My modem wont recognise my router - Computers & Internet
    Problem Solver:
  • 10 Answers
Certain modems have prepharial factures, buy one that works with the type of modem you have
Posted on Jun 15, 2008
Router won't recognise my new Kindle
First try rebooting the router to see if it "see' the kindle. Make certain use are using the correct network password/key - it is case sensitive. Does the Kindle connect to other WiFi networks? If not the Kindle may be the issue
The ultimate answer is a factory reset of the router.
Dec 16, 2011 | D-Link ADSL2/2+ Modem/Wireless Router...
Setting up a new laptop & router, followed instructions, laptop recognises the router but the router will not connect to the internet, orange light flashing on top of the router
The modem most likely need to have its power cord unplugged for about 15 minutes in order to allow its NVRAM to clear and accept the MAC address of the new router.
After the 15 minutes are up, plug in the modem and let it sync to the network. Your router should start to work soon after.
Dec 30, 2010 | Belkin Surf N300 Wireless Router...
I have a Belkin N+ router and I am trying to use the USB storage sharing feature. I have a WD HDD mounted in an Ultra external enclosure. When I plug the HDD into the router, the storage LED on the router...
it says the HDD is not compatible with the router.... it might be due to the file system in HDD....
At this moment, the Belkin N+ Router and Modem-Router, F5D8235 and F5D8635 work with the FAT, FAT32, and NTFS file systems only.
Versions of the F5D8235 firmware earlier than 1.01.24 may fail to detect a drive that contains a mix of supported and unsupported file systems. This was fixed in firmware 1.01.24, available from the Belkin UK Support Site
We have seen a few compatibility problems with drives not being recognised and we are investigating these to get them fixed.
We have also seen occasions where a drive was not detected by the router or modem-router due to a poor quality USB cable. If a bus-powered drive does not spin up, the first thing to do is to make sure that a good quality cable is used. Even self-powered drives may fail to be recognised when using poor quality cables. Even though the cable may work when the drive is connected direct to a PC, always try a different (good quality) cable as part of troubleshooting drive detection problems.
Tech Support: If you come across a drive that is not being recognised by the Router or Modem-Router, please check on the hidden page if the router has detected anything at all. Make sure that the drive works when connected directly to a Windows computer and try a good quality USB cable as mentioned above.
Apr 24, 2010 | Belkin F5D8236-4 Router
Hi my name is tam. I am using the Net gear WGR614 v5 and my laptop is using window 7. But i can't connect to internet via the wireless rounter netgear. The internet light was on but the wifi light is keep...
Make sure that your computer is able to go online through the modem.
If your computer is not able to go online through the modem then you will need to call ISP first.
If your computer is able to go online through the modem
then you need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Apr 23, 2010 | NetGear WGR614 Wireless Router
I am trying to connect netgear wireless router it is not recognising my motorola modem? i do not have disc to reinstall hardwear from modem
You don't need a disc to set up the router.
it depends on the ISP. It's very simple !!
Click Here for more info about how to set up router
Oct 11, 2009 | Arris SBG1000 Wireless Cable Modem Gateway...
Laptop dosent recognise perlico router
Hi Newross,
Is the dsl light is on the modem, no, if not , you need to login into the modem to switch on the wireless on the modem.
Just tell me what is the make of your modem i'll tell you how to actv wlan or elase ring your bb support.
May 15, 2009 | Zyxel P660HW-D1 Router
Cant get new router to work
You must enable first the Ethernet connection on your modem before your new router can allow to access the Internet by Ethernet.
Mar 06, 2009 | Computers & Internet
I want to run a laptop via a zoom router off the same modem I use for my computer which is cable.I cannot get the laptop to recognise the router
pl set the ips , thn connect the ethernet, see if the net icon says ethernet connected,ping the ips including self ping,if unsuccessful chech ips , if successful, ping modem , if unsuccessful check router, ifsuccessful , connect to internet.
Nov 28, 2008 | Computers & Internet
Can connect via the enthernet cable but wont go wireless..
1) Check your wireless network card to make sure its configured correctly and working properly.
2) If you're trying to get access thru a laptop be sure that your wireless network card is ON
3) Check if your wireless network is available to connect.
Oct 21, 2008 | D-Link ADSL2/2+ Modem/Wireless Router...
2wire not finding broadband connection
I have tried also in the past, to set up a connection with this make of router with an ISP other than the ISP that supplied it and i was not able to get it to connect as i think the firmware is set to only recognise certain ISP IP addresses or MAC settings.
Aug 10, 2007 | 2wire (1000-400108-001) Router
Computers & Internet Logo
David Payne
David Payne
