the bottom of the dishwasher and determine leakage.
If you work around the dishwasher, you always take care that appliance must be disconnected from the power supply.
Dado
Jul 22, 2014 | Electrolux Dishwashers
Electrolux ESF 662 no water is taken into the machine
Mine did the same thing. Turned out it was leaning back a bit, so I leveled it and now it seems to be working fine.
Mar 08, 2010 | Electrolux 23 in. ESI602 Free-standing...
Electrolux dishwasher shows code 10 not filling fault and code 20 not draining fault but when running you are able to hear it filling and draining. Whats the problem.?
I had the same issue (Electrolux ESF 6251). I had both error codes 10 and 30. I found that the short hose connecting the inlet valve (solenoid) to the tank was cracked. That explained error code 30, but even after replacing the hose I still got error code 10. I checked water supply and also drain hose and filters. I realized that I had recently tried to flush out lime scale and suspect that the drain or pump had lines could have clogged up. I tried pumping into the floor drain inside the dishwasher (removed the filter cartridge and screen) simply with a suction cup like you use in the kitchen sink. Voila. Now it works again...
Sep 17, 2009 | Electrolux Dishwashers
Dishwasher full of water
Check all areas stated below to address this issue.
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer/Control
Replace if defective (note: uncommon problem).
Jun 18, 2009 | Electrolux Dishwashers
Dishwash machine electrolux esf 6121
Easy fix, had same problem on our. behind the red lights there is the electrc stuff, when you open/close the machine the solderings crack. remove screws until you can get off the panel, then there is some small hooks that hold the board, loosen all contacts and take out the board, check the solderings around the relais and re-solder them, i resoldered all spots on our board.
Mar 01, 2009 | Dishwashers
Electrolux ESL4114 problem
see other problems listed ,other machines have similar problems one chap suggests that the FLOAT SWITCH is stuck or faulty causing the inlet valve to read as full so continues program...
Oct 30, 2008 | Electrolux 18 in. ESL4114 Slim-Line...
Have a trouble: dish-washer will not drain.
I just moved into a new house and builder had provided a dish washer drain just below my kitchen drain line.
DIsh washer install was done by me, every thing worked out OK except dish washer would not drain after a wash cycle.
Cause: drain provided by builder was blocked and needed a circular small cut before mounting drain hose over it.
Mar 21, 2007 | Electrolux 24 in. ESI6220X Free-standing...
Dishwashers Logo
398 people viewed this question
Top Electrolux Dishwashers Experts
Mike
tglynn
Level 1 Expert
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
