SOURCE: Sony Handycam DCR-HC42 Mini DV not recognized by Windows 7
win vista and win 7doesn't support usb streaming. the usb driver for this model would not be compatible with your computer's OS. although, you were able to download PMB still this wouldn't work, it's basically an alternative software that you can use with the newer OS. still the device driver would not be installed. and you would get a message that "ilink connection is not detected". the reason you get that is bec the camcorder and the software is intended for use with the dv (ilink or ieee1394) connection. so if your computer has an ieee1394 card and you have a compatible ilink cable,then your good to go,it should be a plug-and-play connection (no drivers required). all you need then would be a video capturing software (like win moviemaker) to transfer videos from tape to PC. hope this helps. thanks :)
SOURCE: how can i install my aiptek pocket dv 5100m as a webcam that my driver is gone
http://www.aiptek.com/Supports/Driver/ for some operating systems.
SOURCE: Aiptek Pocket DV T8 Starter
l bought this camcorder and ir has no manual so l dont no how to use it to its full potential
