Question about Tappan TGF320 Gas Kitchen Range
Turne the oven in F31 IS ON - Tappan TGF320 Gas Kitchen Range
  • 794 Answers
Hi maideescobar,
You need to check the temperature sensor. You need to open the temperature sensor (RTD). Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Hope this helps.
Thank you for using FixYa.
Posted on Sep 19, 2011
I cant get my oven to stay on model # FFEF3015LSM after a few minutes is turning oven on, it starts to beep and screen says F30
It looks like the probe is the same as the temperature sensor.
On some models, you can recalibrate the oven control up to 35 degrees Fahrenheit higher or lower. Refer to your owner's manual for instructions on how to recalibrate the oven control.
Since you're getting an error message the following may apply:
OPEN PROBE CONNECTION
1. (F30 or F31) Check resistance at room temperature & compare to RTD Sensor resistance chart. If resistance does not match the RTD chart replace RTD Sensor Probe. Check Sensor wiring harness between EOC & Sensor Probe connector.
SHORTED PROBE CONNECTION
2. (F30 or F31) Check resistance at room temperature, if less than 500 ohms, replace RTD Sensor Probe. Check for shorted Sensor Probe harness between EOC & Probe connector. .
Possible Replacement Part:
http://www.repairclinic.com/PartDetail/Frigidaire-Range-Stove-Oven-Temperature-Sensor/316490000/1197392?modelNumber=FFEF3015LSM&fromRepairHelp=True&ss=a13b2d1284938
Mar 24, 2016 | Ovens
F31 on my Frigidaire oven how do I fix it?
Good Afternoon friend, thanks for your post!
Based off the information you have been able to provide an "F31" error code stands for a shorted probe connection. Typically this means you could have issue with the RTD (resistance temperature detector) sensor probe or the wiring harness between your control panel and probe connector. Since it could be any one of these under lying issues I would recommend a professional come out and properly repair your appliance. Hope this helps. -Matt
Sep 17, 2014 | Frigidaire Kitchen Ranges
F31
If the cooling fan is constantly running then means thermal overload probably faulty, it has failed in closed position.
Best to get an engineer to help
warmest regards
Richard the Repairman
Mar 30, 2014 | Bosch HBL 455 Stainless Steel Electric...
Oven does not turn on
Hi! My gas oven is not turning on yet the burners work. When I try to set the oven to bake there is a beeping sound with a digital message that reads F31????
Jan 14, 2014 | Ovens
Oven wont start, shows F31 error on display
What is the complete model number of the unit?
Dec 04, 2012 | Washing Machines
When I try to turn on oven the code F31 shows
Hi and welcome to FixYa,
I am Kelly
See this link:
http://www.applianceaid.com/faultcodes3.html
Scroll down past mid page and read F31
Your Temp probe is shorted. It shuld read around 1091 Ohms (+or- 5.3 Ohms) at 75 Deg.
If you respond with your model number I can point you to parts sources.
Thanks for choosing FixYa,
Kelly
Aug 29, 2011 | Frigidaire Kitchen Ranges
Oven shows error F31 when trying to bake
F31 - Shorted Temperature Probe connection
Check the sensor probe connections for damage. Make sure it is plugged into the socket, all the way, when the oven is in use. If the connections are sound, and not separated from their respective contacts, replace the temp probe.
Dec 15, 2009 | Frigidaire Kitchen Ranges
F31 error
it is a shorted oven probe sensor
Apr 09, 2008 | Ovens
Tappan TGF320 Gas Kitchen Range Logo
135 people viewed this question
Top Tappan Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Sal DeAngelo
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
