Question about GE (PSS26MSRSS) Side by Side Refrigerator
Freezer dethawed What is the explanation. I came home and all of my freezer is totally dethawed. The refrigerator part looks like it is still running
  • timothy14 Jun 15, 2008
    Same thing is happend to me, now it's the fridge side.
By the end of the day we realized we thought the refrig. part was working but was not. We pulled it out from the wall, unplugged and plugged it back in. Still no results. I unloaded everything from the freezer in the morning and refrig in the evening. Right after I got almost the very last item out, (the door on the refrig was opened and left opened) I moved the temperature control levers back and forth quickly, really just out of frustration, thinking, 'great no more refirgerator' - now what am I gonna do?!. i went to dump the last of the contents, and like some sick joke, the refrig started working and then the freezer. We have quite a bit of dust under the refrig. that may have been blocking a fan or something. I think God just wanted me to empty the refig contents and things that looks like pieces of the moon from my ridge. Go figure. I am praying no more problems.
Posted on Jun 16, 2008
Dethaws every 2nd or 3rd day open freezer door push door switch and works fine for an other couple off days this has been happening for about 1 week or so
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Aug 29, 2011 | GE Refrigerators
Defrost heater,every 2 weeks back of freezer frosts over, fridge gets warm, manualy dethaw get 2 more weeks
heatman101
Jun 06, 2011 | Microwave Ovens
Compressor is off and making click then buzzing noise frezzer is dethawing
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 10, 2011 | Amana Easy Reach AFD2535DE Bottom Freezer...
Top is frozen lower shelves food is dethawing
One of two things is going on here, either the door is not closing properly (or some one left it open), check the seal all the way around especially at the bottom.
Or most likely you have a refrigerant (freon) leak that has left the charge low enough that you are unable to get it to cool throughout. A leak on this type of unit is usually in the evaporator in the corner where a weld was made. The evaporator is about $189.00, with refrigerant a new drier and supplies I bet it would run about $450.00 to repair.
Apr 26, 2010 | Frigidaire 14.1 cu. ft. Upright Freezer...
FREEZER WORKING BUT FRIDGE NOT
Remove the rear panel in the freezer and see if the evaporator coils are frozen over.
If so dethaw coils with a hair dryer.
Reassemble freezer and set controls to the normal position.
Although you replaced the defrost timer if the coils were frozen over in the freezer no air can transfer to the ref. section from the freezer.
If you do not want to dethaw the coils unplug the ref. for 1-2 days and leave the doors open .The coils will dethaw by then.
Jan 17, 2010 | Kenmore Refrigerators
Water collects in the bottom of the freezer and freezes. I totally shut down the refrigerator for 24 hours and it is ok for 2-3 months when the same thing happens.
The defrost drain hole is plugged.
The drain is located in the back of the freezer at the bottom of the drain trough.
Remove the back panel if you are handy.
Or call a service tech.
After dethawing the the ice covering the defrost drain
poor hot water down the drain hole and wait a few minutes for the ice to melt in the drain tube.
If after 10min. the water does not drain or is real slow
you use a shop vac. to clear the debris from the drain line or air compressor to blow it out.
If the unit freezes up again call for service.
The defrost heater is proabally out of spec. or the drain heater(If the unit has one) is defective.
Hopefully this helps
Mike
Jan 09, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerator is stuck in defrost mode.
If the compressor is running and not getting cold I would say that you have burnt out your compressor.
If it was stuck in defrost you wouldn't hear the frig running. When in defrost the compressor stops while the frig defrosts.
Dec 29, 2009 | Refrigerators
My whirlpool gold refridgerator - side-by-side - gd5shaxkq00 - is defrosting
I already posted this, but here it is...
The outage/start relay needed replacing. I tried it, and it worked. (The kit came with insturctions.) Total cost: $64 (Would have been cheaper if I would have been willing to wait a couple of days - +/-$45.00.)
Apr 14, 2009 | Refrigerators
Kenmore freezer/fridge - freezer won't stay cold
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Jan 25, 2009 | Kenmore Elite HE4 Electric Dryer
GE (PSS26MSRSS) Side by Side Refrigerator Logo
61 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
