Question about Briggs & Stratton 2200 PSI Gas Pressure Washer
The engine surges at idle and then does not run constantly underpressure. sounds like fuel but cleaned all lines and used new fuel. any suggestions
  • 7,733 Answers
A new spark plug and don,t forget to push in the choke after start.
Posted on Nov 09, 2010
1999 chevy van, 7.4 v8 eng. surges and wants to dye out at idle, otherwise ok. possible causes?
fuel line, with that you most likely got ( gross, oh goodness, eww, yucky) sludge in the tank that is most likely in the lines as well. did the van sit for a long time. if so the first thing u do is drain the tank an put new fuel in it so sludge (dirt) don't happen. hope i helped good luck
Sep 05, 2015 | Cars & Trucks
Engine surgings after running 1hr
You're on the right track its definitely fuel starvation. Try cleaning the fuel tank breather (it's probably in the tank filler cap). This allows air in to the tank as the fuel is used, if it's blocked you get a partial vacuum in the tank and the fuel wont come out.
Jan 02, 2014 | Poulan Snowblower 205cc 8.0 TP Briggs OHV...
Got a 99 Nissan Altima 2.4, t-chain broke... replaced head and all t-components... start up surging idle and whistling off idle... engine runs smooth and great power off idle
the surging and whistling sounds like there might be a vacuum leak that is causing this.recheck all vacuum lines and surfaces were this is a gasket that seals a vacuum source.smooth running and good power off idle suggest this leak only affects the motor at a low(idle)rpm.
Apr 14, 2011 | 2005 Nissan Altima
I HAVE A 20HP SINGLE CYLINDER INTEK ENGINE IN MY LAWN MOWER THAT SURGES BAD AT IDLE UNLOAD NOT SO BAD. CAN YOU SUGGEST WHAT TO DO two year old
Carb needs to be cleaned Clamp your fuel line Get some jet spray gumout with the tube take fuel bowl screw out of the center of the bowl this is where your high speed jet is Dont loose the fuel jet on the float it hangs there clean it as well the rest of the carb inside put back together should run better
Feb 27, 2011 | Briggs & Stratton Garden
1998 camry 5sfe engine, surging at idle
Check for air leaks in the vacuum pipes in and around the inlet manifold, they have a habit if going brittle and splitting.
Another possibility is the temp sender , if the ecu thinks the engine is too cold it will compensate causing the engine to " hunt". This can be something as simple as a worn radiator cap seal letting air into the cooling system and tricking the sensor.
Hope this helps, Marshall
Apr 29, 2010 | 1993 Toyota Camry V6
Engine speed surges
Surging engines in lawn mowers are usually related to a lean fuel/air mixture. With today's environmental concerns, the carburetors on these engines are set with a very lean mixture (to reduce air pollution). Furthermore, they usually put limiter caps on the carburetors where you cannot easily adjust the mix to get the engine to run better.
If there are adjustment screws on the carburetor, try turning the high speed adjustment screw a bit counter-clockwise (if the limiter cap will allow it). This will enrich the fuel/air mix a bit and might help the engine run a bit better.
Oct 11, 2009 | Garden
Coleman Powermate 3000 surging
Check your air filter to make sure it is clean, especially if the gen. has been run in dirty, dusty conditions. Make sure the gas tank vent is not clogged.
Also, pour some combustion cleaner into the carb. through the air intake to clean the carb. It sounds like it is starving for gas.
Hope this helps.
Rob
Sep 27, 2009 | Coleman Powermate Premium Plus 6250W...
Olds alero 2.4 idle fuel pressure
most likely idle air control sensor or low engine coolant I know sounds funny but IAC uses coolant to regulate idle. Idle air control valve or throttle body positioning sensor.
Dec 10, 2008 | 1999 Oldsmobile Alero
Surging while iit idles....
Check for cracked vacuum lines, run some fuel cleaner through, faulty Throttle Position Sensor (TPS), clean your throttle plate really good with some carb cleaner.
Sep 25, 2008 | 1990 Jeep Cherokee Limited
Briggs & Stratton 2200 PSI Gas Pressure Washer Logo
454 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
