Question about Echo CS400 18" Chain Saw
I was cutting at full trottle and saw stopped, tried restarting and cord would not pull. took cover off to check and cord assembly works fine but the part where it attaches to would not move
  • 116 Answers
Chain may have been too tight. or the kickback bar is locked. good luck. hope this helps.
Posted on Nov 06, 2010
How to fix my Tanaka chainsaw rope to recoil back?
replace teh recoil section as there is a problem with the spring or the pulley section holding the cord.
Apr 26, 2015 | Tanaka TCS33EB/14 32 cc Gas Powered 14-in...
Makita JR3000V stopped working
I would have checked the cord first. Cords are a high failure part because they always get bent and pulled and such. Some versions of the jr3000v had problems with field wires breaking right at the field terminal.
Mar 05, 2012 | Makita Saws
The saw was working fine. I shut it off. When I attempted to pull the cord to start it again, the cord would not retract. I removed the cover, disassembled everything related to the cord. Made sure the...
Many of these small saws have what is reffered to as an e start, the section that engages to the flywhell is seperate to the rope pulley, and is joined via a round coil spring, the idea is to soften out the compression and help to spin the engine over when cranking, one end of the spring fits into the outer flyheel engagment pinion, the other ends fits into a hole in the starter cord pulley, it does not fit into the main recoil spring, the securing screw for the assembly is a shoulder screw the idea is not to pinch the rewind mechanism when tightened, as this only screws into plastic it is very easy to over tighted and make the pulley post swell and stop the pulley rotating on the shaft, you may now need to leave the screw just a little slacker, the black plate under the starter is a conductor plate, this helps blow the cold air from the flywheel over the cylinder, this plate should always be there. When assembling the starter on the saw, keep pulling the rope as the cover goes on, this will ensure the pinion engages properly with the flywheel pawls.
Feb 19, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
My Craftsman Series 550 Lawnmower was working fine and I decided to check and clean the airfilter and carburetor. When I tried to restart the pull cord is stuck and won't allow me to pull it. I have...
i suggest you pull the housing off for the pull cord and see if it pulling fine if it does see if the brake is of on the motor i would bet the brake is not releasing
Jul 17, 2017 | Craftsman Garden
What is h and l screws for we have been moving them around to try make the saw tick over as it keep cutting out
"H" is high speed and "L" is low speed. Turn both screws in full, then unscrew them one and a half turns each. Start the saw, you may have to adjust the trottle screw to keep it running.Then adjust the "L" screw a little, in or out, with the trottle screw until you are happy with it ticking over. then adjust the "H" screw to get it to run full. You need time and patience. Stephen.
Sep 24, 2010 | Husqvarna Chain Saw 20" Bar
Chain saw chain stopped moving
Was it running and shut down and was froze or when you went to restart it was frozen? Two things I have seen cause this other than a seized engine. One - chain bound up. Remove side cover and inspect chain mechanism. Two- the pull cord is bound up. Remove the pull cord cover and inspect.
Jun 15, 2010 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Renew pull start cord
Go to smalleng.com they have video on how to do what you need. Check it out awesome website!
Nov 24, 2009 | Husqvarna Partner Gas Powered Cut Off Saw...
Husky 372 xp stopped working?
you need to check to see if the piston is scored.pull the muffler off the saw and look inside.the piston is right there.if the piston is scored all you can do is change the piston and cylinder assembly.if the saw is new it might be under warranty.check with who you bought it from.most saws have a one year for consumer use.....let me know if this helped...................
May 15, 2009 | Husqvarna Garden
Poulan wild thing recoil froze up
You may need to replace the recoil assembly, check with poulan for availability.
Sorry I couldn't be of greater assistance.
Apr 17, 2009 | Garden
Echo CS400 18" Chain Saw Logo
138 people viewed this question
Top Echo Garden Experts
Jim Parker
Jim Parker
Mike
Nick Olsen
Are you an Echo Garden Expert? Answer questions, earn points and help others
