Question about MagLite Mag Lite® 2x 'd' Battery Flashlight In Display Box Black Case
New batteries, bulb looks fine, no light-what gives
  • 116 Answers
Hold the glass part of the bulb, and twist the metal base. there may be a break there. good luck, hope this helps.
Posted on Nov 06, 2010
Hi.. my 06 r6 headlights dont work... everything else works fine.. and its not the bulb.
Their is a fuse box next to the battery that has a few fuses in it and a few extras. Bulbs fail often though and a bad bulb can look good. If you touch the lens of the bulb with your finger the oils in your skin can make even a new bulb fail in a few seconds. With a test light cannected to the battery ground( negitive) ( a test light is a tool that looks like an ice pick with a wire coming out the end of the handle with a clip on the end, the handle is clear and has a bulb inside, with the clip connected to ground ( metal of the bike or car or the neg of the battery the light will light as the tip is touched to a pulg or wire thats live with power, if you connect theclip to power then the light will light as the tip is connect to a good ground) With the key on touch the lioght to the plug and it'll light on the terminals that are live with power then connect the light to power and see the terminals that are ground ( you ned both for the light to light) The high beam low beam switch can be open and the wires going to this swich can be tested the same way. f the bike has hit some hard bumps or other hard licks their may be a wire disconnected and looking at all the wiring and unpluging and replugging these connectors can find the problem as dirt or crosion can get into the plugs and get thingsa working.
Jun 24, 2011 | 2006 Yamaha YZF-R6
How to change head light lamp on a Saturn S-Series SC2
Purchase the replacement light you need from an auto parts store. Give them the year and particular Saturn S Series model number to acquire the right part. Also indicate whether you need the high or low beam light bulb, as some S Series models require separate bulbs.
  • Turn off the engine. Pop the hood and secure it open. Disconnect the battery cables from the battery by grasping the cable and pulling it straight off of the positive and negative battery terminals.
  • Position yourself in front of the headlight you wish to repair. Look behind the headlight assembly to find the wiring harness for the headlight assembly. Lift the locking tab, grab the wiring harness and pull the wiring directly away from the assembly.
  • Grab the old headlight bulb, twist it counterclockwise and pull it out of the headlight assembly. Replace it with a new bulb and secure it by turning it clockwise.
  • Reconnect the wiring harness to the headlight assembly and reconnect the battery cables. Test the lights to see if they work properly.
  • Thanks
    May 22, 2011 | 2000 Saturn SC
    I have a 94 ford probe, The radio works when it wants to.. but the prblem is the tail lights and dash lights went out about a week ago, Checked all fuses in car and under hood checked all light bulbs all...
    You need to replace headlight switch - if fuses, bulbs, wiring looks good. Avoid the toggle switch idea, you'll be opening a whole new can of worms.
    Mar 01, 2011 | 1994 Ford Probe
    Have Cooper lighting outdoor motion detected flood
    Sounds like the relay in motion sensor. Change the bulb. Rechargeable batteries are no good after 3-4 years also.
    Jul 18, 2009 | Desa International 240 Deg. White Twin 150...
    The boot light will not work even with a new bulb
    Fast solution:
    Assuming all fuses are OK.
    Check the filaments (look for a broken filament wire) in the old bulb to make sure it's a bulb problem. If the old bulb is truely defective, check the new bulb to make sure it does not have a broken filament. If the bulb looks OK, take a look at the socket to make sure that it is not rusty or corroded. If the socket contacts are not clean, take a small piece of fine sandpaper and clean both the center contact and the inside of the socket.
    If you have tried these things, and the light still does not come on, you'll have to do a continuity trace of the wiring to fine where the power to the bulb is being interrupted.
    Jul 13, 2009 | 2004 Ford Fusion
    Rechargeable maglite won't turn on.
    I found out the light bulb was bad even though it looked good. Had a fine break in the filament that I couldn't see with my eyes. Pulled the light bulb part way out, put a voltage meter on the two prongs. It showed I had voltage right up to the light bulb which told me the light bulb was bad. Ordered a new one and it works.
    Dec 22, 2008 | MagLite - Mag Charger System 110v (M)...
    Headlight replacement instructions
    Release the hood latch inside the Rodeo. Raise the hood and look down behind the headlights. The old bulb and assembly are held into the headlight from the back side of the the headlight. There is not a great deal of room to work behind the headlight because of the battery on the passenger's side and the air cleaner box on the driver's side.
    Grip the large round plastic nut with your hands and give it a quarter turn counter-clockwise. Carefully remove the head light and plastic nut. Look for the release lever to depress and pull on the old bulb at the same time. It will unplug very much like your computer power cord. Be careful not to drop the plastic nut.
    Now plug in the new bulb and replace the plastic nut. Carefully insert the bulb into the headlight and give the plastic nut a clockwise quarter turn and try the new light.
    I just replaced both of my headlights last night and I am an accountant.
    Oct 20, 2008 | 1999 Isuzu Rodeo
    WS3 Broan Allure Range Hood Premier 36 inch
    Hi shealy,
    I'm Harvey the Master Plumber.
    Your problem is: This hood worked fine until a light bulb blew out. Put in a new light bulb, but the lights will not turn off. Is the light switch bad or is there a problem with the control panel? The fan still works fine but the lights will not turn off or adjust dim or bright.
    You're on the right track. The light control switch needs replacing. You might try utilizing the Repair Directory to find a repairman. If you have the tools and ability just remember to turn off the electric first.
    Feel free contact me again!
    Please give me a rating here at fixya.com before you sign off
    Thank you,
    Harvey your Master Plumber
    Sep 08, 2008 | Broan-NuTone WS330 Kitchen Hood
    MagLite Mag Lite® 2x 'd' Battery  Flashlight In Display Box Black Case Logo
    122 people viewed this question
    Top MagLite Camping, Backpacking & Hiking Experts
    John Egan
    John Egan
    David Black
    David Black
    Level 1 Expert
     steve
    steve
    Are you a MagLite Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
