Question about IBM IntelliStation Z Pro 6221 PC Desktop
I recently installed Win7 on IBM intellistation zPro (6223), with RAID 1 SATA drives. All worked well for a few days, but then system would not boot. I can go into bios and see the RAID disks, and verify them, but when I boot into windows repair program and try and load the SATA drivers it just hangs. Any thoughts on how I can troubleshoot and isolate this problem.
    Genius:
  • 1,672 Answers
Did you try to set your BiOS to DEFAULT?
Posted on Nov 06, 2010
Can run windows 8 on IBM intellistation z pro ?
IBM IntelliStation zPro came with different CPU chips through 1997 to 2006. Depending on which year or type your machine is will determine if you can upgrade to Windows8.
The chips used were
Type 6899 (March 1997 to ??)
Type 6865 (October 1998 to April 2000)
Type 6866 (January 2000 to March 2002)
Type 6894 (May 2001 to June 2002)
Type 6221 (November 2002 to February 2005)
  • Dual Intel Xeon at 2.4, 2.67, 2.8 or 3.2 GHz
Type 6223 (August 2004 to March 2007)
  • Dual Intel Xeon with Intel 64 (formerly EM64T) at 3.0, 3.2, 3.4, 3.6 or 3.8 GHz
Type 9228 (June 2006)
  • Dual Intel Xeon Model 5130, 5140, 5150 or 5160
Windows 8 If you want to run Windows 8 on your PC, here's what it takes:
  • Processor: 1 gigahertz (GHz) or faster with support for PAE, NX, and SSE2 (more info)
  • RAM: 1 gigabyte (GB) (32-bit) or 2 GB (64-bit)
  • Hard disk space: 16 GB (32-bit) or 20 GB (64-bit)
  • Graphics card: Microsoft DirectX 9 graphics device with WDDM driver
As you have Type 6223 which a Xeon faster than 1GHz it should work with Windows 8 but not all Xeon processors are compatible depending on which one you have. See this Microsoft site after you check your Xeon chip family on the motherboard or through the Windows system command. Search for xeon.
Processors What processors support Windows 8
Aug 15, 2014 | IBM IntelliStation Z Pro 6223-42U PC...
IntelliStation Z Pro 6223-3EU:what memory does it use?
It uses 2GB DDR2 SDRAM memory at the speed of 400 MHz. And supported up 16 GB of memory
Jul 28, 2010 | IBM IntelliStation Z Pro 6223-3EU PC...
What are the compatible BIOS for intellistation Z PRO 6223 work station
Here is the link to your system BIOS tools and updates:
http://www-947.ibm.com/systems/support/supportsite.wss/supportresources?categoryind=5050379&selectedButton.x=12&selectedButton.y=13&selectedButton=category&familyind=5050008&brandind=5000004&osind=5053379&typeind=5178890&modelind=0&matrix=Y&taskind=2
Dec 17, 2009 | IBM IntelliStation Z Pro 6221 PC Desktop
With a IBM 6223 can I mix sata and scsi drives in the same machine?
Yes. you can use any mixture of different interfaces a PC. As long as you have the appropriate controller interface to plug the drive into, and your power supply is big enough to support the drive(s) you're using, there should not be a problem.
The only caveat is that if you want to boot from a drive type that is not part of the PC bios, this may not work.
Such as if the bios is so old that it only has IDE and you plug in a SATA or SCSI adapter, it may take some fiddling to make it boot properly. Many interface adapters have their own bios, and sometimes things are not as compatible as they should be.
Oct 21, 2009 | IBM IntelliStation Z Pro 6221 PC Desktop
Does not see hard drive
configure the bios settings, hdd should be scsi. maybe your current settings is sata or ide. if not work check the scsi controller if have installed driver or compatible to your unit.
Oct 10, 2009 | IBM IntelliStation Z Pro 6223-31U PC...
How to install Adaptec SCSI driver when installing XP -Z Pro 6223
you have to use sata xp cd to intall that driver no need floppy disk.
Aug 19, 2009 | IBM IntelliStation Z Pro 6221 PC Desktop
Boot problem with IBM xseries 206 - SCSI Drive and SATA drive
Refer to user's manual how to set the boot order in BIOS.
Jul 17, 2009 | IBM eServer xSeries 206
Raid 0 on Intellistation 6221?
That particular work station comes with both IDE and SCSI drive interface controllers. The IDE drive should be used for your OS. The SCSI drives for your data storage. Now, the issue is to get the SCSI to work in RAID_0 as I understand.
You iwll need a RAID controller such as Adaptec AHA-3940AU WD SCSI Host Controller, which may be found on eBay (used) for a very affordable price. The driver software may be downloaded directly from Adaptec, so I suggest you do that in the iterim peroid, and store drivers on a USB thumb drive.
Hope this helps you.
Dec 21, 2008 | IBM IntelliStation Z Pro 6221 PC Desktop
IBM Blue Screen
I had the same problem with an Intellistation 6868 for years. It just wouldn't load XP but ran fine on Windows 2000 SP4. I tried 3 different XP Installation CD's with no luck. After several attempts at installing XP I bought a clean XP Upgrade from ebay.
It took me 3 goes to install it but eventually I got it in there. If you can get XP to start on the 6868 press F8 and start it in safe mode first then when it's booted fully, shut it down and and then start it clean again. It worked for me. I've been running it for 5 months now and it's fine.
I couldn't get it to work at all on the 6868's onboard IDE so I installed a PCI Raid Card and it boots fine on that.
System:
IBM 6868 52A M-Pro Intellistation
2 x Intel P3 866 CPU's 256 mb cache
2 GB ECC RD Ram
2 x Seagate 320 GB 8MB Cache HDD on a Sunix ATA133 PCI Raid Card
2 x Seagate 10000 rpm SCSI HDD on Adaptec Raid Card
ATI 9520 AGP 128mb Graphics
Win2000 Professional SP4 - Upgraded to XP Professional Edition SP3
Dual Boots with Xandros Linux Desktop Destop 3.01C
Sep 08, 2008 | IBM IntelliStation M Pro 6868 PC Desktop
IBM IntelliStation Z Pro 6221 PC Desktop Logo
306 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
