Menu screen for monitor keeps coming on, press exit button, disappears for awhile then comes back or flashes on &off. emachine monitor, modl le1799
  • 6,993 Answers
it is possible that the screen menu button is stuck "IN", that's why it keeps coming up itself. Get a pin and use it to bring out/pull out the stuck button.
Or press the menu button constantly so that is can be freed.
I hope you understand the above solution.
Good luck.
Posted on Nov 08, 2010
  • Walesarumi
    Walesarumi Nov 10, 2010
    I haven't heard from you for a while now. How far have you gone with the windows repair?
    Bye for now.
Auto adjust in progress
1. Push the menu button at the front side of your Dell monitor. The icon looks look like a miniature version of your monitor.
2. Push the menu button again. This will exit the monitor menu and launch the OSD (On-Screen Display) menu.
3. Use the down arrow button on your monitor to select "Factory Reset."
4. Push the menu button.
5. Use the down arrow button to select "All Settings." Press the menu button to save changes.
6. Push the menu button twice to exit from the menu. Your Dell monitor will go back to its factory settings default, and its auto-detect feature will be disabled.
Oct 10, 2014 | Dell E171FPb 17" TFT LCD Flat Panel...
My brightness monitor appears in the lower right quarter of the screen and does not go away. When I press and hold the right button, it disappears, but as soon as I release, it comes back. The screen is...
Hi
It's likely you have a sticky button.
Look carefully to see if you have a Menu button, enter the control panel and use the arrow buttons to scroll to the exit icon and then press menu again to manually exit.
I hope this helps.
Aug 25, 2011 | Samsung SyncMaster 740N 17" LCD Monitor
An emachine monitor menu keeps popping up and can't be turned off. what do I do
Press the "MENU" button on the monitor to turn it on or off. If that doesn;t work, press the AUTO button, let it reset and then press again to exit.
Good Luck
Nov 18, 2010 | E-Machines eMachines Monitor E15T4
Stupid padlock/main menu keeps opening and closing DELLe152fp
That is the OSD (On Screen Display) system built-in to your computer monitor. Check that when you hit the ON/OFF button on your monitor, that you do *NOT* hit the 'OSD ON/OFF' button.
Most of the time, the OSD will disappear after 10 seconds of "non-use".
Dec 11, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
A message keeps coming up about the resolution.
in your monitor paenl tehre are button like menu and enter and up and down arow just press the menu button twice or turn off the monitor and switch it on .
Nov 27, 2009 | Office Equipment & Supplies
I don't know how to increase the volume
OSD Menu Functions
English
All the function settings for the LCD monitor are controlled via the control keys located on
the bottom part of the front panel. To display the OSD main menu, press the “Menu”
keypad button on the control keys2.gif. (Note: The OSD menu display will disappear
automatically after approximately 10 seconds, if no action is taken.)
The LCD2.gif monitor has been adjusted to optimal settings before shipment. Adjustments to
the monitor settings can be made using the OSD menu.
• Press the “Menu” button to display the OSD.
• Press the ▲ or ▼ button to select the function to be adjusted.
• Press the �� button to access the function to be adjusted.
• Press the ▲ or ▼ button to select the sub-function to be adjusted.
• Press the �� or �� buttons to change the current setting of the sub-function.
• To go back to the previous menu, press the button. Changes are saved
automatically.
Source
• To exit the OSD menu press "Menu" again. It automatically will save any changes
that have been made.
If this is helpfull; please indicate so.
JZKlipper/Mike
Nov 11, 2009 | Westinghouse LCM-19v5 Monitor
I don't know how to increase/adjust the volume on my LCM-19v5 computer monitor
OSD Menu Functions
English
keypad button on the control keys. (Note: The OSD menu display will disappear
The LCD monitor has been adjusted to optimal settings before shipment. Adjustments to
automatically.
Source
JZKlipper/Mike
Nov 11, 2009 | Westinghouse Computers & Internet
OSD Lockout bananas
Please try to Turn the monitor off. Hold down the Menu button while the monitor is turned off, then press the Power button again to turn the monitor back on. This should unlock your OSD menu and remove that message from your screen. best regards
May 23, 2009 | HP w1907 LCD Monitor
Menu/screen resolution/contrast box keeps popping up on screen.
By what your describing, the board in the monitor that allows you to make changes to the display is going bad (sounds like the settings button). If it were a notebook you might be able to get a board replacement (just an example I know notbooks dont have this feature in the lid). Since it seems that your display is for a desktop, I dont think it would be easy or inexpensive to get a replacement board. You will probably have to get a new monitor. If you want to fix it yourself, pull the monitor apart and get the board out. Try an electronics cleaner and put it back together. If it works, great. If it doesnt, take the board back out and take the board to an electronics (tv) repair shop and see if they can solder in a new button. If that doesnt work your back to buying a new monitor. Hope this helps...
Jan 09, 2009 | E-Machines eMachines Desktop PC
Computers & Internet Logo
51 people viewed this question
Alun Cox
David Payne
David Payne
