Question about KitchenAid Ovens
KitchenAid oven model KGRT507 - oven flame on side of bottom pan is way high comes out side of pan cover, just replace gas valve & regulator. What is my problem? TY
SOURCE: high flames in oven
Flame saftey device control valve stuck in open position that why main gas is coming other wise flame should be max 2cm long after flame saftey device heat up and bellow expand and main valve should open
Posted on Nov 07, 2008
jumptrout51
  • 3361 Answers
SOURCE: Replaced gas safety valve, burner flame now too hot
Take a 1/2 inch open end wrench and tighten the orifice on top of the safety valve.Probably about 2 turns. Then adjust the air shutter to mostly open.
Posted on Mar 26, 2009
  • 126 Answers
SOURCE: maytag gas oven wont restart after pre heat
you have a bad oven sensor /faulty connection or bad control board.look for probe coming thru inside rear wall.should read 11k ohms cold.go bad a lot part number Hope this helps ,please rate my response :)
12001655
Posted on Jun 25, 2009
SOURCE: Hello. I have an old Roper oven, model no.
I have the same problem, bad ignitor on model 1068106 but do not have a part number or a manual. Could you send a part number?
Posted on Jul 12, 2010
  • 494 Answers
SOURCE: I have a GE Spectra XL44, model #JGBP40BEC4WH gas
Most likely, you're oven igniter is not getting hot enough to open the gas valve to ignite the burner. It glows like normal, but does not reach the temperature required to open the gas valve. Replace the igniter. Before you replace that, make sure that the small shutoff lever on the appliance regulator was not accidentally closed, which would turn off the gas to the oven, while still allowing gas to the stovetop. The silver lever should be sticking straight out or up. Douglas
Posted on Sep 12, 2010
I have a kitchenaid model kgrs505xss double oven. The flame in the bottom oven comes on and burns for a very short time, then turns off before the oven comes up to temperatures. What is wrong?
Any gas cooker has a thermocouple that keeps the gas valve open; if the thermocouple no longer generates current (which feeds the coil of an electromagnet) then the gas valve closes and the flame will go out. So check thermocouple. In normal conditions the voltage generate by the thermocouple is low but the current is high.
Nov 14, 2017 | KitchenAid Ovens
The oven burner will not ignite.
Because the glowbar is glowing does not necessarily make it good.
Turn off the gas to the stove. Remove the oven racks. Remove the bottom oven pan. Remove the flame spreader. This gives you access to the glow bar and gas valve.
Put a clamp on amp meter around one wire of the glowbar. Turn the oven control on to BAKE.
If the glowbar reads 3 amps or less,replace the glowbar ignitor.
If the glowbar reads good,check the burner tube for a white ash buildup. It can be cleaned with a wire brush. Look closely near the glowbar section of the burner.
Check all the wire connections for the gas valve.
If the glowbar is good and the ash deposits are gone and the oven still will not ignite,the next step is to replace the gas safety valve.
Dec 01, 2009 | Amana Ovens
A friend has a oven that has been coming on with a bang. I've cycled it on and off cold and hot no problems when I was there. Pulled the botten pan out (it is quite worped from heat and dosn't fit that...
a lot of iffy things could be happening here..
verify proper amperage draw through the ignitor.. i believe thats a 3.2-3.5 amp system but check the label thats on the gas valve, it will have the ratings listed on there for sure. make sure amperage draw is in the middle of the range as some gas valves are less tolerant of low amperage draw than others.
it almost sounds like your amperage load may be on the low side, just enough to open the valve regularly but not open fully..
its on its way out if so..
the popping could be the gas coming into the oven slowly enough to NOT blow directly across the ignitor properly, (igniting it instantly if it were) and allowing it to pool in the enclosure some because of the low amperage draw through the ignitor, eventually firing with a bang..
yes the regulator vent could be plugged, but another thing is if you are on bottled gas/lp/propane for your source of fuel the regulator at the tank could be faulty also, causing the pulsing flame..
hope this helps,
best of luck,
ttfn
Nov 02, 2009 | Jenn-Air Ovens
The ignitor draws amperage thru gas valve which opens the bimetal valve to release the gas.Round ignitor 2.75 amps. Rect. 3.5 amps.Bottom line if burner dont fire within 60 seconds of turning orange you have a weak/bad ignitor.Hope this helps.Please rate my response :)
Jun 20, 2009 | Ovens
Yellow flames causing carbon buildup
If the burner bar has an adjustable slider for increasing or decreasing air into the bar.That would be it. If not then there is a defect with the gas valve or burner bar.
May 30, 2009 | GE JGRP17 Gas Single Oven
Oven lights on low flame but will not come up on high flame .cannon chester cooker.suspect by pass is not working. Do I need control knob/thermostat with the phial. Thanking you.
all gas range ovens have a small metal box in the back upper area of the broiler burner; a gas line runs into this box as do two wires; this is a "flame control " gas valve; the way it works is: after the pilot has been lit as you turn the oven temp control a heating element in the box causes a small valve to open allowing a larger amount of gas into the oven burner to ignite the whole burner If you can only get pilot flame on high replace this valve
Apr 26, 2009 | Ovens
Oven burner flame is low
0000000.jpgOn top of that safety valve is a nut. Get a good fitting wrench. Turn on the oven and use that good fitting wrench on that nut. Turn it counterclockwise till the flame comes up about midways of the flame spreader. Don't get the flames too high. Midways of the spreader now. LOL
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 02, 2009 | Ovens
Lighting an old Frigidaire gas oven
Sounds as though the pilot light in your oven went out. On the inside of the oven there should be a small hole about the size of a 50cent piece on the floor of the oven. Turn on the gas for the oven, light a matchstick or rolled up piece of paper, stick it into that hole and it should light, monitor the oven for 30 seconds to see if it starts to heat. SAFETY 1st!
Dec 23, 2008 | Ovens
High flames in oven
Jul 21, 2008 | Frigidaire FGB24S5A Gas Single Oven
Ovens Logo
50 people viewed this question
Top KitchenAid Ovens Experts
Marvin
Marvin
Craig Butler
Craig Butler
Jim Goldsmith
Jim Goldsmith
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
