Question about Gateway FPD1950
Gateway monitor model Fpd 1950
The logic board failed. Where can I buy it ?
I had the same problem as a result of messing with the menu settings. Experiment till it fixes, the controls are at the bottom of the Monitor, and you can operate them by vigorously dusting the monitor with the power on.
Posted on Nov 06, 2009
  • 2,794 Answers
It's probably cheaper to get a new monitor than it is to get a logic board. If Gateway can even get you such a thing.
Good luck on that.
Posted on Jun 15, 2008
Complete power failure on gateway fpd 1830 monitor on last bootup. no light on power button and nothing on screen . A fuse maybe ?????
Could be the fuse. But typically it is the caps on the output have failed.
Usually can find repair kits on e-bay and repair if you are experienced.
Nov 04, 2013 | Gateway FPD 1830 18.1" Flat Panel LCD...
I turn on my monitor and its just a white screen, nothing pops up.
Just white glowing screen as shown here: http://s807.photobucket.com/albums/yy352/budm/LCD%20panel/ ?
If it is, then check the power supply caps, ribbon cable between the logic board and the LCD panel.
The panel may be bad due to blown fuse on the T-CON board or not getting the 5vdc from the logic board.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Jun 21, 2011 | Gateway FPD 1750 17" Flat Panel LCD...
Gateway fpd 2485 W looked like 60 cycle lines across
Power supply will be the first thing to check, see example of failed Gateway due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Mar 18, 2010 | Gateway FPD1975W 19" LCD Monitor
Where can I buy on line the inverter board for FPD 1830
eBay is probably the best and easiest source for this item.
Dec 28, 2009 | Gateway FPD 1830 18.1" Flat Panel LCD...
Monitor goes blank
I was thinking about your problem, I just had a similar issue and the problem is that the inverter or the power supply with an embedded inverter had gone bad.
The reason it goes black is because the inverter fails to provide power to the LCD Display.
The only way to fix this is to open up the FPD:
*note these are instructions for the most popular FPD 1730*
1.there should be four screws on the back --> plus two large screws that hold the FPD stand and the Monitor together.
2.Open the back by pulling the cover off
Remove 7 screws holding the frame and the power button for the LCD
3.Remove two screws through holding a silver cover and remove cables.(pinkwhite) (blackwhite)
Please note where they belong before removal**
4.On the edges left and right are two screws 4 total ---> remove and remove LCD off of frame**becareful because the backlight Damaging can cause severe damage to your LCD panel.
5.Choose your model
Your FPD has 3 boards (power, inverter(backlights) Logic Video)
replace the inverter with well known good one
Your FPD has 2 boards(Power with inverter on edges, Logic Video)
replace the power board with a well known good one
6.Then do steps 1-5 in reverse order(putting your FPD back together.
I hope this is significant help
Sep 11, 2008 | Gateway FPD 1730 17" Flat Panel LCD...
Gateway FPD 1830 18.1 in. Flat Panel Problem
Usually in these cases the power supply would be the issue, but you say the OSD window shows up clearly, So the LCD panel is good and the Power Supply /inverter depending on which your FPD has.
FPD 1830 should have 3 boards(logic, Inverter, Power) otherwise just 2(logic, power)
If it is super dim, the problem is the inverter. Or the Power Supply if the inverter is embedded
Otherwise what your issue is the logic board, if you can swap out that part for a good one, Chances are for sure that you will have a spanking new FPD working.
I've worked with these a lot. Im working on one right now.
I hope this helps
Wish you luck
Victorsinferno45
Sep 11, 2008 | Gateway FPD 1830 18.1" Flat Panel LCD...
Gateway FPD 1830 LCD Monitor
User "noclew1"
Your problem is the back lights are not being powered. There is a signal going to your FPD because the power light remains on, but the back lights are what helps support an image from the Front Panel Display.
The only way to fix this is to open it up.
If its got 3 boards inside((logic-->video, Inverter, Power)) The problem is the Inverter. Replace it.
If its got 2 boards inside ((Logic-->video, Power)) The problem is the power supply. The inverter is embedded onto it.
Simply replace the part with a known good one, and you got a spanking new monitor.
As for User Guest
Your issue is nearly the same issue when it turns off on you. But the doubling effect is from the power being supplied by an old or weary power outlet to an FPD. That can be the cause. Try different locations.
Well I wish you both luck and I hope this solution can help you with the problem.
Thanks
Victorsinferno45
Aug 30, 2008 | Smart Modular PYXSCAPE SV1170 17" Flat...
Monitor screen displays sideways
if the screen is rotated then press
ctrl + alt + up arrow
your screen will be placed correctly
this is happened because sometime you might have pressed by mistake ctrl + alt + some arrow key .....
the hot key will be enabled defaultly so your screen got rotated
Jul 05, 2008 | Gateway FPD1950
No Power On at all
What it sounds like is the Power supply on your FPD is bad. If its making a High Pitch Sound, A circuit or piece of your power supply is failing. It would need to be replaced in order to get it working.
Suggestion.
You can repair this easily if you have another FPD 1730 lying around that doesnt work you can replace parts, but its best if they were made around the same time because certain models have 3 boards(video board, inverter, power supply) But most have two boards (power supply, video card)
They are easy to replace and maneuver if you want to give it a try. Open the FPD and see what kind you have. If anything you might be able to find a part online.
Good Luck,
I hope this helps
victorsinferno45
Jun 07, 2008 | Gateway FPD 1730 17 in. Flat Panel LCD...
Gateway FPD1950 Logo
233 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
