I bleed my raditors,but no air or water came out ,,,plus no heat from 2 raditors,,,
  • 43,501 Answers
You have a problem with your fill valve or pressure reducing valve...it is not uncommon for these valves to plug up or fail to work right.... this valve's job is to maintain 12 psi in your system.
Here is a tip that will help you with that also...
Valve Pressure Reducing or Pressure Reducing Valve
heatman101
Posted on Nov 06, 2010
Over heating
If you are sure you have done it all then it islikely you have a leaking head gasket.
Mar 24, 2014 | Cars & Trucks
When i put it in reverse it dies and has been running hot
possible air trapped in water jackets, need to bleed air out
Nov 24, 2013 | 1997 Ford Taurus
I have a vaillant ecotec plus 630r1 system boiler, since two weeks ago the central heating part of it is causing problems. Even when i put the heating dial on max most of the rads would not get hot and...
You either have a bad circulating pump or you have air in the system. A little bit of air can completely stop water flow in a boiler system. Your problem is more than likely air though. Each radiator should have an air bleed on it. Turn your boiler completely off. Go to each radiator and open the air bleed. It will be located towards the top of the radiator. After air is bled out, close the air bleed and go to the next one until all have been done. If you have a two story house, start at the lowest level of radiators. When you are finished start the boiler back up and let it run for about 2 to 3 minutes and shut it back down and bleed all the radiators again. If you are making progress and getting more to heat up but not all of them yet, keep repeating process until all of them heat up.
Jan 30, 2011 | Heating & Cooling
I have a 2003 Pontiac Grand AM..Headgaskets replace with headwork. new themstast..new water pump...new raditor cap still overheating
Flow test the radiator, and look for air bleed screws, at higher places on your engine. Also, heater on high when filling or topping up the rad....or major air is heater circuit.
Jun 30, 2010 | Pontiac Grand Am Cars & Trucks
Not shure if I should replace the thermostat or water pump in my 03 chevy s10
If water pump leaking replace both, if not and truck is over heating start with thermostat.
May 13, 2010 | 2003 Chevrolet S-10
Air in water line how to bleed out
the frig ha a plastic resivor that has air in it
you can bleed the line by continuing to use the water dispenser and diverting it into a pitcher
you can make a transfer funnel etc out of tin foil should not take more than 2 containers ( 1 /2 gal each)
Dec 11, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Boiler unit
In a hydronic system for heating you must insure that the pressure on the boiler is maintained during the process of bleeding off the air from the system. There is a regulator for the water make-up to the system which normally maintains 12 PSI with the boiler cold. If this is stuck or fails to open you will loose the pressure on the system when bleeding the air off. Most are adjustable. Loosen lock nut on the adjustment stem and turn the screw (clockwise) to increase the pressure. Count the turns as you adjust it and return it to the original setting when you finsh bleeding off the air.
Oct 30, 2008 | Heating & Cooling
Heating & Cooling Logo
65 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
