Question about Casio Parts Cash Register PC Desktop
Dboyatawent out of business and put royal 601sc in storage. just open a new \r\nbusiness a couple of year later and pull out my register and I have forgot what I programmed in it. want to program for new business but everytime i hit a key i get and error message.
  • 42 Answers
Needs to be ram cleared if it has been sitting in storage awhile...
turn key to program while holding down journal feed button.
after all 0's appear in screen press subtotal
(note, this will clear any programming and totals in the register
Posted on Dec 17, 2010
I have Royal alpha 600/601SC Cash register with PS-700e bar code reader.I purchased one PS-700P bar code reader for that after the original got damaged. But I have problems with this unit. it does not
the clue is in what youve typed
you used to use a 700E type
you replaced with a 700P type
perhaps look for the 700E type that matches the older type you have
i would assume the last letter is the series ident so the one you replace it will it newer
perhaps doesnt communicate in the same exact way
Nov 30, 2014 | Royal Alpha Retail Supplies
How to change the date on a royal alpha 601 sc cash register ?
Turn key to Prg mode for date punch in todays date, example June 13 2014 would be 061314 and depress the # key.
The time in Program mode would be for 9:45 Am 0945 and depress the QTY/Date Key. for PM you would use military time such as 3:00 PM would be 1500. Hope this helps.
Jun 11, 2014 | Casio Parts Cash Register PC Desktop
I want to know how the parallell port is configureg. baudrate. bitrate etc
The parallel port does not use bit or baud rate. These terms apply to not serial ports.
A complete description of the Parallel port operation is not possible in this forum, so I'll just highlight the differences.
First, serial transmits one bit at a time. Parallel means that all 8 bits in a byte are passed at one time. A parallel port can pass data at about 10K bytes (Standard) to greater than 1M characters per second depending on the configuration of the Port.
There are two types of parallel port connections. The Centronics or Standard Parallel Port (This is signal line activated and then is run by timing.)
For example, when the PC has data to send to the printer, it first checks that the parallel port is not busy, by testing the signal on the nBUSY pin.
If the printer is not busy, then the PC lowers the signal on the nSTROBE signal line. The printer sees the signal drop and waits about 500ns and then sets nBUSY to low and transfers the data to the printer. 500ns later, the printer will raise the ACK line and lower the nBusy line.
The high speed version of the port works off of the edges of the signals and does not use the timing delays.
For example, the PC will check the nBUSY line and if it is not busy, then it will lower the nSTROBE line. When the printer sees the nSTROBE line go low, it latches the data off of the parallel port and then raises ACK and lowers nBUSY.
So the difference between the High Speed IEEE1284 and the Standard or Centronics is the timing. Standard uses timing delays and IEEE1284 does not. Also, the IEE1284 protocol allows for communication back from the printer via the parallel data pins. You cannot do this with the Centronics port.
There are several forms of IEE1284 so yo8u have to know which forms are used by your PC. For example, I believe that HP PCs use EPP form and Lexmark uses another form of IEE1284.
Don
Dec 02, 2009 | Brother HL-2040 Laser Printer
Royal Alpha 601sc cash register won't program.
Hi. I don't have a manual for that model. If you can flick me an electronic version, I'll try to help.
May 27, 2009 | Casio Parts Cash Register PC Desktop
Replacement keys
try bizrate.com or ebay.com
Apr 29, 2009 | Casio Parts Cash Register PC Desktop
The $ bill lever broke on my Alpha 601SC cash register
Hi.
You will need to find a dealer in your area. The bill holders are usually very cheap to replace and you can just fit it yourself. Look up a dealer under cash registers in the yellow pages. Many brands usually have interchangeable holders, so you might be able to use say a Casio one if they are the only dealers in your area.
Mark
Mar 22, 2009 | Casio Parts Cash Register PC Desktop
Casio Parts Cash Register PC Desktop Logo
70 people viewed this question
Top Casio Retail Supplies Experts
Electroboy
Electroboy
tomferryman
Level 1 Expert
Are you a Casio Retail Supply Expert? Answer questions, earn points and help others
