Question about Taco Inc. WAGS7200 Shuts Off Water, Gas, Oil, Electric
My upstairs air handler is not getting hot water from my oil fired Liberty Slant Fin model L30PT. I bench tested the Taco pump on the air handler and it works fine. The downstairs heat works just fine also. There seems to be no pressure going to the air handler/coil upstairs in the attic.
  • 2 more comments
  • petlor_2000 Nov 06, 2010
    If the pressure relief valve is bad, would that explain the 0 psi reading on the gauge for the oil burner?
    The furnace has 0 psi. Could the expansion tank be the culprit for not having any water pressure to my attic air handler?
    I was told by another fixya expert that it may be the fill valve or pressure relief valve.
  • petlor_2000 Nov 07, 2010
    I traced the well water inlet pipe to the furnace and could not find a pressure reducing valve.
    Could the valve be after the hot water leaves the boiler? There are two Taco valves that have screw in tabs on top. The tabs are seated all the way down. Are these the pressure reducing valves?
  • petlor_2000 Nov 08, 2010
    Traced the piping from the well (40 psi at the well). It goes directly into the furnace via a 1/2 inch pipe. There is a wheel valve on the pipe and it is wide open.
    The pipe underneath the the bolier that supplies the hot water T's and one side goes to the air handler next to the furnace (this one is 160 degrees) the other part of the T travels to the air handler up in the attic. This pipe is cool at about three feet from the ground. The furnace still is reading 0 psi yet the downstairs heat is fine.
  • Taco Master
  • 43,501 Answers
You have a problem with your fill valve or pressure reducing valve...it is not uncommon for these valves to plug up or fail to work right.... this valve's job is to maintain 12 psi in your system.
If you do not have enough pressure it will not push the water to the upstairs air handler...
You also will then need to get the air out of the pipes for the pump to work right after getting the pressure problem fixed...
Here is a tip that will help you with that also...
Valve Pressure Reducing or Pressure Reducing Valve
heatman101
Posted on Nov 06, 2010
  • 2 more comments
  • D. Floyd Kolb
    D. Floyd Kolb Nov 06, 2010
    The inlet to the valve may just be clogged....or the valve may be stuck...it is hard to tll as both happen very often...
    And if you go to look for the part ask for a "pressure reducing valve" and not a "relief valve" as they are two very different things...
    But yes I think that the pressure reducing valve or fill valve is bad and that is why you have that 0 pressure reading...it should be between 12 -20 PSI pressure at all times...
  • D. Floyd Kolb
    It is NOT the expansion tank... that would create a differnt set of symptoms...
  • D. Floyd Kolb
    Just an FYI if it was the "pressure relief" valve then you would have a steady flow of water running from the pipe off of the relief valve out of your boiler...
  • D. Floyd Kolb
    D. Floyd Kolb Nov 07, 2010
    It is possible that all you have is a valve to let water into the boiler and that their is no pressure reducing valve... Some contractors will skip that....to save money...
    But you do have to have a fill of some type to get water into the system....it may be a ball valve or a regular valve....
    It will probably be a small 1/2" pipe that goes into the boiler piping at some point.....trace the well piping to see if any pipes go from it to the boiler....then open the valve to get at least 12 psi in the boiler...
Taco circulator
Is this for a hot water system? If it is, u might have air in the system.
Mar 04, 2014 | Taco 007-F5-5 Cartridge Circulator Pump,...
Taco 007 not working
If the motor is getting warm I would suggest replacing the Cartridge assuming all the air is out.
Jan 23, 2014 | Taco Cartirdige Circulator Model 007
Hot water is not staying hot
Is the control that operates the pump located in the storage tank? If so the pump not be pumping. A few factors might be needed to solve the issue.
Dec 18, 2013 | Taco 006-B4 1/40 HP Bronze Circulator Pump
We had no heat in rads downstairs we changed pump and flushed system no we have heat downstairs but not up any ideas?
Make sure the air is bled from the upstairs rads.
[air = top of rad is cold & bottom hot]
If you need to balance the rads to maintain an even flow through all then :-
Turn off all rads [one valve fully open and the other closed] Get heat going and open each rad valve, in turn, about 1 or 2 turns. Start with upstairs. The position you need to get to is when the return pipe fron each rad is a few degrees below the flow pipe. Adjust each rad valve to get this effect a few times may be necessary
Mar 19, 2010 | Water Heaters
Blinking red light no heat
It sounds like you are actually in lock out. Recycle is when during a call for heat, the flame goes out, the unit will try to restart itself. Hope this helps
Nov 10, 2009 | Water Heaters
3rd yaco 006 in 3 years hot h20to hot
Taco circ. should be bronze in color for domestic applications. If it is green, it's wrong. Average temp for hot water should be 120 degrees. Overheating of circulator may be the cause of premature failure.
Mar 28, 2009 | Water Heaters
No heat in the radiators in the upstairs of our home.
Hi, What your looking for is called a (hy-vent). it bleeds air out of a system. you should have one on the top of your expansion tank. it is 1-1/2" in diameter and about 3" long. there is a little cap on top, unscrew the cap off. it looks like a bicycle tire valve. press the stem down inside until water comes out, then put the cap back on leave the cap loose so the hy-vent can do its job. it should be a self bleeder.
If this doesn’t work for you, please write back. Thanks,
Nov 19, 2008 | Water Heaters
Taco Inc. WAGS7200 Shuts Off Water, Gas, Oil, Electric Logo
146 people viewed this question
Top Taco Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Taco Water Heater Expert? Answer questions, earn points and help others
