Question about Watches
I need help setting a crivit sensor technology sports watch 1ld29000
Where can I get instruction details for my POD 550 watch?
RCX5 found it surprisingly light and small. It doesn't look like a computer on your wrist like many other GPS watches. Of course that is largely because the bulk of the GPS components and battery are in an arm band.
The armband and separate GPS device seemed like, and became, one extra piece of equipment to worry about.
The watch, heart rate monitor and foot pod all use watch batteries. Battery removal can be difficult, however once the back is removed the batteries are easy to install and replace. The GPS piece is charged with a standard USB cable.
The speed and cadence sensors batteries are not replaceable. These sensors must be purchased again when they wear out
The speed and cadence sensors are attached to a bike with zip ties. I found them easier to install than the Garmin sensor largely because they are separate devices. It was easier to position each of them so that they picked up the magnet from the wheel/pedal separately, rather than trying to align one device to detect both.
Additionally the speed and cadence sensor each have a built in led light that flashes each pass of the magnet.
However, to configure your stride length is tricky at best. The best way to do it is to run a distance using the stride sensor that you know the actual distance of, then change the distance in the history. So let's say you ran 1 mile. The watch believes you ran 1.1 miles. By changing the history to 1 it should adjust the settings so that the next mile you run will record correctly.
Once you have been using the watch for some time you can get into advanced setup. You can add your own sports, or configure the devices, and screens setup with each sport.
You can do this from the watch, but it is easier to do it from the Polar Web Sync software. The software works much like a remote terminal for the watch. You connect to the watch and add or change each sport profile, or change user or device settings.
May 09, 2015 | Watches
Have armitron sports watch and cannot set time. Help!!!
On the time press and hold the set button till one of the things start flashing then press mod to switch from hours, minutes, and seconds. then press the adjust button to adjust it. when you are done press set!
Jan 10, 2011 | JCPenney Armitron Sport Link Bracelet...
How to set the compass on a casio SGW 100
http://world.casio.com/wat/download/en/manual/
Use the four numbers on the back of your watch and you will have a PDF version of your instruction manual.
Hope this tip helps
R/
David
Feb 24, 2010 | Casio Digital Compass Twin Sensor Sport...
Need help setting interval timer on timex w-191-na 100 lap memory. need to set to 1 min and 2 min and repeat 10 times
http://www.timex.com/info/Product_Instruction_Guides_Downloads
Use the numbers on the back of your watch and you will have a PDF version of your instruction manual.
Hope this tip helps
R/
David
Jan 13, 2010 | Timex Popular T5E931 100 Lap Ironman...
How to set my timex watch
Hope this tip helps
R/
David
Dec 11, 2009 | Timex 1440 Sports Aggressor 56014 Wrist...
How to reset time columbia small sport watch cl-5008
Press mode til you get to time then press and hold set. Once the hour starts blinking press the ST/SP button to set the time, then press set again for the minutes and do the same thing again. This should let you set your watch.
Nov 10, 2008 | Columbia All Sport Digi Watch l
Can't set time on a 2 button armitron watch
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Armitron says if the model is not listed on their site call them 718-784-0700. I did and they promptly e-mailed me PDF.file instructions for my M516 watch. - David
Mar 10, 2008 | Watches
Watches Logo
330 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
