Question about Light Outboard Motor Boat Bass Fishing Saltwater Base
MY 2004 yamaha 115 4 stroke has had some problems with the ignitian switch. First it would not start unless I turned turned the key on and off a couple of times. I sprayed electronic cleaner into it a number of times. Now it starts ok. Now I have to turn it back and forth to get it to turn off. I tried the cleaner again but no luck.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Light Master
  • 1,190 Answers
Replace the switch ! will only fail again when your out and then cant get back !
Posted on May 27, 2014
4 Suggested Answers
  • 77 Answers
SOURCE: have 1975 Merc 115 h.p. motor. won't turn over with key
it may be your neutral safety switch. Try it again but this time turn the key with one hand and wiggle the throttle/shifter lever at the same time. My 25 johnson does this, but usually I can wiggle the shifter and she'll turn over. Hope this helps.
Posted on Jun 23, 2009
finish line
  • 207 Answers
SOURCE: 75 mercury boat motor not turning over
you have one of two problemsyour starter brushes are sticking or your solenoid is going bad next timme it happens take a hammer and lightly tap the starter if it turns over your starter is going bad if you try this repeatly and nothing then you have a bad solenoid they are not expensive if you do not want to tap the starter then just replace the solenoid the best way to find it is follow your main battery line to motor where it stops and breaks with two posts and then the hot goes to the sarter take a picture of it so if you need to take it with you u acn see where the wires go oriellys probally will have it is round and you battery will go to one post and the hot to the starter will go to the other there will be to little posts on it as well one to the key switch and the other is a groud
Posted on Jun 30, 2009
  • 53 Answers
SOURCE: yamaha 115 will not shut off with key or kill switch
not enough information on the motor. what year and model? but all yamaha outboards are shut down by the C.D.I. being grounded by the key switch or the emergency kill switch. the cheapest thing to test or replace is the key switch and the emergency kill. with more info on engine I can help you further.
Posted on Nov 02, 2009
What trim sending unit is on 2005 Yamaha 150 vmax
67H-83672-00-00
All models uses the same unit since 2004 ( from 30 to 300hp)
Jun 15, 2017 | Clymer Marine Maintenance and Repair...
Motor wont turn off with key
Could be broken wire in loom,or bad connection in loom plug or faulty ign switch which is very unlikely
Mar 17, 2014 | Clymer Marine Maintenance and Repair...
2002 yamaha 150 outboard wont shut off with key
Broken wire in loom,white wire,bad connection in loom plug,if it switches off with kill switch,then it points to ign switch
Mar 15, 2014 | Clymer Marine Maintenance and Repair...
My 86 yamaha outboard will not turn over
Bypass solenoid,put jumper from pos on batt to starter motor,but could be so many things,faulty battery cables,broken wire in loom,worn starter brushes,faulty solenoid ,start in gear switch or ignition switch
Feb 02, 2014 | Clymer Marine Maintenance and Repair...
Where is the neutral safety switch located in 2004 Vito 115 CDI We can not able to start the car any one help me please
run fault codes first as it may be an immobiliser. have a load test done on the battery as it may be faulty. Check battery terminals and posts are shiny clean and tight. It may not be the neutral switch at all unless you have been experiencing problems before hand
Dec 12, 2013 | Cars & Trucks
Yamaha 115 68v not starting
Do you have spark? What about fuel? Have you tested anything?
Aug 12, 2013 | Yamaha 115 Hp Stator Assy 68v-81410-00-00...
Yamaha 115 will not shut off with key or kill switch
Sep 23, 2009 | Light Outboard Motor Boat Bass Fishing...
Light Outboard Motor Boat Bass Fishing Saltwater  Base Logo
123 people viewed this question
Top Light Boating Experts
ray gallant
fordexpert
Ian Summerfield
Ian Summerfield
Are you a Light Boating Expert? Answer questions, earn points and help others
