Question about HP OfficeJet J4580 All-In-One Laser Printer
'My All-in-one will not print and is showing the following message in the display window: "print cartridge problem: Black". I have tried turning on/off and reloading the cartridge. This is not an issue of running out of ink. I am very grateful for any suggestions!
    Director Badge:
    Uploaded 100 video answers.
  • HP Master
  • 685 Answers
  • amanda_dewal Nov 10, 2010
    Thank you!
  • Ben Johnson Nov 10, 2010
    You're welcome. If that helped, will you give this solution a rating so other people know if it's a solution they should try?
How to clean HP 3110. Print failure. Shows black as "?" as not authentic HP cartridge when it is.
try to reinstall black cartridge ,and clean contact as the follow picture
if still the problem try the next step
1. Unplug the power cable from printer while the printer is powered on.
2. Press and hold Plus (#) and 6 while plugging in the power cord. This will perform a maintenance cycle. I did this twice but no joy. BUT THE THIRD TIME WORKED!!!
Print a self test by pressing "Setup" and then 1, then 1 again.
Mar 04, 2013 | HP Photosmart 3110 All-In-One InkJet...
I have Lexmark X125 and get message "Check Cartride" I put a new Black Cartride in and get message " None Changed" Printer won't print. What can I do?
What is the black cartridge version that you are using on your Lexmark X125 printer? If you are inserting a photo cartridge on your printer, please follow these steps: 1. Remove the black cartridge and insert the photo cartridge. The printer LCD screen will display CARTRIDGE? NONE CHANGED. 2. Press the Options button to select NEW RIGHT and then press Start. The printer LCD screen will now display RIGHT CARTRIDGE? 3. Use the Options button to select the STD PHOTO cartridge type and click Start. An Alignment page will then print. When the Alignment page is fully printed, the LCD screen will display CARTRIDGE ALIGN. 15 [00-30] A , where - 15 represents the straightest line on the page; - [00-30] is the value range you can select from, between 00 and 30 - A represents the line in each section. 4. Use the numbers on the keypad to select the number of the line you think is the straightest. As you press the number, the LCD will change to the next line automatically. Select the number representing the straightest line in each section.
Source: How to Install the Photo Cartridge in Standalone Mode
May 10, 2011 | Lexmark X125 All-In-One InkJet Printer
Have an HP PSC 1510 printer. I put in a new genuine HP Tri-Color (93) printer cartridge as I usually do and the "Check Printer" cartridge started flashing. Also flashing on the printer is the...
Problem After you install a print cartridge, one of the following messages appears on the color graphics display:
  • Incorrect Print Cartridge
  • Incompatible Print Cartridge
  • Problem with the Print Cartridge
  • Remove and Check [color / black or photo] Cartridge
  • [Tri-color / Black or Photo] Print Cartridge Inserted Now is Not Intended for Use in This Printer
NOTE: In the procedures below, the "problem" cartridge is the one identified by the message on the color graphics display. If the message does not specify a cartridge, perform the procedures on both cartridges. Step 1: Remove, inspect, and reseat the problem cartridge The print cartridge may not have full electrical contact with the printer. Removing and reinstalling the cartridge may help.
NOTE: HP cannot guarantee the quality of remanufactured or refilled cartridges.
  1. Make sure the printer is on. Press the Power button if it is not lit.
  2. Open the printer cover, then wait until the print cartridge carriage is idle and silent.
  3. Press down lightly on the end of the problem cartridge to release it. Figure 1: Removing the tri-color cartridge
  4. Slide the cartridge out and inspect it:
    CAUTION: Do not touch the copper electrical contacts or the ink nozzles. Figure 2: Electrical contacts and nozzlesc00211537.gif 1 - Copper electrical contacts 2 - Nozzles
    • Check the electrical contacts for debris.
    • Make sure all the clear nozzle protective tape has been removed.
      CAUTION: Do not attempt to remove the copper electrical strip! Figure 3: Removing the clear nozzle protective tape
    • Look at the number on the print cartridge label and make sure it is compatible with your printer. Compatible print cartridges are listed in the Printer Reference Guide supplied with your printer.
  5. If the cartridge is compatible, reinstall it in the printer:
    • Cartridges marked with a triangle go into the left carriage slot.
    • Cartridges marked with a square or pentagon go into the right carriage slot.
Step 2: Clean the problem cartridge contacts
  1. Gather the following items to clean the cartridge and carriage:
    • Clean distilled water. Use bottled or filtered water if distilled water is not available. Tap water can contain contaminants that damage the cartridge.
    • Clean cotton swabs or any soft, lint-free material that will not stick to the cartridges (coffee filters work well).
    • Sheets of paper or a paper towel to rest the cartridge on during cleaning.
