Hitron car amp ha-2000.2 - Audio Players & Recorders
My Protecton light is lite on my amp. Why? also can't hear anything
Posted on Apr 04, 2010
Hitron hra-2500b amp turns on then turns off
Make sure that you are not over loading the amp. Example - if your amp is only rated for 8 ohm then you can not wire the speakers for a 4 ohm.
Jan 25, 2013 | Hitron HRA 2500B 2 Channel 500 Watt Mosfet...
Bought a hitron 3200b secondhand. installed the amp and no sound I have a 06 gmc I am using an aftermarket radio it is a lo line model made by I think dual 50 bucks at walmart all connections are good...
Bypass the amp with a small speaker or tweeter to make sure your rca input is working. Is the amp light on. Got good power, ground, and remote? Have you tried a different set of speakers on your amp?
Sep 04, 2011 | Hitron HA20002 Car Amp
How do i know what size fuse i need for a hitron hra 2500 amp?
im assuming you dont have the old one. typically it will be 20-50a. i recomend consulting the manufactures website.
Apr 25, 2009 | Hitron HRA-2500 250W 2CH Amplifier Car...
Need amp
Hi and welcome to FixYa,
It would be safe to use an amplifier slightly lower than the maximum rating of the speaker. In this particular case, 350 watts or lower would be just about right for each. If you are wiring the 2 subs in parallel and powering them with a single channel amp, then a 700 watt bridged would also work.
Good luck and thank you for using FixYa.
Apr 09, 2009 | Hitron 2 12in Subwoofers loaded in...
8 ohm to 4 ohm
All you need to do is wire your 2 subs together in parallel. This means Hooking the positives of both subs together, as well as hooking both negatives together.
Your total resistance:
Rt = (R1 x R2) / (R1 + R2) = (8 x 8) / (8+8) = 4
A ---------------- + ------------ +
M >| >|
P------------------_--------------_
May 15, 2008 | Hitron HRA-2200B 2 Channel 400 Watt Mosfet...
2 12" Hitron 600w subs in a BandPass box
Remember that driving a load with an underpowered amp will probably cause more problems than having a more powerful amp that is not running flat out. 200-300W amp would be ok, but I would suggest going for the biggest you can afford. If you crank up the volume on the smaller amp you will probably get a fair amount of distortion, which may actually damage the speakers. A larger amp will not give as much distortion for the same loudness/volume and give better control of the speakers for a tighter bass..
Oct 31, 2007 | Hitron 2 12in Subwoofers loaded in...
Hitron 600w 12' subs in a bandpass box
i think u mean ohms,amp wattage?wat r u trying to do>?
60 people viewed this question
 Grubhead
Grubhead
