Question about Porter Cable C2002 150 Psi 6 Gal Compressor
C2006 Type 4 Porter Cable will pump from 50# to 100# then will not pump any higher but will keep running.
    Scholar:
  • 146 Answers
This sounds like the piston ring is worn out and will not allow the unit to pump up to it's shut off pressure.
You can order the D30324 cylinder/ring kit and it should repair your problem.
You can order this at www.allpartsinc.com or go to www.msservice.net
Posted on Nov 07, 2010
Compressor is OK but tank may need replacement
have you tried to find a welder to repair the tank?
Aug 04, 2012 | Porter Cable Air Tools & Compressors
Porter cable C2006 compressor what tool do i use to remove motor cover
The screws used to hold the two halves of the motor cover together are torx drive or sometimes called star drive. They are a round, six point driver available at most tool stores and box stores.
Apr 16, 2012 | Porter Cable Air Tools & Compressors
Hi, I have a porter cable air compressor c2006, and bought it used and sometimes the motor is in limbo when it wants to rebuild air supply, so I have to pull the release valve for it to charge properly,...
indicates a failing start/run capacitor for the motor
as most small compressor do not have an un-loader for the start and the motor is strong enough to start with a reduced load when the controller switches the power back on
Nov 09, 2017 | Porter Cable C2002 150 Psi 6 Gal...
Porter Cable c2006 type 4 ari compressor contiuely runs. No leaks, never gets to 150 shut off pressure. Is it pistons or gaskets? Is there a way to tell by looking at parts if they are worn or not?
Check the pressure regulator, lower it at different settings, if it works at lower
pressures but does not go to its maximum pressure, its the regulator.
costs about 25 dollars and may be less if you shop around. good luck!
Jul 10, 2011 | Garden
I have a Porter Cable 352VS Type 4 sander needs bearings.
You need special pullers for these, you will have to take it to a power tool repair shop.
Jan 26, 2010 | Porter Cable 3" x 21" Electronic Variable...
Operating manual for C2006 Type 4
Sounds like the same problem. My compressor would run and pressurize to 125# but no air out the outlet. Turning the pressure reguator knob did nothing. If this is the same then here is my fix which worked great. Before you start bear in mind a new reg is under $20. Make sure the compressor has no air in it. Remove the regulator. Take a needle nose and remove the plastic insert gently from the bottom and inside of the reg. Take out the pressure spring. You should see a threaded shaft and a "c" clip. If there is no washer on the end then what is taking place is when you turn the knob in for more pressure it simply goes down through the center of the spring and exerts no pressure on the plastic insert which applies pressure to the valve. Thus no pressure. I simply removed the "c" clip, placed a generic washer placed on the end. The hole of the washer should allow it to sit on the end of the threaded end without going down the shaft and center protruding an 1/8" or so. Naturally the washer should easily fit inside the regulator housing. Now slip the "c" clip back on, back it out the knob all the way( don't force) and reassemble. Have no idea what is suppose to be in there from the factory but the problem was when I took mine apart there was nothing pushing on the spring which pushes on the nylon plastic insert which regulates the air at the outlet. Good Luck Bob F.
Oct 20, 2009 | Porter Cable Air Tools & Compressors
Compressor air leak
hi first we have to find where the leak is comming from ,so you will have to remove the cover,secondly is the leak just from an external fitting?if so then you can see the problem and a simple adjustment or removal to re seal can be done ,if the leak appears to be from the pump head joint then the head will have to be removed and a replacement gasket fitted however i reccomend that if this is done then a new valve set be fitted at the same time
hope this helps ian
Dec 27, 2008 | Air Tools & Compressors
Porter Cable C2002 150 Psi 6 Gal Compressor Logo
202 people viewed this question
Top Porter Cable Air Tools & Compressors Experts
John Trevino
elunsford
Are you a Porter Cable Air Tool and Compressor Expert? Answer questions, earn points and help others