  2. Open the product cover and wait until the carriage is idle and silent.
  3. Remove the cartridge and place it on a piece of paper with the nozzle plate facing up.
    NOTE: Clean the contacts quickly so that the cartridge is not outside of the product for more than 30 minutes. If the cartridge is outside of the product for too long, the ink can dry and clog the nozzles.
  4. Unplug the product from the electrical outlet.
  5. Dip a swab in the clean water and squeeze it to remove most of the moisture. The swab should be only slightly damp.
  6. Clean the cartridge contacts.
    CAUTION: Do not touch the ink nozzles.
  7. Clean the contacts in the carriage, inside the product.
  8. Either let the cartridge sit for 10 minutes to allow the cleaned area to dry, or use a new swab to dry it.
  9. Reinstall the cartridge.
  10. Reconnect the product to the electrical outlet.
  11. Close the product cover.
Step 3: Repeat reseating and cleaning steps If the problem is not solved, repeat the reseating and cleaning procedures above.
Call HP if the cartridge is covered under warranty to replace the cartridge
or its time for a new printer
Apr 04, 2011 | HP PSC 1510 All-In-One InkJet Printer
Hi Ya! I was looking out for the solution of the Epson 1400 printer having black toner shows pop-up message; which displays "Consumables near end of service life". "Prepare the following...
If a consumable product reaches the end of its service life, the product stops printing and displays the following messages in the LCD panel or the window of EPSON Status Monitor 3. When this happens, the product cannot resume printing until you replace the depleted consumable products.
The photoconductor unit comes to the end of its service life. Even if this message is displayed in the LCD panel, you can continue to print for a short time by pressing the B&W Start or Color Start button on the control panel. The message in the LCD panel changes from Replace Photoconductor to Worn Photoconductor.
Mar 22, 2011 | Epson Stylus Photo 1400 Printer
Windows Ink Cartridge Empty false error message.
slowly off and on the printer for five times without cartridge, printer saves data of cart of last 5 only so next time it reads full ink..
Oct 28, 2009 | HP C6280 All-in-One Printer
Hp psc2410xi
The following error message appears on the color graphics display after you insert a cartridge: Remove and Check Print Cartridges . The printer will not print. The message does not specify which cartridge has caused the error. Solution This error message indicates that the printer cannot determine which cartridge is causing the error. Follow the steps below to solve the problem.
  1. Remove the color cartridge from the left stall (which has a blue latch) and refasten the latch. Leave the other cartridge in place.
  2. Close the printer, wait 10 to 15 seconds, then look at the LCD display.
    • If the LCD display reads Insert Color Cartridge in Left Stall , the color cartridge may be causing the problem. Follow the steps below:
      1. Clean the color cartridge contacts.
      2. Reinsert the color cartridge into the carriage and close the blue latch.
      3. Close the printer and wait 10 to 15 seconds.
      4. If the LCD display reads Remove and Check Print Cartridges , replace the color cartridge.
    OR
    • If the LCD display reads Remove and Check Print Cartridges , follow the steps below:
      1. Reinsert the color cartridge.
      2. Remove the black or photo cartridge, depending on which one is installed in the right stall. The right stall has the gray latch. Be sure to refasten the latch on the empty stall.
      3. Clean the black or photo cartridge contacts.
      4. Reinsert the black or photo cartridge.
      5. Close the printer and wait 10 to 15 seconds.
      6. If the LCD display reads Remove and Check Print Cartridges , replace the black or photo cartridge.
  1. Remove and then reinsert the cartridge indicated in the error message.
  2. If the error is still displayed, clean the contacts.
    1. If the error message is Error. Remove and Check Black or Photo Cartridge , the following steps may help:
    1. Remove both cartridges, lower the latches, and close the printer access door.
    2. Turn off the unit by pressing the On button on the front panel. Wait for the printer to completely shut down.
    3. Turn the printer back on by pressing the On button.
    4. When the message display reads Insert Print Cartridges , open the access door and replace the cartridges.
    1. If neither of the steps above fixed the problem, either the cartridge or the printer is faulty
    Aug 12, 2008 | HP LaserJet 5L Printer
    Bought today a hP7200 All-inOne Series. Set up and received the following: Error message "Incorrect Ink Cartridge: The following ink cartridges cannot be used after device initializaed and must be...
    hi friend
    try remove your printer cardige & rinstall it if u have not remove your printer cardige nosel raper so remove tape of the nosel try to install & print
    Apr 13, 2008 | Office Equipment & Supplies
    HP OfficeJet J4580 All-In-One Laser Printer Logo
    48 people viewed this question
    Ben Johnson
    mukhtar21 shaikh
    mukhtar21 shaikh
